-   -   LG BH16NS55 problemy z nagrywaniem (https://forum.cdrinfo.pl/f107/lg-bh16ns55-problemy-nagrywaniem-96906/)
gochad0303 31.07.2018 10:34
W ImgBurn to samo.
Wina płyt to nie jest na bank. Mam jaką starą nagrywarkę LG i się wypala. Do tego próbowałam 3 różnych marek nośników: HP, Maxell i Verbatim.
LOG:
I 10:32:56 ImgBurn Version 2.5.8.0 started!
I 10:32:56 Microsoft Windows 8 Core x64 Edition (6.2, Build 9200)
I 10:32:56 Total Physical Memory: 7 285 764 KiB - Available: 4 447 244 KiB
I 10:32:56 Initialising SPTI...
I 10:32:56 Searching for SCSI / ATAPI devices...
I 10:32:57 -> Drive 1 - Info: HL-DT-ST BD-RE BH16NS40 1.03-A0 (D:) (ATA)
I 10:32:57 -> Drive 2 - Info: ASUS BW-16D1HT 3.03 (E:) (ATA)
I 10:32:57 Found 2 BD-RE XLs!
I 10:35:50 Operation Started!
I 10:35:50 Source File: F:\obrazy dvd (iso)\piotrus.iso
I 10:35:50 Source File Sectors: 2 119 840 (MODE1/2048)
I 10:35:50 Source File Size: 4 341 432 320 bytes
I 10:35:50 Source File Volume Identifier: piotrus
I 10:35:50 Source File Volume Set Identifier: 4CF9ABB9________piotrus
I 10:35:50 Source File Implementation Identifier: VsoSoftware
I 10:35:50 Source File File System(s): ISO9660; UDF (1.02)
I 10:35:51 Destination Device: [1:1:0] ASUS BW-16D1HT 3.03 (E:) (ATA)
I 10:35:51 Destination Media Type: DVD+R (Disc ID: RITEK-F16-01)
I 10:35:51 Destination Media Supported Write Speeds: 8x; 16x
I 10:35:51 Destination Media Sectors: 2 295 104
I 10:35:51 Write Mode: DVD
I 10:35:51 Write Type: DAO
I 10:35:51 Write Speed: 8x
I 10:35:51 DVD+R Reserve Track: No
I 10:35:51 Link Size: Auto
I 10:35:51 Lock Volume: Yes
I 10:35:51 Test Mode: No
I 10:35:51 OPC: No
I 10:35:51 BURN-Proof: Enabled
I 10:35:51 Write Speed Successfully Set! - Effective: 11 080 KB/s (8x)
I 10:35:52 Filling Buffer... (80 MiB)
I 10:35:52 Writing LeadIn...
I 10:36:04 Writing Session 1 of 1... (1 Track, LBA: 0 - 2119839)
I 10:36:04 Writing Track 1 of 1... (MODE1/2048, LBA: 0 - 2119839)
W 10:37:52 Failed to Write Sectors 17664 - 17695 - Reason: Write Error
W 10:37:52 Retrying (1 of 20)...
W 10:37:52 Retry Failed - Reason: Invalid Address For Write
W 10:37:52 Retrying (2 of 20)...
W 10:37:52 Retrying (3 of 20)...
W 10:37:52 Retrying (4 of 20)...
W 10:37:52 Retrying (5 of 20)...
W 10:37:52 Retrying (6 of 20)...
W 10:37:52 Retrying (7 of 20)...
W 10:37:52 Retrying (8 of 20)...
W 10:37:52 Retrying (9 of 20)...
W 10:37:52 Retrying (10 of 20)...
W 10:37:52 Retrying (11 of 20)...
W 10:37:52 Retrying (12 of 20)...
W 10:37:52 Retrying (13 of 20)...
W 10:37:52 Retrying (14 of 20)...
W 10:37:52 Retrying (15 of 20)...
W 10:37:52 Retrying (16 of 20)...
W 10:37:52 Retrying (17 of 20)...
W 10:37:52 Retrying (18 of 20)...
W 10:37:53 Retrying (19 of 20)...
W 10:37:53 Retry Failed - Reason: Invalid Address For Write
W 10:37:53 Retrying (20 of 20)...
czary2mary 31.07.2018 12:27
Napisany przez gochad0303 (Post 1408515)
W ImgBurn to samo.
W Log błędy zapisu pod koniec operacji .. może być to problem chipset AMD A68H \kontroler SATA AMD \ sterowniki SATA AMD ...
Jaką dokładnie masz wersje Windows 10 ?
Musisz znaleźć sterowniki chipset \ SATA do tej płyty głównej i systemu ..
gochad0303 01.08.2018 09:06
Win 10 home wersja 1803
Z chipsetami sobie nie daję rady, ponieważ nie chcą się zainstalować z tej strony, którą mi podaliście wcześniej.
Chyba, że ja robię coś źle.
Instalkę do SATA uruchamiam poprzez plik rcraid.msi (żadnych exe tam nie mam po ściągnięciu)
Po tym wyskakuje mi błąd, że ta aplikacja nie jest kompatybilna z moim windowsem (a ściągam oczywiście pliki do win10 bo taki posiadam).
czary2mary 01.08.2018 11:16
Napisany przez gochad0303 (Post 1408554)
Pobierz jakiś program który pokaże dokładnie wersje Windows oraz dokładny hardware komputera , typ płyty głównej .. bo inaczej czort go wie do czego szukać sterowników ....
gochad0303 01.08.2018 11:19
a Mogę jaśniej? :)
co mam ściągnąć i jak zainstalować?
czary2mary 01.08.2018 13:00
Napisany przez gochad0303 (Post 1408559)
a Mogę jaśniej? :)
Np: AIDA32-Enterprise System Information
https://www.instalki.pl/programy/dow...formation.html
gochad0303 01.08.2018 13:22
ID płyty głównej: 63-0100-000001-00101111-041312-Chipset$F2A68HM-DS2_BIOS DATE: 12/24/15 16:28:30 VER: 04.06.05
Nazwa płyty głównej Gigabyte GA-F2A68HM-DS2
Nazwa systemu operacyjnego Microsoft Windows 10
Wersja systemu operacyjnego 10.0.17134.1
To jest to, co podawałam wcześniej.
Naprawdę mi to już spokoju nie daje. :(
stara nagrywarka działa jak należy, a dwie nowe Blu/DVD się tak zachowują.
czary2mary 01.08.2018 13:43
Napisany przez gochad0303 (Post 1408565)
Każdy sprzęt ma inny kontroler Sata , sterowniki itp itd ...nie można porównywać że jeden działa to wszystkie będą działać ...nie ma tak ..
Do chipsetu do W10 32\64 są sterowniki dla Gigabyte GA-F2A68HM-DS2
http://download.gigabyte.eu/FileList...plus_win10.zip
Jeżeli nie da się zainstalować to tylko pomoc techniczna Gigabyte może coś podpowiedzieć ,pomóc ... na pewno nie jest to normalne :sciana:k***a
https://www.gigabyte.com/Support/Technical-Support
Wszystkie czasy w strefie CET. Aktualna godzina: 23:33.
