-   -   HTTP Error 401 - problem z wejsciem na stronke (https://forum.cdrinfo.pl/f5/http-error-401-problem-wejsciem-stronke-19597/)
SLAYER 08.04.2003 17:19
Mam problem z wejsciem na stronke www.wsz.air.prv.pl
Powinno mi sie pojawic okienko pytajace o login i haslo, a pisze taki blad:
HTTP Error 401
401.3 Unauthorized: Unauthorized due to ACL on resource
This error indicates that the credentials passed by the client do not have access to the particular resource on the server. This resource could be either the page or file listed in the address line of the client, or it could be another file on the server that is needed to process the file listed on the address line of the client.
Please make a note of the entire address you were trying to access and then contact the Web server's administrator to verify that you have permission to access the requested resource.
Admin jest kumplem z grupy i nie wie czemu tak sie dzieje. Inni wchodza bez poblemu. Mam Win 98. Moze mam jakies zle ustawienia w przegladarce.
Prosze o pomoc.
Wszystkie czasy w strefie CET. Aktualna godzina: 00:18.
