Stary 24.08.2015, 13:16   #1381
szczuru
eŁDeZet Ma(j)ster
Avatar użytkownika szczuru
Data rejestracji: 05.04.2005
Jest Rebug 4.75
Stary 24.08.2015, 14:02   #1382
Jest jakiś changelog?
Stary 24.08.2015, 14:19   #1383
Diabolique
Horror Fan
Avatar użytkownika Diabolique
Data rejestracji: 27.06.2005
a właśnie wlazłem tu, żeby dowiedzieć się coś na temat nowego CFW. ważne, że jest jakieś nowe
iHAS124@PX-L890SA
Stary 24.08.2015, 15:25   #1384
ethar
Herbaciarz^^
Data rejestracji: 19.09.2008
ethar zaczyna zdobywać reputację <1 - 49 pkt>
Tylko "smaczki":
FEATURES FOR REBUG REX/D-REX EDITION
FEATURE – Dual LV2 Kernels CEX/DEX
(Swap your EID0/LV2 kernel using Rebug Toolbox in seconds)
FEATURE – ALL Retail functions available in CEX mode
(No need to install different firmware)
FEATURE – ALL Debug functions available in DEX mode
FEATURE – FULL ProDG Connectivity in DEX mode
(Full Support on both Normal mode and Cobra mode)
FEATURE – QA Token compatibility
FEATURE – OtherOS++ support enabled
(Use Rebug Toolbox to Boot OtherOS with different LV1 patches)
FEATURE – Package Manager
(Replacement for the standard ‘Install Package Files’ option)
INCLUDED – Rebug Toolbox 02.02.05
(Install included Rebug Toolbox or higher for full compatibility)
PATCHED – Appldr: LV2 memory hash check is disabled
(Memory protection on LV2 is disabled in higher level)
PATCHED – LV1: Disable System Integrity Check
(Safe to use with mismatched COREOS/SYSCON versions or if PS3 is not QA enabled)
PATCHED – LV1: Undocumented function 114
(Allow mapping of protected memory)
PATCHED – LV1: Skip all ACL Checks
(Needed to allow booting of OtherOS)
PATCHED – LV1: Peek and Poke support
(Unused LV1 call 182 and 183)
PATCHED – LV2: Peek and Poke support
(LV2 Syscall 6 and 7)
PATCHED – LV2: Peek and Poke support for LV1
(LV2 Syscall 8 and 9)
PATCHED – LV2: LV1 CALL System call
(LV2 Syscall 10)
PATCHED – Recovery: Prevent accidental OFW update while on Recovery mode
PATCHED – VSH: Allow Unsigned act.dat and *.rif files
PATCHED – VSH: Disable Unlinking/Deleting of act.dat
PATCHED – VSH: Disable NEW PSP DRM Check on Unsigned PSP packages added on OFW 4.75
PATCHED – VSH: Disable Epilepsy Warning for Faster Boot-Up Speed
FUN FEATURE – Fake Save Data Owner
(Use Game Saves from ANY Owner)
FUN FEATURE – In Game Screenshot
(Allows taking screenshots in Game)
FUN FEATURE – Enhanced Remote Play
(This unlocks the limitation of working apps/games for remote play)
FUN FEATURE – Lock/Unlock Trophies (Offline only)
FEATURE – Cinavia protection fully disabled
(Supports optical media/bd iso, AACS must be decrypted)
FEATURE – Cobra 7.1
(Disabled by default, Toolbox required to enable)
FEATURE – 1.42.04 MOD REBUG EDITION
(Full Webman intergration supports both CEX/DEX 4.75)
https://www.facebook.com/CzytelnikPlakalJakKupowal - moja osobista misja.
https://www.facebook.com/ZakonBrowardynow - wytłumaczenie mojego uwielbienia do piwa.
kubacki.deviantart.com
ethar jest offline   Odpowiedz cytując ten post
Stary 24.08.2015, 15:28   #1385
ethar
Herbaciarz^^
Właśnie ktoś może potwierdzić jedną rzecz, siedze na Habib 4.70 i mam 2 problemy - nie frustrujące ale jednak:
1) Odpalanie PS2ISO nie wykrywa pada bezprzewodowego (trzeba grać na kablu, bezsensu dla mnie bo pad od PS2 jest już ściorchany - przyciski nie wchodzą jak powinny, a od PS3 mam bardzo krótki kabel który w sumie służy tylko do ładowania).
2) Po wyjściu do Systemu PS3 - po graniu w grę z PS2, nonstop automatycznie mi ją odpala w kółko. Jedyny sposób to rozłączenie konsoli od prądu.
Czy ktoś miał podobne problemy na Habibie? Czy ten Rebug ma podobnie?
Ostatnio zmieniany przez ethar : 24.08.2015 o godz. 15:30
Stary 24.08.2015, 16:11   #1386
Trilu
Avatar użytkownika Trilu
Data rejestracji: 15.02.2008
Trilu jak się przyłoży ma szansę zostać specem <150 - 249 pkt>Trilu jak się przyłoży ma szansę zostać specem <150 - 249 pkt>
Na 4.70 były takie cyrki ,gry z ps2 na Rebugu ładuje się PS2 ISO / Classic Launcher'em ,wtedy działa bezprzewodowo pad .
Trilu jest offline   Odpowiedz cytując ten post
Stary 24.08.2015, 16:44   #1387
@ethar
Ale chodzi o zmiany od ostatniej wersji, nie o ficzery.
Stary 24.08.2015, 18:23   #1388
ethar
Herbaciarz^^
@Berion
Obawiam się, że nie wiele się zmieniło od 4.70 poza tym że jest postawiony na 4.75... I tak z połowy funkcji pewnie nie skorzystam do końca życia mojej konsoli. Na dniach sobie zaktualizuje
Stary 24.08.2015, 18:46   #1389
To tak jak ja. Ale przynajmniej można być już spokojnym z tym numerkiem o wszystkie gry i patche.
Stary 24.08.2015, 18:55   #1390
ethar
Herbaciarz^^
Dokładnie szczególnie, że już zaraz Phantom Pain - chociaż zastanawiam się bardziej nad zakupem wersji na PC - mam kompa który to uciągnie, możliwość experymentalnego sterowania myszką (albo pada zawsze mogę podłączyć), lepsza grafika i tańszy.
(Dzisiaj sprawdzałem ceny i mniej więcej PC - 179 PS3 -199 PS4 -229)
W dodatku mody - ktoś walnął fajnego moda do GZ w postaci FPP - ale raczej ciekawostka. Chociaż mam nadzieję że kiedyś ktoś się znajdzie kto będzie chciał przenieść np MGS1 albo MG i MG2 na silnik V. Co nie jest takie nierealne jak ostatnio wyczytałem że ktoś przenosi Morrowinda na silnik Skyrima
BTW Czy w oficjalnym changelogu OFW 4.75 jest "Poprawa stabilności systemu" ?
Ostatnio zmieniany przez ethar : 24.08.2015 o godz. 19:02
Stary 24.08.2015, 21:14   #1391
Na PC. ;]
Stary 24.08.2015, 22:38   #1392
ethar
Herbaciarz^^
Na PC. ;]
To miała być ironia ? Bo szczerze nie wiem, znam takich którzy mówią "Hideo się sprzedał jedyny prawdziwy MGS może być tylko na playstation - to jedyna słuszna wersja." Argumenty typu że pierwsze MG były na nesa, a pierwszy MGS także na PC jakoś jakby ich nie słyszeli
Ogólnie bym polował na jakiś pakiet MGS: GZ + PP, albo nawet kolekcjonerke (chociaż z tego co widziałem takowej na PC nie ma - tylko XBO oraz PS4).
Stary 25.08.2015, 10:09   #1393
misiozol
Avatar użytkownika misiozol
Data rejestracji: 26.10.2008
Jak cenisz naklejke na konsoli i pudelko w kolory MGS to bierz konsole , inaczej tylko wersje z PC nie ma sensu brac juz konsoli (sam nie wieze ze to napisalem) PC mozna zmapowac pod kontroler na ps3 i to bezprzewodowo
Stary 25.08.2015, 11:12   #1394
ethar
Herbaciarz^^
Właśnie ta konsola z MGS'em średnio mnie się podoba szczerze mówiąc - już bardziej podchodzi mi ta z limitowanej Edycji Uncharted na PS4. Póki co budżet mały, poczekam aż wejdą jakieś pierwsze slimy PS4 a gry używane potanieją. To mój przepis na przyszłość mojego konsolowego grania
Stary 07.09.2015, 18:56   #1395
Trilu
Wyszedł Rebug 4.75.3 ,dodany spoofer 4.76 w Rebug Toolbox .
MGS wygląda dobrze na ps3 ,ogólnie gra bardzo dobra i warta wydanego grosza .Wciąga jak Uncharted ,a to dobry omen
PS3 "Jailbreak" Berion Hardware 1996 13.02.2014 11:19
jak zupgrade'owac psp slim & lite do Custom Firmware 3.90 M33 Caleb_88 Homebrew 1 08.02.2008 23:27
Wgrywanie firmware! Pytanie!! JackMan Flashowanie/Firmware/Podkręcanie napędów optycznych 1 05.03.2006 18:42
Firmware do napędu DVD LG. 9down Flashowanie/Firmware/Podkręcanie napędów optycznych 1 10.07.2005 12:41
Co wiecie o biosie 1.04 do LG GCE-8320B ? Kusiu Napędy optyczne CD 8 12.05.2002 11:11
Wszystkie czasy w strefie CET. Aktualna godzina: 16:08.
