| Nero Oficjalne forum poświęcone aplikacjom ze stajni Nero AG |
Data rejestracji: 13.06.2009
Problem z nero
mam następujący problem proszę o pomoc
Kod:
Patryk
1C80-0000-19E5-MA2X-4002-8239-****
Windows XP 5.1
IA32
WinAspi: -
NT-SPTI used
Nero Version: 7.9.6.0
Internal Version: 7, 9, 6, 0
(Nero Express)
Recorder: <HL-DT-ST DVD-RAM GSA-H55N>Version: 1.05 - HA 1 TA 0 - 7.9.6.0
Adapter driver: <IDE> HA 1
Drive buffer : 2048kB
Bus Type : default (0) -> ATAPI, detected: ?
CD-ROM: <SONY DVD-ROM DDU1612 >Version: DYS3 - HA 1 TA 1 - 7.9.6.0
=== Scsi-Device-Map ===
DiskPeripheral : WDC WD800JB-00JJC0 atapi Port 0 ID 0 DMA: On
DiskPeripheral : ST3160215ACE atapi Port 0 ID 1 DMA: On
CdRomPeripheral : HL-DT-ST DVD-RAM GSA-H55N atapi Port 1 ID 0 DMA: Off
CdRomPeripheral : SONY DVD-ROM DDU1612 atapi Port 1 ID 1 DMA: On
CdRomPeripheral : Generic DVD-ROM 1.0 d347prt Port 2 ID 0 DMA: Off
=== CDRom-Device-Map ===
Generic DVD-ROM E: CdRom2
HL-DT-ST DVD-RAM GSA-H55N I: CdRom0
SONY DVD-ROM DDU1612 J: CdRom1
AutoRun : 1
Excluded drive IDs:
BUFE : 0
Physical memory : 1023MB (1048044kB)
Free physical memory: 500MB (512968kB)
Memory in use : 51 %
Uncached PFiles: 0x0
Use Inquiry : 1
Global Bus Type: default (0)
13.6.2009
Kompilacja ISO
14:21:15 #1 Text 0 File SCSIPTICommands.cpp, Line 424
14:21:15 #2 Text 0 File Isodoc.cpp, Line 6663
Iso document burn settings
Simulate : FALSE
Write : TRUE
Finalize CD : FALSE
Multisession : TRUE
Multisession type: : Continue multisession
Burning mode : DAO
Mode : 1
Character set : ISO 9660
Joliet : TRUE
14:21:15 #3 ISO9660GEN -11 File Geniso.cpp, Line 3343
14:21:15 #4 Text 0 File Burncd.cpp, Line 3508
14:21:16 #5 Text 0 File DlgWaitCD.cpp, Line 307
Last possible write address on media: 2295103 (510:01.28, 4482MB)
Last address to be written: 2180559 (484:34.09, 4258MB)
14:21:16 #6 Text 0 File DlgWaitCD.cpp, Line 319
14:21:16 #7 Text 0 File DlgWaitCD.cpp, Line 2964
Recorder: HL-DT-ST DVD-RAM GSA-H55N, Media type: DVD+R
Disc Manufacturer ID: MCC, Media Type ID: 004, Product revision number: 0
Disc Application Code: 0, Extended Information Indicators: 7
14:21:16 #8 Text 0 File DlgWaitCD.cpp, Line 493
14:21:16 #9 Text 0 File ThreadedTransferInterface.cpp, Line 793
0: TRM_DATA_MODE1 ()
original disc pos #0 + 717152 (717152) = #717152/159:22.2
-> TRM_DATA_MODE1, 2048, config 0, wanted index0 0 blocks, length 717152 blocks [I: HL-DT-ST DVD-RAM GSA-H55N]
14:21:16 #10 Text 0 File ThreadedTransferInterface.cpp, Line 995
Prepare [I: HL-DT-ST DVD-RAM GSA-H55N] for write in CUE-sheet-DAO
DAO infos:
MCN: ""
TOCType: 0x00; Session Closed, disc not fixated
Tracks 2 to 2: Idx 0 Idx 1 Next Trk
1: TRM_DATA_MODE1, 2048/0x00, FilePos 0 0 1468727296, ISRC ""
DAO layout:
___Start_|____Track_|_Idx_|_CtrlAdr_|_____Size_|______NWA_|_RecDep__________
1463408 | lead-in | 0 | 0x41 | 0 | 0 | 0x00
1463408 | 2 | 0 | 0x41 | 0 | 0 | 0x00
1463408 | 2 | 1 | 0x41 | 717152 | 1463408 | 0x00
2180560 | lead-out | 1 | 0x41 | 0 | 0 | 0x00
14:21:16 #11 Text 0 File SCSIPTICommands.cpp, Line 215
14:21:16 #12 Text 0 File Burncd.cpp, Line 4294
Caching options: cache CDRom or Network-Yes, small files-Yes (<64KB)
14:21:16 #13 Phase 24 File dlgbrnst.cpp, Line 1762
Caching of files started
14:21:16 #14 Text 0 File Burncd.cpp, Line 4413
Cache writing successful.
14:21:16 #15 Phase 25 File dlgbrnst.cpp, Line 1762
Caching of files completed
14:21:16 #16 Phase 36 File dlgbrnst.cpp, Line 1762
Burn process started at 8x (11 080 KB/s)
14:21:16 #17 Text 0 File ThreadedTransferInterface.cpp, Line 2721
Verifying disc position of item 0 (relocatable, disc pos, no patch infos, orig at #0): write at #1463408
14:21:16 #18 Text 0 File Cdrdrv.cpp, Line 9872
---- Disc Structure: Physical Format Information (00h) ----
Media Type: 0, Layer: 0, Address: 0 (0 h), AGID: 0; Length: 2050
Book Type: DVD-ROM (0), Part Version: 1.0x (1)
End Sector Number in Layer 0: 0 h (LBN: FFFD0000 h, 4193920 MB)
Media Specific [16..63]:
00 00 07 4D 43 43 00 00 - 00 00 00 30 30 34 00 38 ...MCC.....004.8
23 54 37 12 02 54 6C 02 - 92 5F 15 15 0B 0B 08 08 #T7..Tl.._......
01 19 1B 0C 0C 0C 0D 01 - 00 00 00 00 00 00 00 00 ................
14:21:16 #19 Text 0 File DVDR.cpp, Line 6553
Drive: HL-DT-ST DVD-RAM GSA-H55N
Book Type request [LG]: DVD-ROM
Changing the Book Type was finished successfully, return code 0
14:21:16 #20 CDR -1207 File DVDR.cpp, Line 6477
Book Type automatically set to: DVD-ROM
14:21:16 #21 SPTI -1066 File SCSIPassThrough.cpp, Line 179
CdRom0: SCSIStatus(x02) WinError(0) NeroError(-1066)
Sense Key: 0x05 (KEY_ILLEGAL_REQUEST)
Sense Code: 0x24
Sense Qual: 0x00
CDB Data: 0xAC 00 00 00 00 00 00 00 00 64 00 00
Sense Area: 0x70 00 05 00 00 00 00 0E 00 00 00 00 24
Buffer x06b90040: Len x648
14:21:16 #22 Text 0 File DVDPlusRW.cpp, Line 675
Start write address at LBA 1463408
DVD high compatibility mode: No
14:21:16 #23 Text 0 File ThreadedTransfer.cpp, Line 269
Pipe memory size 83836800
14:23:44 #24 SPTI -1 File SCSIPassThrough.cpp, Line 179
CdRom0: SCSIStatus(x02) WinError(0) NeroError(-1)
Sense Code: 0x80
Sense Qual: 0x04
CDB Data: 0x2A 00 00 17 65 D0 00 00 20 00 00 00
Sense Area: 0x70 00 03 00 00 00 00 0E 00 00 00 00 80 04
Buffer x0b9be380: Len x10000
0x2D C9 04 8F 2B 9E 93 85 DE 84 AA 2F 0E 79 B4 EF
0xBC C2 69 87 18 1D 13 08 F9 55 FE BC 7F 2F 3B 30
0x60 0A 25 60 A4 15 01 B3 47 81 5D 8F 49 86 88 61
14:23:44 #25 CDR -1 File Writer.cpp, Line 303
Unspecified Recorder Error
14:24:24 #26 Text 0 File DVDPlusRW.cpp, Line 935
EndDAO: Last written address 1533392
14:24:24 #27 Phase 38 File dlgbrnst.cpp, Line 1762
Burn process failed at 8x (11 080 KB/s)
14:24:24 #28 Text 0 File SCSIPTICommands.cpp, Line 261
14:24:31 #29 Text 0 File Cdrdrv.cpp, Line 11185
14:24:31 #30 Text 0 File SCSIPTICommands.cpp, Line 424
Existing drivers:
Registry Keys:
Ostatnio zmieniany przez joujoujou : 13.06.2009 o godz. 15:49 |
1. Włącz DMA.
2. Zmień nośniki. 3. Zastanów się nad zmianą zasilacza.
Głupi Yasio
Data rejestracji: 27.05.2003
Ja bym sie tez zastanowił nad wgraniem nowszej wersji Nero, lub próbował na innym sofcie.
Co DMA, zgadzam sie, co do nosnikow - stosuje Verbatimy, ale tu doczytalem sie DVD+ RW (nie wiem czy slusznie) a to juz sugeruje problemy.
Powyższa wypowiedz, wyraża jedynie moja opinię w dniu dzisiejszym. Nie może on służyć przeciwko mnie ani w dniu jutrzejszym, ani każdym innym następującym po tym terminie. Ponadto zastrzegam sobie prawo zmiany poglądów bez ostrzeżenia i podawania przyczyn. ****************************************** Monarchista, podstępnie knujący przeciwko Republice i demokracji! |
DVD-RW? Ja widzę DVD+R od MCC 04.
Jak wyżej: 1 włącz DMA 2 zmień nośniki (ten key medium error) 3 nie nagrywaj multisesji, z tym zbyt często są problemy - albo od razu albo później 4 może poskutkować wgranie nowszego firmware 5 ten zasilacz to na sam koniec bym zostawił Zawsze dobrze jest sprawdzić napęd na innym kompie. |
#5 | |
Głupi Yasio
Data rejestracji: 28.03.2011
mam ten sam problem hellp
| Problem, a właściwie błąd: Nero BackITup 2 | booboss | Dane | 8 | 25.05.2006 10:51 |
| Problem z Nero | madmax2 | Nero | 3 | 14.02.2006 21:38 |
| Nero problem z nagraniem jako dane pliku avi | Jagna | Dane | 4 | 20.01.2006 21:18 |
| NERO i CD-RW. Problem. | monroe | Napędy optyczne CD | 2 | 22.04.2004 00:09 |
| NERO i problem z otwarta sesja!!! | photonix | Napędy optyczne CD | 0 | 13.01.2002 17:54 |
