| Audio Dział poświęcony programom związanych z audio: - Nero Express (tylko część o audio), Nero Burning ROM (tylko część o audio), Nero SoundTrax, Nero WaveEditor |
Data rejestracji: 16.04.2008
mp3-->audio + raport błędów
po kilkunastu procentach nagrywania , proces zostaje przerwany, o to raport :
(co może być przyczyną?? z góry dzięki za pomoc, pozdrawiam!!) Windows XP 5.1 IA32 WinAspi: File 'Wnaspi32.dll': Ver=?.?.?.?, size=74240 bytes, created 2006-05-24 15:20:13 ahead WinASPI: File 'C:\Program Files\Ahead\nero\Wnaspi32.dll': Ver=2.0.1.74, size=164112 bytes, created 2004-10-26 18:35:32 Nero Version: 6.6.0.15 Internal Version: 6, 6, 0, 15h (Nero Express) Recorder: <TSSTcorp CD/DVDW TS-L632C>Version: AS06 - HA 0 TA 1 - 6.6.0.15 Adapter driver: <atapi> HA 0 Drive buffer : 2048kB Bus Type : default (0) -> ATAPI, detected: ATAPI CD-ROM: <TSSTcorp CD/DVDW TS-L632C>Version: AS06 - HA 0 TA 1 - 6.6.0.15 Adapter driver: <atapi> HA 0 === Scsi-Device-Map === DiskPeripheral : HTS421260H9AT00 atapi Port 0 ID 0 DMA: On CdRomPeripheral : TSSTcorp CD/DVDW TS-L632C atapi Port 0 ID 1 DMA: On === CDRom-Device-Map === TSSTcorp CD/DVDW TS-L632C E: CDRom0 ======================= AutoRun : 1 Excluded drive IDs: WriteBufferSize: 74448896 (0) Byte ShowDrvBufStat : 0 BUFE : 0 Physical memory : 511MB (523568kB) Free physical memory: 185MB (189952kB) Memory in use : 63 % Uncached PFiles: 0x0 Use Inquiry : 1 Global Bus Type: default (0) Check supported media : Disabled (0) 16.4.2008 Audio CD 16:27:03 #1 CDADOC -1 File Cdadoc.cpp, Line 1465 Audio item log info: Audio document burn settings: ============================= Burn mode: DAO, CD Text: On, Cache disk or network files: No, Cache small files: No, Cache files smaller than 65536 bytes. Audio Multisession: No List of audio tracks: ===================== Track 01: Length: 08:02.49, Pause frames: 150, Filters: 0, Name: '05-sunblock_feat_sandy-baby_baby_(audiophiles_remix)-scratch.mp3'. Track 02: Length: 08:25.54, Pause frames: 150, Filters: 0, Name: 'Bob Sinclar Ft Gary Nesta Pine - Give A Lil Love(Elektro Blues Clu.mp3'. Track 03: Length: 08:15.05, Pause frames: 150, Filters: 0, Name: 'Silverchair - Straight Lines (Mics Ctrl Alt Del Mash).mp3'. Track 04: Length: 07:33.36, Pause frames: 150, Filters: 0, Name: 'supafly___sunrise__original_mix_.mp3'. Track 05: Length: 07:53.45, Pause frames: 150, Filters: 0, Name: 'The Absolute feat. Suzanne Palmer - There Will Come A Day (Piano V.mp3'. Track 06: Length: 08:17.16, Pause frames: 150, Filters: 0, Name: 'The Fatback Band - Feel The Fire (Bah Samba Remix).mp3'. Track 07: Length: 06:30.41, Pause frames: 150, Filters: 0, Name: 'The Star Alliance Feat. Sheila Ferguson - Hes A Runner (Fedde Le G.mp3'. Track 08: Length: 07:16.73, Pause frames: 150, Filters: 0, Name: 'Thomas Gold vs. Chris Montana - Sexgirl (Chriss Ortega Mix).mp3'. Track 09: Length: 06:54.12, Pause frames: 150, Filters: 0, Name: 'Unity Goove - Somethings Gotta Give (Wawa Mix).mp3'. Total size: 69:27.31 16:27:03 #2 Text 0 File Burncd.cpp, Line 2946 TSSTcorp CD/DVDW TS-L632C Włączono Super Link 16:27:04 #3 Text 0 File Reader.cpp, Line 127 Reader running 16:27:04 #4 Text 0 File AudioCompilationImpl.cpp, Line 842 DRM: StartDrmRecording(RealRec:1, ImageRec:0, Copies:1) DRM: Beginning burn process. 16:27:04 #5 Text 0 File Writer.cpp, Line 122 Writer TSSTcorp CD/DVDW TS-L632C running 16:27:04 #6 Text 0 File Burncd.cpp, Line 3231 Turn on Disc-At-Once, using CD-R/RW media 16:27:04 #7 Text 0 File DlgWaitCD.cpp, Line 269 Last possible write address on media: 359848 ( 79:59.73) Last address to be written: 312405 ( 69:27.30) 16:27:04 #8 Text 0 File DlgWaitCD.cpp, Line 281 Write in overburning mode: NO (enabled: CD) 16:27:04 #9 Text 0 File DlgWaitCD.cpp, Line 2477 Recorder: TSSTcorp CD/DVDW TS-L632C; CDR code: 00 97 27 18; OSJ entry from: Plasmon Data systems Ltd. ATIP Data: Special Info [hex] 1: D0 00 A0, 2: 61 1B 12 (LI 97:27.18), 3: 4F 3B 4A (LO 79:59.74) Additional Info [hex] 1: 00 00 00 (invalid), 2: 00 00 00 (invalid), 3: 00 00 00 (invalid) 16:27:04 #10 Text 0 File DlgWaitCD.cpp, Line 447 >>> Protocol of DlgWaitCD activities: <<< ========================================= 16:27:04 #11 Text 0 File ThreadedTransferInterface.cpp, Line 830 Setup items (after recorder preparation) 0: TRM_AUDIO_NOPRE (05-sunblock_feat_sandy-baby_baby_(audiophiles_remix)-scratch.mp3) 2 indices, index0 (150) not provided original disc pos #0 + 36199 (36199) = #36199/8:2.49 relocatable, disc pos for caching/writing not required/not required, no patch infos -> TRM_AUDIO_ULTRARAW96, 2448, config 0, wanted index0 0 blocks, length 36199 blocks [TSSTcorp CD/DVDW TS-L632C] 1: TRM_AUDIO_NOPRE (Bob Sinclar Ft Gary Nesta Pine - Give A Lil Love(Elektro Blues Clu.mp3) 2 indices, index0 (150) not provided original disc pos #0 + 37929 (37929) = #37929/8:25.54 relocatable, disc pos for caching/writing not required/not required, no patch infos -> TRM_AUDIO_ULTRARAW96, 2448, config 0, wanted index0 0 blocks, length 37929 blocks [TSSTcorp CD/DVDW TS-L632C] 2: TRM_AUDIO_NOPRE (Silverchair - Straight Lines (Mics Ctrl Alt Del Mash).mp3) 2 indices, index0 (150) not provided original disc pos #0 + 37130 (37130) = #37130/8:15.5 relocatable, disc pos for caching/writing not required/not required, no patch infos -> TRM_AUDIO_ULTRARAW96, 2448, config 0, wanted index0 0 blocks, length 37130 blocks [TSSTcorp CD/DVDW TS-L632C] 3: TRM_AUDIO_NOPRE (supafly___sunrise__original_mix_.mp3) 2 indices, index0 (150) not provided original disc pos #0 + 34011 (34011) = #34011/7:33.36 relocatable, disc pos for caching/writing not required/not required, no patch infos -> TRM_AUDIO_ULTRARAW96, 2448, config 0, wanted index0 0 blocks, length 34011 blocks [TSSTcorp CD/DVDW TS-L632C] 4: TRM_AUDIO_NOPRE (The Absolute feat. Suzanne Palmer - There Will Come A Day (Piano V.mp3) 2 indices, index0 (150) not provided original disc pos #0 + 35520 (35520) = #35520/7:53.45 relocatable, disc pos for caching/writing not required/not required, no patch infos -> TRM_AUDIO_ULTRARAW96, 2448, config 0, wanted index0 0 blocks, length 35520 blocks [TSSTcorp CD/DVDW TS-L632C] 5: TRM_AUDIO_NOPRE (The Fatback Band - Feel The Fire (Bah Samba Remix).mp3) 2 indices, index0 (150) not provided original disc pos #0 + 37291 (37291) = #37291/8:17.16 relocatable, disc pos for caching/writing not required/not required, no patch infos -> TRM_AUDIO_ULTRARAW96, 2448, config 0, wanted index0 0 blocks, length 37291 blocks [TSSTcorp CD/DVDW TS-L632C] 6: TRM_AUDIO_NOPRE (The Star Alliance Feat. Sheila Ferguson - Hes A Runner (Fedde Le G.mp3) 2 indices, index0 (150) not provided original disc pos #0 + 29291 (29291) = #29291/6:30.41 relocatable, disc pos for caching/writing not required/not required, no patch infos -> TRM_AUDIO_ULTRARAW96, 2448, config 0, wanted index0 0 blocks, length 29291 blocks [TSSTcorp CD/DVDW TS-L632C] 7: TRM_AUDIO_NOPRE (Thomas Gold vs. Chris Montana - Sexgirl (Chriss Ortega Mix).mp3) 2 indices, index0 (150) not provided original disc pos #0 + 32773 (32773) = #32773/7:16.73 relocatable, disc pos for caching/writing not required/not required, no patch infos -> TRM_AUDIO_ULTRARAW96, 2448, config 0, wanted index0 0 blocks, length 32773 blocks [TSSTcorp CD/DVDW TS-L632C] 8: TRM_AUDIO_NOPRE (Unity Goove - Somethings Gotta Give (Wawa Mix).mp3) 2 indices, index0 (150) not provided original disc pos #0 + 31062 (31062) = #31062/6:54.12 relocatable, disc pos for caching/writing not required/not required, no patch infos -> TRM_AUDIO_ULTRARAW96, 2448, config 0, wanted index0 0 blocks, length 31062 blocks [TSSTcorp CD/DVDW TS-L632C] -------------------------------------------------------------- 16:27:04 #12 Text 0 File ThreadedTransferInterface.cpp, Line 1043 Prepare recorder [TSSTcorp CD/DVDW TS-L632C] for write in raw writing DAO infos: ========== MCN: "" TOCType: 0x00; Session Closed, disc fixated Tracks 1 to 9: 1: TRM_AUDIO_ULTRARAW96, 2448/0x00, FilePos 0 367200 88982352, ISRC "" 2: TRM_AUDIO_ULTRARAW96, 2448/0x00, FilePos 88982352 89349552 182199744, ISRC "" 3: TRM_AUDIO_ULTRARAW96, 2448/0x00, FilePos 182199744 182566944 273461184, ISRC "" 4: TRM_AUDIO_ULTRARAW96, 2448/0x00, FilePos 273461184 273828384 357087312, ISRC "" 5: TRM_AUDIO_ULTRARAW96, 2448/0x00, FilePos 357087312 357454512 444407472, ISRC "" 6: TRM_AUDIO_ULTRARAW96, 2448/0x00, FilePos 444407472 444774672 536063040, ISRC "" 7: TRM_AUDIO_ULTRARAW96, 2448/0x00, FilePos 536063040 536430240 608134608, ISRC "" 8: TRM_AUDIO_ULTRARAW96, 2448/0x00, FilePos 608134608 608501808 688730112, ISRC "" 9: TRM_AUDIO_ULTRARAW96, 2448/0x00, FilePos 688730112 689097312 765137088, ISRC "" DAO layout: =========== __Start_|____Track_|_Idx_|_CtrlAdr_|_RecDep_______ ___ -150 | lead-in | 0 | 0x01 | 0x00 -150 | 1 | 0 | 0x21 | 0x00 0 | 1 | 1 | 0x21 | 0x00 36199 | 2 | 0 | 0x21 | 0x00 36349 | 2 | 1 | 0x21 | 0x00 74278 | 3 | 0 | 0x21 | 0x00 74428 | 3 | 1 | 0x21 | 0x00 111558 | 4 | 0 | 0x21 | 0x00 111708 | 4 | 1 | 0x21 | 0x00 145719 | 5 | 0 | 0x21 | 0x00 145869 | 5 | 1 | 0x21 | 0x00 181389 | 6 | 0 | 0x21 | 0x00 181539 | 6 | 1 | 0x21 | 0x00 218830 | 7 | 0 | 0x21 | 0x00 218980 | 7 | 1 | 0x21 | 0x00 248271 | 8 | 0 | 0x21 | 0x00 248421 | 8 | 1 | 0x21 | 0x00 281194 | 9 | 0 | 0x21 | 0x00 281344 | 9 | 1 | 0x21 | 0x00 312406 | lead-out | 1 | 0x01 | 0x00 16:27:04 #13 Phase 36 File dlgbrnst.cpp, Line 1832 Burn process started at 16x (2 400 KB/s) 16:27:04 #14 Text 0 File ThreadedTransferInterface.cpp, Line 2643 Verifying disc position of item 0 (relocatable, no disc pos, no patch infos, orig at #0): write at #0 16:27:04 #15 Text 0 File ThreadedTransferInterface.cpp, Line 2643 Verifying disc position of item 1 (relocatable, no disc pos, no patch infos, orig at #0): write at #36349 16:27:04 #16 Text 0 File ThreadedTransferInterface.cpp, Line 2643 Verifying disc position of item 2 (relocatable, no disc pos, no patch infos, orig at #0): write at #74428 16:27:04 #17 Text 0 File ThreadedTransferInterface.cpp, Line 2643 Verifying disc position of item 3 (relocatable, no disc pos, no patch infos, orig at #0): write at #111708 16:27:04 #18 Text 0 File ThreadedTransferInterface.cpp, Line 2643 Verifying disc position of item 4 (relocatable, no disc pos, no patch infos, orig at #0): write at #145869 16:27:04 #19 Text 0 File ThreadedTransferInterface.cpp, Line 2643 Verifying disc position of item 5 (relocatable, no disc pos, no patch infos, orig at #0): write at #181539 16:27:04 #20 Text 0 File ThreadedTransferInterface.cpp, Line 2643 Verifying disc position of item 6 (relocatable, no disc pos, no patch infos, orig at #0): write at #218980 16:27:04 #21 Text 0 File ThreadedTransferInterface.cpp, Line 2643 Verifying disc position of item 7 (relocatable, no disc pos, no patch infos, orig at #0): write at #248421 16:27:04 #22 Text 0 File ThreadedTransferInterface.cpp, Line 2643 Verifying disc position of item 8 (relocatable, no disc pos, no patch infos, orig at #0): write at #281344 16:27:04 #23 Text 0 File Mmc.cpp, Line 16881 StartDAO : CD-Text - On 16:27:04 #24 Text 0 File Mmc.cpp, Line 21663 Set BUFE: Super Link -> ON 16:28:17 #25 SCSI -1135 File Cdrdrv.cpp, Line 1436 SCSI Exec, HA 0, TA 1, LUN 0, buffer 0x0B6B0000 Status: 0x04 (0x01, SCSI_ERR) HA-Status 0x00 (0x00, OK) TA-Status 0x02 (0x01, SCSI_TASTATUS_CHKCOND) Sense Key: 0x03 (KEY_MEDIUM_ERROR) Sense Code: 0x0C Sense Qual: 0x00 CDB Data: 0x2A 0x00 0x00 0x00 0x90 0xD5 0x00 0x00 0x1A 0x00 0x00 0x00 Sense Data: 0x70 0x00 0x03 0x00 0x00 0x00 0x00 0x0A 0x00 0x00 0x00 0x00 0x0C 0x00 16:28:17 #26 CDR -1135 File Writer.cpp, Line 311 Write error 16:28:21 #27 Text 0 File ThreadedTransfer.cpp, Line 228 all writers idle, stopping conversion 16:28:21 #28 Text 0 File ThreadedTransfer.cpp, Line 222 conversion idle, stopping reader 16:28:21 #29 Phase 38 File dlgbrnst.cpp, Line 1832 Burn process failed at 16x (2 400 KB/s) 16:28:21 #30 Text 0 File AudioCompilationImpl.cpp, Line 867 DRM: DRM burn session terminated. 16:28:21 #31 Text 0 File AudioCompilationImpl.cpp, Line 896 DRM: Closing entire DRM handling. Bye. Existing drivers: File 'Drivers\CDRALW2K.SYS': Ver=8.0.0.212 , size=9464 bytes, created 2007-03-08 01:51:00 File 'Drivers\PXHELP20.SYS': Ver=3.00.56a, size=43528 bytes, created 2007-03-08 01:51:00 (Prassi/Veritas driver for win 2K) File 'Drivers\atapi.sys': Ver=5.1.2600.2180 (xpsp_sp2_rtm.040803-2158), size=95360 bytes, created 2004-08-03 22:59:44 (Adapter driver for rec) Registry Keys: HKLM\Software\Microsoft\Windows NT\CurrentVersion\WinLogon\AllocateCDROMs : 0 (Security Option) |
stara nagrywarka w laptopie + kiepskie p***322;yty = powy***380;szy efekt.
tylko w tym problem ,że ściągnąłem jakiś inny prymitywny programik i wszystko działa ,a płytki to sony cd-r audio premium , więc nie są złej jakości:/ kłopot musi tkwić w nero. Myślałem ,że ten raport coś jakiejś osobie powie i ta mi pomoże. |
Te p***322;ytki s***261; od Plasmona, wi***281;c trudno je nazwa***263; dobrymi
Key_Medium_Error znaczy, ***380;e nagrywarka nieprawid***322;owo rozpoznaje no***347;nik. Wina p***322;ytek lub nagrywarki. Podejrzewam, ***380;e w tym innym programiku te***380; ci si***281; b***281;dzie wysypywa***263;. |
próbowałem też na innych płytkach i teraz już nawet żaden inny programik nie nagrywa:/ zastanawia mnie też jedno: laptop był kupiony jakiś rok temu , a nagrywarka była użyta max. 20 razy do zapisu. Podczas procesu zapis "dochodzi" do 5 -30% i nagle użycie bufora spada do zera i przerywa:/
Nap***281;dy laptopowe s***261;, og***243;lnie m***243;wi***261;c, kiepskie.
Poczytaj forum, te problemy s***261; cz***281;ste. Prawdopodobnie wina jest jednak po stronie nagrywarki. |
| Problemy z plikami MP3 ! | Maximus Magnus | Audio/Stacjonarne nagrywarki i nośniki CD-R Audio | 2 | 07.02.2008 11:13 |
| Problem z nagrywaniem Acer | deenoos | Napędy optyczne CD | 5 | 28.03.2006 01:38 |
| index:of | jazonik | Off topic | 4 | 19.07.2005 17:03 |
| Nagrywanie mp3 pod car audio | SIWYYY | Napędy optyczne CD | 6 | 01.03.2004 15:59 |
| mp3 na DVD | Lodofka | Napędy optyczne CD | 3 | 18.11.2001 17:37 |
