Off topic Forum poświęcone wszelkim innym tematom. |
#1 | |
.: Zapracowany :.
Data rejestracji: 23.01.2003
"Codziennie dowiaduje się czegoś nowego" - Pagerus ![]() |
#2 | |
Data rejestracji: 10.08.2002
#3 | |
.: Zapracowany :.
#4 | |
Data rejestracji: 05.11.2004
chocby wielowatkowosc
Minarchista
Data rejestracji: 20.09.2005
Choćby dziury załatać:
July 25, 2006 - Several vulnerabilities have been discovered in WinRar which could be exploited to execute arbitrary code and compromise system security. Users of this tool are advised to update to the latest version to correct these security problems. WinRAR is a popular file compression tool for Windows which supports, among others, the following formats: RAR, ZIP, CAB, ARJ, LZH, TAR, GZ, and ACE. Two stack overflow vulnerabilities have recently been detected in the modules that process LZH and SFX formats. An attacker could construct a compressed file based on LZH or SFX and send it to a potential victim with a vulnerable version of WinRAR installed. The stack overflow and execution of arbitrary code would occur on opening and extracting the file, leaving the system vulnerable to any action. The vulnerability in the LZH module was corrected in WinRAR 3.60 beta 7, and then version 3.60 beta 8 was published to correct the problem in the SFX module, as explained at: http://www.rarlab.com/rarnew.htm All affected users with a 3.x version of WinRAR are advised to install the latest update, WinRAR 3.60 beta 8, available at http://www.rarlab.com/download.htm Za : http://secunia.com/advisories/21080/ Ostatnio zmieniany przez salawalas : 01.08.2006 o godz. 10:51 |
#7 | |
.: Zapracowany :.
Minarchista
@andrzejj9
Niestety musz***281; Ci***281; rozczarowa***263;... Ale robi wra***380;enie, nie? |
#9 | |
the one
Data rejestracji: 08.12.2002
neverending path to perfection.. |
#10 | |
.: Zapracowany :.
![]() ![]() Chocia***380; z drugiej strony zapomnia***322;em, ***380;e jest co***347; takiego jak samowyzwalacz w aparacie ![]() Bez urazy salawalas ![]()
#11 | |
the one
#12 |
lołn łulf
Data rejestracji: 15.07.2005
Samowyzwalacz testosteronu
#13 |
Jukebox Hero
Data rejestracji: 17.09.2004
no coz nie zalapalem sie... szczescie ze i tak uzywam 7zipa
![]() to juz nie pierwsza tego typu "promocja". Rok temu zalapalem sie przez przypadek na darmowy "zakup" DivX6Pro. Problem tylko ze uzywam XVida (moim zdaniem lepszy a na pewno szybszy) przez co warty 20 dolcow divx skonczyl gdzies na plycie ![]() ![]() |
#14 | |
.: Zapracowany :.
#15 |
cenzurki nie ma?
