Stary 18.03.2009, 13:53   #1
Piotrek1985
Data rejestracji: 16.05.2005
Piotrek1985 zaczyna zdobywać reputację <1 - 49 pkt>
Problem z PSS Plex.
Witam.
Mam problem z tym programem. Mam plik PSS otwieram go w Plexie uruchamiam opcję DEMULTIPLEX i wszystko ładnie idzie, ale gdy już proces jest zakończony to mam plik .m2v ALE zamiast tego drugiego czyli .wav mam plik nazwie File-09989-Alt0 bez rozszerzenia i nie mogę tego połączyć w multiplexie... Co z tym zrobić ??
Ostatnio zmieniany przez Piotrek1985 : 18.03.2009 o godz. 13:58
Piotrek1985 jest offline   Odpowiedz cytując ten post
Stary 18.03.2009, 15:05   #2
RTFM
Usage (Windows)
Select 'Demultiplex' or 'Multiplex' from the main screen, and you will be taken to a screen to fill in the name of the source file(s) and destination file(s).
For demultiplexing, just hit start. If all goes ok, you will get a M2V (MPEG2 Video) file, and a WAV (Audio) file. In some cases you may find you get multiple WAV files (often ending in '-Alt1', '-Alt2', etc) - these are alternate sound streams, often used in multilingual games.
For multiplexing, you will have a few additional options:
'Use Sound Compression (ADPCM)' - For games that support ADPCM, it will compress the audio.
'Sound Stream Number' - Generally, most games will use stream 0 for an audio track. However, some games that have multilingual support will use streams 1 or higher for alternate language soundtracks. You will know this is the case if demultiplexing produces filenames that end with '-Alt#', where # is the stream number.
'Use Custom Profile' - In some cases, the PSS format used by a particular game may be radically different than normal. This option tells PSS Plex to handle the multiplex to a game's custom requirements
. Currently the only option available here is for Zone of the Enders (details on this option are in the tutorial doc).
A tutorial is provided with this distribution to step you through creating DVD-rips with PSS files, for a few different games.
Stary 18.03.2009, 18:36   #3
Piotrek1985
Berion ja to przeczytałem, ale i tak nie wiem jak te pliki połączyć, co w tm przypadku trzeba zrobić ??
Stary 18.03.2009, 19:10   #4
Mnie też to zainteresowało. Więc... należałoby przeczytać jednak ten opis dotyczący Zone of The Enders i prawdopodobnie multipleksacja tylko z poziomu cmd.
Oj nie mam czasu za bardzo na takie zabawy, ale zajrzę.
Stary 18.03.2009, 19:49   #5
Piotrek1985
Bardzo bym prosił...
EDIT:
To samo mam w PSS Demux, mam plik z filmem działa, no ale wiadomo bez dzwięku... a zamiast wev mam plik o końcówce .dat... W MF Audio można odczytać ten plik.
Ostatnio zmieniany przez Piotrek1985 : 18.03.2009 o godz. 20:04
Stary 20.03.2009, 11:46   #6
Piotrek1985
Baerion tutaj jest ten plik:
http://rapidshare.com/files/21137935...566_0.rar.html
Stary 27.03.2009, 15:10   #7
Piotrek1985
Napisany przez Piotrek1985 Podgląd Wiadomości
Ok. Berion trochę męczyłem ten plik. Udało mi się go przetłumaczyć, wsadzić z powrotem w ISO i wszystko było by fajnie gdyby nie jeden problem: Nie ma dźwięku ! PSS Plex w zasadzie wypakowuje dźwięk ale nie ma w tym pliku headera więc dlatego końcówka jest taka a nie inna. To samo w PSS Demux końcówka plik to .dat Próbowałem więc wsadzić header ze standardowego pliku wav i podziałało mogłem zmultiplexować oba pliki. Ale gdy przyciąłem plik na identyczną wielkość jak oryginał i wsadziłem go w ISO okazało się, że obraz może i jest, ale nie ma w nim dźwięku. Mam pytanie czy istnieje jakiś program, który pozwolił by mi na połączenie tych dwóch pików to jest m2v i audio bez headera czy header jest wymagany i jeśli tak to jak odnaleźć ten właściwy ??
Tutaj jest ten plik jeszcze raz:
http://www.megaupload.com/?d=A5UT7SXQ
Stary 29.03.2009, 13:06   #8
Mam go nadal, nie wywalałem. W każdym razie miło, że próbujesz rozwiązać problem samodzielnie.
Ja myślę, że problem polega na czym innym. Gra używa drugiego kanału audio, a nie pierwszego. Ale jak mówiłem jeszcze nie zaglądałem do tego.
Stary 29.03.2009, 21:49   #9
Piotrek1985
Hmm szczerze powiedziawszy nie myślałem o tym, ale to rodzi teraz kolejne pytania jak zmuxować te dwa pliki aby audio było w drugim kanale ??
Stary 01.04.2009, 21:21   #10
Nie, nie, bzdury wypisałem. Skoro jest -Alt0 to musi chodzić tylko o pierwszy kanał. Nie możesz też doklejać sobie headera, skoro moduły odpowiedzialne za obsługę PSS tego nie rozumieją. Sprawa jest skomplikowana, ponieważ nie ma scenowych, dedykowanych do tego narzędzi. Square-Enix zrobiło sobie własne, podobnie jak moduł do obsługi tego syfu. Jedynym sensownym rozwiązaniem byłoby po prostu poprosić jakiegoś programistę z nadwyżką wolnego czasu, żeby zmontował taki program. Ale to to wiesz sam doskonale. ;]
PSS Demux odpada, bo obsługuje tylko standardowe PSS (poza tym tylko w jedną stronę ). PS2STR jest oficjalnym wynalazkiem z SDK, ale też jak w przypadku PSS Demux, tylko do standardowych plików (+ IPU które też dosyć często są używane).
Zwróciłem uwagę na PSS bo Zone of The Enders ma podobne customy. Niestety po wybraniu jego profilu i suba, wysypuje się przy multipleksacji (może ma na sztywno wpisane wielkości plików). Chciałem jeszcze drania zmusić do współpracy z cmd, ale... nie wiem jak XD Za każdym razem drze się o niepoprawnej komendzie (na razie bawiłem się standardowym *.pss z LoK-Solu Reavera).
Kod:
PSS_Plex.exe "c:\test.m2v" "c:\test.wav" "c:\test_2.pss"
pause
W readme wyraźnie jest napisane, żeby pliki dać w nawiasy. Geez, wstyd
Generalnie rzecz biorąc to przyszło mi do głowy, żeby dać /STREAM0 i zamiast wave'a dać mu sub. Ten syntax jest jakiś poj*y, a ja mam dziś kiepski humor...
Stary 01.04.2009, 23:17   #11
Piotrek1985
Wow, wow wow zaraz Berion chcesz powiedzieć, że z CMD daje radę ??
Stary 02.04.2009, 11:15   #12
Nadinterpretacja
Ja, nie daję rady, zmusić go w cmd do współpracy. Jakiś głupi jestem bo nie mogę dojść prawidłowego syntax'u. Wątpię aby to pomogło, skoro gui się wysypuje, ale spróbować można. Szczególnie zaintrygował mnie parametr /STREAM#, tyle, że chyba nie przyjmie *.sub zamiast *.wav.
Stary 15.04.2009, 20:03   #13
Piotrek1985
Czyli nic już z tym się nie da zrobić ??
Stary 15.04.2009, 20:45   #14
Musisz znaleźć dobrego samarytanina, który napisze Ci multiplekser.
Stary 03.05.2009, 15:39   #15
Piotrek1985
Berion, a że tak jeszcze Ciebie zapytam czy może wiesz gdzie szukać tego dobrego samarytanina ?? Ajkaś strona, grupa etc ??
Czy ktoś ten problem wreszcie rozwiąże??? sovi Napędy optyczne DVD 15 28.02.2006 11:27
Problem z nagrywarką. rafkup Napędy optyczne CD 13 07.12.2003 14:36
dziwny problem z nagrywaniem... he-man Napędy optyczne CD 7 09.06.2002 22:29
Wszystkie czasy w strefie CET. Aktualna godzina: 13:28.
