-   Dane (https://forum.cdrinfo.pl/f59/)
-   -   NERO63125 i Nec 3500 AG:problem (https://forum.cdrinfo.pl/f59/nero63125-nec-3500-ag-problem-66049/)
suchyjastrzab 14.06.2006 01:06
Tak na pocz***261;tek to w***322;***261;cz DMA na obu kana***322;ach IDE.
shalashaska 14.06.2006 00:49
Jestem troch***281; nie teges z tym wszystkim:P.A co do pr***281;dko***347;ci to nie widzi wi***281;kszej ni***380; 1/2/2,4 http://img160.imageshack.us/img160/7057/predkosc0ab.jpg .A co do biosu to si***281; na tym nie znam i wol***281; nic z tym nie kombinowa***263;:(
LOG
xxxx-xxxx-xxxx-xxxx-xxxx-xxxx
Windows XP 5.1
IA32
WinAspi: -
ahead WinASPI: File 'C:\Program Files\Ahead\Nero\Wnaspi32.dll': Ver=2.0.1.68, size=160016 bytes, created 2004-07-22 17:33:44
Wersja Nero: 6.3.1.25
Nagrywarka: <_NEC DVD_RW ND-3500AG> Wersja: 2.16 - HA 0 TA 1 - 6.3.1.25
Sterownik adaptera: <nvatabus> HA 0
Drive buffer : 2048kB
Bus Type : default (0) -> ATAPI, detected: ?
CD-ROM: <_NEC DVD_RW ND-3500AG>Wersja: 2.16 - HA 0 TA 1 - 6.3.1.25
=== Scsi-Device-Map ===
DiskPeripheral : ST380011A nvatabus Port 0 ID 0 DMA: Off
CdRomPeripheral : _NEC DVD_RW ND-3500AG nvatabus Port 0 ID 1 DMA: Off
CdRomPeripheral : HL-DT-ST CD-RW GCE-8160B nvatabus Port 0 ID 3 DMA: Off
=== CDRom-Device-Map ===
_NEC DVD_RW ND-3500AG K: CDRom0
HL-DT-ST CD-RW GCE-8160B L: CDRom1
AutoRun : 1
Excluded drive IDs:
ShowDrvBufStat : 0
BUFE : 0
Physical memory : 1023MB (1048036kB)
Free physical memory: 573MB (587636kB)
Memory in use : 43 %
Uncached PFiles: 0x0
Use Static Write Speed Table: 0
Use Inquiry : 1
Global Bus Type: default (0)
13.6.2006
Kompilacja UDF
23:52:37 #1 Text 0 File Isodoc.cpp, Line 6083
Iso document burn settings
Simulate : FALSE
Write : TRUE
Finalize CD : TRUE
Multisession : FALSE
Burning mode : DAO
Mode : 1
Character set : ISO 9660
Joliet : TRUE
23:52:37 #2 Text 0 File Reader.cpp, Line 126
Reader running
23:52:37 #3 Text 0 File Burncd.cpp, Line 3152
23:52:37 #4 Text 0 File DlgWaitCD.cpp, Line 247
Last possible write address on media: 2298495 (510:46.45, 4489MB)
Last address to be written: 1235599 (274:34.49, 2413MB)
23:52:37 #5 Text 0 File DlgWaitCD.cpp, Line 259
23:52:37 #6 Text 0 File DlgWaitCD.cpp, Line 2162
Recorder: _NEC DVD_RW ND-3500AG, Media type: DVD-R
Disc Manufacturer: SONY16 - D1
Disc Application Code: 64, Disc Physical Code: 193
23:52:37 #7 Text 0 File DlgWaitCD.cpp, Line 420
23:52:37 #8 Text 0 File ThreadedTransferInterface.cpp, Line 813
0: TRM_DATA_MODE1 (CTransferItem)
original disc pos #0 + 1235600 (1235600) = #1235600/274:34.50
relocatable, disc pos for caching/writing not required/required, no patch infos
-> TRM_DATA_MODE1, 2048, config 0, wanted index0 0 blocks, length 1235600 blocks [_NEC DVD_RW ND-3500AG]
23:52:37 #9 Text 0 File ThreadedTransferInterface.cpp, Line 984
Prepare recorder [_NEC DVD_RW ND-3500AG] for write in CUE-sheet-DAO
DAO infos:
MCN: ""
Tracks 1 to 1:
1: TRM_DATA_MODE1, 2048/0x00, FilePos 0 0 2530508800, ISRC ""
DAO layout:
__Start_|____Track_|_Idx_|_RecDep_|_CtrlAdr_
0 | lead-in | 0 | 0x00 | 0x41
0 | 1 | 0 | 0x00 | 0x41
0 | 1 | 1 | 0x00 | 0x41
1235600 | lead-out | 1 | 0x00 | 0x41
23:52:37 #10 Phase 24 File dlgbrnst.cpp, Line 1855
Rozpocz***281;to buforowanie plik***243;w
23:52:37 #11 Text 0 File Burncd.cpp, Line 4163
Cache writing successful.
23:52:37 #12 Phase 25 File dlgbrnst.cpp, Line 1855
Zako***324;czono buforowanie plik***243;w
23:52:37 #13 Phase 36 File dlgbrnst.cpp, Line 1855
Rozpocz***281;to zapis z pr***281;dko***347;ci***261; 2x (2 770 KB/s)
23:52:37 #14 Text 0 File ThreadedTransferInterface.cpp, Line 2344
23:52:37 #15 Text 0 File dlgbrnst.cpp, Line 1713
Set remaining time: 15:37,054 (937054ms) -> OK
23:52:37 #16 Text 0 File DVDR.cpp, Line 2000
Recording mode: Sequential Recording Mode
23:52:37 #17 Text 0 File Mmc.cpp, Line 20660
Set BUFE: supported -> ON
23:52:37 #18 Text 0 File DVDR.cpp, Line 2141
Start write address at LBA 0
23:52:37 #19 Text 0 File Cdrdrv.cpp, Line 8230
---- DVD Structure: Physical Format Information (00h) ----
Layer: 0, Address: 0 (0 h), AGID: 0; Length: 2050
Book Type: DVD-R (2), Part Version: 5
End Physical Sector Number of Data Area: 26127F h
End Sector Number in Layer 0: 0 h
Start sector number of the current Border-Out: 2FE10 h
Start sector number of the next Border-In: 2FFA0 h
Media Specific [16..63]:
00 60 00 10 20 30 40 50 - 00 00 00 21 00 00 00 00 .`...0@P...!....
00 02 FE 10 00 02 FF A0 - 00 00 00 00 00 00 00 00 ................
00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00 ................
23:52:37 #20 SCSI -1046 File Cdrdrv.cpp, Line 1191
SCSI Exec, HA 0, TA 1, LUN 0
Status: 0x04 (0x01, SCSI_ERR)
HA-Status 0x00 (0x00, OK)
TA-Status 0x02 (0x01, SCSI_TASTATUS_CHKCOND)
Sense Key: 0x05 (KEY_ILLEGAL_REQUEST)
Sense Code: 0x30
Sense Qual: 0x05
CDB Data: 0x53 0x00 0x00 0x00 0x00 0x00 0x12 0xDA 0x90 0x00 0x00 0x00
Sense Data: 0x70 0x00 0x05 0x00 0x00 0x00 0x00 0x0A
0x00 0x00 0x00 0x00 0x30 0x05
23:52:37 #21 Text 0 File DVDR.cpp, Line 5588
Book Type counter: 500, Book Type selected in EEPROM, command version 2
23:52:37 #22 Text 0 File DVDR.cpp, Line 5588
23:52:37 #23 Text 0 File DVDR.cpp, Line 5588
23:52:37 #24 CDR -1207 File DVDR.cpp, Line 4509
Book Type automatically set to: DVD-ROM
23:52:37 #25 Text 0 File DVDR.cpp, Line 4818
Drive: _NEC DVD_RW ND-3500AG
Book Type request: DVD-ROM
Book Type setting not supported for the loaded disc type
23:52:37 #26 CDR -1046 File ThreadedTransferInterface.cpp, Line 1614
Nieprawid***322;owy dysk!
23:52:37 #27 TRANSFER -27 File ThreadedTransferInterface.cpp, Line 1614
Wykonanie polecenia Rozpocznij w trybie DAO nie jest mo***380;liwe!
23:52:37 #28 Text 0 File dlgbrnst.cpp, Line 1713
Set remaining time: 0:00,000 (0ms) -> OK
23:52:37 #29 Phase 38 File dlgbrnst.cpp, Line 1855
Zapis z pr***281;dko***347;ci***261; 2x (2 770 KB/s) nie powi***243;d***322; si***281;!
Existing drivers:
File 'Drivers\PXHELP20.SYS': Ver=2.03.32a, size=20640 bytes, created 2006-04-19 00:34:55 (Prassi/Veritas driver for win 2K)
File 'Drivers\nvatabus.sys': Ver=5.10.2600.0446 built by: WinDDK, size=79360 bytes, created 2004-06-03 10:40:46 (Adapter driver for rec)
Registry Keys:
Edytowane przez BD: Nie podajemy numer***243;w seryjnych na forum.
joujoujou 14.06.2006 00:41
Wrzu***263; log z nero, warto by***322;oby to nero zaktualizowa***263; do jakiego***347; 6.6... i nowy bios do nagrywarki...
Poza tym wolniej nie znaczy lepiej. :nie:
Spr***243;buj wypali***263; x8 :idea:
shalashaska 14.06.2006 00:38
Normalnie zawsze mi wypala***322;o p***322;ytki DVD bez problemowo.A jak chc***281; wykona***263; wypalenie dvd to mi wyskakuje co***347; takiego http://img161.imageshack.us/img161/4301/beztytuu2de.jpg .Testowa***322;em na zwyk***322;ej CD i wypala ***322;adnie, tylko DVD mu co***347; nie odpowiada.U***380;ywam p***322;yty DVD-R Sony 120min/4.7GB 16x.I nie wa***380;ne jakie dane chc***281; wypali***263;, zawsze mam to samo...error.Aha i widzi max pr***281;dko***347;***263; nagrywania 2.4 i dziwi mnie to troch***281;.Mo***380;e mi kto***347; wyt***322;umaczy***263; co jest nie tak?:|
Wszystkie czasy w strefie CET. Aktualna godzina: 03:41.
