Pioneer BDR-PR1EPDV 2013r
| #ads | |
PlexDisc CD-R Printable Inkjet Matt CMC Magnetic 97m26s66f
Pioneer BDR-PR1EPDV fw.1.01 ImgBurn 2.5.8.0 x16 ![]() ![]() ![]() ![]() ![]() ![]() ![]()
PlexDisc CD-R Printable Liquid Defense Plus Ritek 97m15s17f
Pioneer BDR-PR1EPDV fw.1.01 ImgBurn 2.5.8.0 x4 ![]() ![]() ![]() ![]() ![]() ![]() ![]()
MediaRange CD-R x52 Plasmon 97m27s18f
Pioneer BDR-PR1EPDV fw.1.01 NERO 2017 x10 Jestem w lekkim szoku co Pionek +Nero zrobiły z tym nośnikiem ![]() ![]() ![]() Znaczek PR1 nie od parady ... ![]() log : Kod:
Windows 8 6.2 AMD64 Wow64Process Nero Version: 18.0.15.0 Internal Version: 18,0,15,0 Recorder : <PIONEER BDR-PR1EPDVPP100> FW version: 1.01 - HA 1 TA 1 - 18.0.15.0 Device bus : <> HA 1 Host system bus : <USB 2> Drive buffer : 4000kB Bus Type : via Inquiry data Connected to MMC as unknown drive with class-nr : 1 Drive is autodetected - recorder class: Std. MMC recorder CD/DVD-ROM : <HL-DT-ST DVDRAM GT30N > FW version: 1.01 - HA 1 TA 0 - 18.0.15.0 Device bus : <> HA 1 Host system bus : <IDE> === Scsi-Device-Map === DiskPeripheral : KINGSTON SV300S37A120G iaStor Port 0 ID 0 DMA: On DiskPeripheral : WDC WD7500BPKX-75HPJT0 iaStor Port 0 ID 1 DMA: Off CdRomPeripheral : HL-DT-ST DVDRAM GT30N iaStor Port 0 ID 2 DMA: Off === CDRom-Device-Map === HL-DT-ST DVDRAM GT30N D: CdRom0 PIONEER BDR-PR1EPDVPP100 F: CdRom1 ======================= AutoRun : 0 Excluded drive IDs: WriteBufferSize: 83886080 (0) Byte BUFE : 0 Physical memory : 4090MB (4189108kB) Free physical memory: 1849MB (1893848kB) Memory in use : 54 % Uncached PFiles: 0x0 Global Bus Type: default (0) Check supported media : Disabled (0) 1.4.2017 Obraz dysku 09:09:41 #1 Text 0 File SCSIPTICommands.cpp, Line 617 LockMCN - completed sucessfully for IOCTL_STORAGE_MCN_CONTROL 09:09:41 #2 Text 0 File Burncd.cpp, Line 3723 PIONEER BDR-PR1EPDVPP100 Włączono System ochrony zapisu 09:09:41 #3 PHASE 214 File dlgbrnst.cpp, Line 2108 Generation of disc structures started 09:09:41 #4 IMAGEGEN -10 File ImageGen.cpp, Line 400 Image was written as DAO. DAOI: MediaCatalogNumber = ' ' TocType = 0x00 Finalized = 1 First/Last Track = 1 / 14 1: ISRC = '' Blocksize = 2352 TrackMode = 'TRM_AUDIO_NOPRE' TrackConfig = 0x00 First/Last Index = 0 / 1 Index0FilePos = 0, Index1FilePos = 352800, NextTrackFilePos = 32732784 2: ISRC = '' Blocksize = 2352 TrackMode = 'TRM_AUDIO_NOPRE' TrackConfig = 0x00 First/Last Index = 0 / 1 Index0FilePos = 32732784, Index1FilePos = 33085584, NextTrackFilePos = 59719632 3: ISRC = '' Blocksize = 2352 TrackMode = 'TRM_AUDIO_NOPRE' TrackConfig = 0x00 First/Last Index = 0 / 1 Index0FilePos = 59719632, Index1FilePos = 60072432, NextTrackFilePos = 97097616 4: ISRC = '' Blocksize = 2352 TrackMode = 'TRM_AUDIO_NOPRE' TrackConfig = 0x00 First/Last Index = 0 / 1 Index0FilePos = 97097616, Index1FilePos = 97450416, NextTrackFilePos = 130493664 5: ISRC = '' Blocksize = 2352 TrackMode = 'TRM_AUDIO_NOPRE' TrackConfig = 0x00 First/Last Index = 0 / 1 Index0FilePos = 130493664, Index1FilePos = 130846464, NextTrackFilePos = 185575152 6: ISRC = '' Blocksize = 2352 TrackMode = 'TRM_AUDIO_NOPRE' TrackConfig = 0x00 First/Last Index = 0 / 1 Index0FilePos = 185575152, Index1FilePos = 185927952, NextTrackFilePos = 231422688 7: ISRC = '' Blocksize = 2352 TrackMode = 'TRM_AUDIO_NOPRE' TrackConfig = 0x00 First/Last Index = 0 / 1 Index0FilePos = 231422688, Index1FilePos = 231775488, NextTrackFilePos = 280000896 8: ISRC = '' Blocksize = 2352 TrackMode = 'TRM_AUDIO_NOPRE' TrackConfig = 0x00 First/Last Index = 0 / 1 Index0FilePos = 280000896, Index1FilePos = 280353696, NextTrackFilePos = 325566192 9: ISRC = '' Blocksize = 2352 TrackMode = 'TRM_AUDIO_NOPRE' TrackConfig = 0x00 First/Last Index = 0 / 1 Index0FilePos = 325566192, Index1FilePos = 325918992, NextTrackFilePos = 369343968 10: ISRC = '' Blocksize = 2352 TrackMode = 'TRM_AUDIO_NOPRE' TrackConfig = 0x00 First/Last Index = 0 / 1 Index0FilePos = 369343968, Index1FilePos = 369696768, NextTrackFilePos = 431728416 11: ISRC = '' Blocksize = 2352 TrackMode = 'TRM_AUDIO_NOPRE' TrackConfig = 0x00 First/Last Index = 0 / 1 Index0FilePos = 431728416, Index1FilePos = 432081216, NextTrackFilePos = 503476176 12: ISRC = '' Blocksize = 2352 TrackMode = 'TRM_AUDIO_NOPRE' TrackConfig = 0x00 First/Last Index = 0 / 1 Index0FilePos = 503476176, Index1FilePos = 503828976, NextTrackFilePos = 615934704 13: ISRC = '' Blocksize = 2352 TrackMode = 'TRM_AUDIO_NOPRE' TrackConfig = 0x00 First/Last Index = 0 / 1 Index0FilePos = 615934704, Index1FilePos = 616287504, NextTrackFilePos = 678074544 14: ISRC = '' Blocksize = 2352 TrackMode = 'TRM_AUDIO_NOPRE' TrackConfig = 0x00 First/Last Index = 0 / 1 Index0FilePos = 678074544, Index1FilePos = 678427344, NextTrackFilePos = 814144800 CUES: 0: Ctrl=0x01 Trk= 0 (0x00) Index=00 Start=954437:08.46 ( -150) RecDep=0x00 1: Ctrl=0x00 Trk= 0 (0x00) Index=138 Start=123105:47.39 (553976064) RecDep=0x24 [open track] 2: Ctrl=0x21 Trk= 10 (0x10) Index=00 Start=34:51.59 ( 156884) RecDep=0x00 MTYP: Mediumtype = CD (old format) (0x1) Image file name: <C:\Users\czary2mary\Desktop\Image.nrg> 09:09:42 #5 PHASE 215 File dlgbrnst.cpp, Line 2108 Generation of disc structures completed 09:09:42 #6 Text 0 File Burncd.cpp, Line 4086 Turn on Disc-At-Once, using CD-R/RW media 09:09:44 #7 Text 0 File DlgWaitCD.cpp, Line 335 [F: BDR-PR1EPDVPP100] Last possible write address on media: 359846 Last address to be written: 345999 09:09:44 #8 Text 0 File DlgWaitCD.cpp, Line 347 [F: BDR-PR1EPDVPP100] Write in overburning mode: NO (enabled: CD) 09:09:45 #9 Text 0 File DlgWaitCD.cpp, Line 3127 Recorder: PIONEER BDR-PR1EPDVPP100; CDR code: 00 97 27 18; OSJ entry from: Plasmon Data systems Ltd. ATIP Data: Special Info [hex] 1: D0 00 A0, 2: 61 1B 12 (LI 97:27.18), 3: 4F 3B 4A (LO 79:59.74) Additional Info [hex] 1: FF FF FF (invalid), 2: FF FF FF (invalid), 3: FF FF FF (invalid) 09:09:45 #10 Text 0 File DlgWaitCD.cpp, Line 537 [F: BDR-PR1EPDVPP100] >>> Protocol of DlgWaitCD activities: <<< ========================================= 09:09:45 #11 Text 0 File ThreadedTransferInterface.cpp, Line 879 Setup items (after recorder preparation) 0: TRM_AUDIO_NOPRE (1 - Audio) 2 indices, index0 (150) provided original disc pos #0 + 13767 (13767) = #13767/3:3.42 not relocatable, disc pos for caching/writing not required/not required -> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 13767 blocks [F: PIONEER BDR-PR1EPDVPP100] 1: TRM_AUDIO_NOPRE (2 - Audio) 2 indices, index0 (150) provided original disc pos #13917 + 11324 (11324) = #25241/5:36.41 not relocatable, disc pos for caching/writing not required/not required -> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 11324 blocks [F: PIONEER BDR-PR1EPDVPP100] 2: TRM_AUDIO_NOPRE (3 - Audio) 2 indices, index0 (150) provided original disc pos #25391 + 15742 (15742) = #41133/9:8.33 not relocatable, disc pos for caching/writing not required/not required -> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 15742 blocks [F: PIONEER BDR-PR1EPDVPP100] 3: TRM_AUDIO_NOPRE (4 - Audio) 2 indices, index0 (150) provided original disc pos #41283 + 14049 (14049) = #55332/12:17.57 not relocatable, disc pos for caching/writing not required/not required -> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 14049 blocks [F: PIONEER BDR-PR1EPDVPP100] 4: TRM_AUDIO_NOPRE (5 - Audio) 2 indices, index0 (150) provided original disc pos #55482 + 23269 (23269) = #78751/17:30.1 not relocatable, disc pos for caching/writing not required/not required -> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 23269 blocks [F: PIONEER BDR-PR1EPDVPP100] 5: TRM_AUDIO_NOPRE (6 - Audio) 2 indices, index0 (150) provided original disc pos #78901 + 19343 (19343) = #98244/21:49.69 not relocatable, disc pos for caching/writing not required/not required -> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 19343 blocks [F: PIONEER BDR-PR1EPDVPP100] 6: TRM_AUDIO_NOPRE (7 - Audio) 2 indices, index0 (150) provided original disc pos #98394 + 20504 (20504) = #118898/26:25.23 not relocatable, disc pos for caching/writing not required/not required -> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 20504 blocks [F: PIONEER BDR-PR1EPDVPP100] 7: TRM_AUDIO_NOPRE (8 - Audio) 2 indices, index0 (150) provided original disc pos #119048 + 19223 (19223) = #138271/30:43.46 not relocatable, disc pos for caching/writing not required/not required -> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 19223 blocks [F: PIONEER BDR-PR1EPDVPP100] 8: TRM_AUDIO_NOPRE (9 - Audio) 2 indices, index0 (150) provided original disc pos #138421 + 18463 (18463) = #156884/34:51.59 not relocatable, disc pos for caching/writing not required/not required -> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 18463 blocks [F: PIONEER BDR-PR1EPDVPP100] 9: TRM_AUDIO_NOPRE (10 - Audio) 2 indices, index0 (150) provided original disc pos #157034 + 26374 (26374) = #183408/40:45.33 not relocatable, disc pos for caching/writing not required/not required -> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 26374 blocks [F: PIONEER BDR-PR1EPDVPP100] 10: TRM_AUDIO_NOPRE (11 - Audio) 2 indices, index0 (150) provided original disc pos #183558 + 30355 (30355) = #213913/47:32.13 not relocatable, disc pos for caching/writing not required/not required -> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 30355 blocks [F: PIONEER BDR-PR1EPDVPP100] 11: TRM_AUDIO_NOPRE (12 - Audio) 2 indices, index0 (150) provided original disc pos #214063 + 47664 (47664) = #261727/58:9.52 not relocatable, disc pos for caching/writing not required/not required -> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 47664 blocks [F: PIONEER BDR-PR1EPDVPP100] 12: TRM_AUDIO_NOPRE (13 - Audio) 2 indices, index0 (150) provided original disc pos #261877 + 26270 (26270) = #288147/64:1.72 not relocatable, disc pos for caching/writing not required/not required -> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 26270 blocks [F: PIONEER BDR-PR1EPDVPP100] 13: TRM_AUDIO_NOPRE (14 - Audio) 2 indices, index0 (150) provided original disc pos #288297 + 57703 (57703) = #346000/76:53.25 not relocatable, disc pos for caching/writing not required/not required -> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 57703 blocks [F: PIONEER BDR-PR1EPDVPP100] -------------------------------------------------------------- 09:09:45 #12 Text 0 File ThreadedTransferInterface.cpp, Line 1095 Prepare [F: PIONEER BDR-PR1EPDVPP100] for write in CUE-sheet-DAO DAO infos: ========== MCN: " " TOCType: 0x00; Session Closed, disc fixated Tracks 1 to 14: Idx 0 Idx 1 Next Trk 1: TRM_AUDIO_NOPRE, 2352/0x00, FilePos 0 352800 32732784, ISRC "" 2: TRM_AUDIO_NOPRE, 2352/0x00, FilePos 32732784 33085584 59719632, ISRC "" 3: TRM_AUDIO_NOPRE, 2352/0x00, FilePos 59719632 60072432 97097616, ISRC "" 4: TRM_AUDIO_NOPRE, 2352/0x00, FilePos 97097616 97450416 130493664, ISRC "" 5: TRM_AUDIO_NOPRE, 2352/0x00, FilePos 130493664 130846464 185575152, ISRC "" 6: TRM_AUDIO_NOPRE, 2352/0x00, FilePos 185575152 185927952 231422688, ISRC "" 7: TRM_AUDIO_NOPRE, 2352/0x00, FilePos 231422688 231775488 280000896, ISRC "" 8: TRM_AUDIO_NOPRE, 2352/0x00, FilePos 280000896 280353696 325566192, ISRC "" 9: TRM_AUDIO_NOPRE, 2352/0x00, FilePos 325566192 325918992 369343968, ISRC "" 10: TRM_AUDIO_NOPRE, 2352/0x00, FilePos 369343968 369696768 431728416, ISRC "" 11: TRM_AUDIO_NOPRE, 2352/0x00, FilePos 431728416 432081216 503476176, ISRC "" 12: TRM_AUDIO_NOPRE, 2352/0x00, FilePos 503476176 503828976 615934704, ISRC "" 13: TRM_AUDIO_NOPRE, 2352/0x00, FilePos 615934704 616287504 678074544, ISRC "" 14: TRM_AUDIO_NOPRE, 2352/0x00, FilePos 678074544 678427344 814144800, ISRC "" DAO layout: =========== ___Start_|____Track_|_Idx_|_CtrlAdr_|_____Size_|______NWA_|_RecDep__________ -150 | lead-in | 0 | 0x01 | 0 | 0 | 0x00 -150 | 1 | 0 | 0x01 | 0 | 0 | 0x00 0 | 1 | 1 | 0x01 | 13767 | 0 | 0x00 13767 | 2 | 0 | 0x01 | 0 | 0 | 0x00 13917 | 2 | 1 | 0x01 | 11324 | 13917 | 0x00 25241 | 3 | 0 | 0x01 | 0 | 0 | 0x00 25391 | 3 | 1 | 0x01 | 15742 | 25391 | 0x00 41133 | 4 | 0 | 0x01 | 0 | 0 | 0x00 41283 | 4 | 1 | 0x01 | 14049 | 41283 | 0x00 55332 | 5 | 0 | 0x01 | 0 | 0 | 0x00 55482 | 5 | 1 | 0x01 | 23269 | 55482 | 0x00 78751 | 6 | 0 | 0x01 | 0 | 0 | 0x00 78901 | 6 | 1 | 0x01 | 19343 | 78901 | 0x00 98244 | 7 | 0 | 0x01 | 0 | 0 | 0x00 98394 | 7 | 1 | 0x01 | 20504 | 98394 | 0x00 118898 | 8 | 0 | 0x01 | 0 | 0 | 0x00 119048 | 8 | 1 | 0x01 | 19223 | 119048 | 0x00 138271 | 9 | 0 | 0x01 | 0 | 0 | 0x00 138421 | 9 | 1 | 0x01 | 18463 | 138421 | 0x00 156884 | 10 | 0 | 0x01 | 0 | 0 | 0x00 157034 | 10 | 1 | 0x01 | 26374 | 157034 | 0x00 183408 | 11 | 0 | 0x01 | 0 | 0 | 0x00 183558 | 11 | 1 | 0x01 | 30355 | 183558 | 0x00 213913 | 12 | 0 | 0x01 | 0 | 0 | 0x00 214063 | 12 | 1 | 0x01 | 47664 | 214063 | 0x00 261727 | 13 | 0 | 0x01 | 0 | 0 | 0x00 261877 | 13 | 1 | 0x01 | 26270 | 261877 | 0x00 288147 | 14 | 0 | 0x01 | 0 | 0 | 0x00 288297 | 14 | 1 | 0x01 | 57703 | 288297 | 0x00 346000 | lead-out | 1 | 0x01 | 0 | 0 | 0x00 MediaType: CD-R 09:09:45 #13 Text 0 File SCSIPTICommands.cpp, Line 404 SPTILockVolume - completed successfully for FSCTL_LOCK_VOLUME 09:09:45 #14 Text 0 File Burncd.cpp, Line 4984 Caching options: cache CDRom or Network-Yes, small files-No (<64KB) 09:09:45 #15 PHASE 24 File dlgbrnst.cpp, Line 2108 Caching of files started 09:09:45 #16 Text 0 File Burncd.cpp, Line 5106 Cache writing successful. 09:09:45 #17 PHASE 25 File dlgbrnst.cpp, Line 2108 Caching of files completed 09:09:45 #18 PHASE 36 File dlgbrnst.cpp, Line 2108 Burn process started at 10x (1*500 KB/s) 09:09:46 #19 Text 0 File ThreadedTransferInterface.cpp, Line 2926 Verifying disc position of item 0 (not relocatable, no disc pos, no patch infos, orig at #0): write at #0 09:09:46 #20 Text 0 File ThreadedTransferInterface.cpp, Line 2926 Verifying disc position of item 1 (not relocatable, no disc pos, no patch infos, orig at #13917): write at #13917 09:09:46 #21 Text 0 File ThreadedTransferInterface.cpp, Line 2926 Verifying disc position of item 2 (not relocatable, no disc pos, no patch infos, orig at #25391): write at #25391 09:09:46 #22 Text 0 File ThreadedTransferInterface.cpp, Line 2926 Verifying disc position of item 3 (not relocatable, no disc pos, no patch infos, orig at #41283): write at #41283 09:09:46 #23 Text 0 File ThreadedTransferInterface.cpp, Line 2926 Verifying disc position of item 4 (not relocatable, no disc pos, no patch infos, orig at #55482): write at #55482 09:09:46 #24 Text 0 File ThreadedTransferInterface.cpp, Line 2926 Verifying disc position of item 5 (not relocatable, no disc pos, no patch infos, orig at #78901): write at #78901 09:09:46 #25 Text 0 File ThreadedTransferInterface.cpp, Line 2926 Verifying disc position of item 6 (not relocatable, no disc pos, no patch infos, orig at #98394): write at #98394 09:09:46 #26 Text 0 File ThreadedTransferInterface.cpp, Line 2926 Verifying disc position of item 7 (not relocatable, no disc pos, no patch infos, orig at #119048): write at #119048 09:09:46 #27 Text 0 File ThreadedTransferInterface.cpp, Line 2926 Verifying disc position of item 8 (not relocatable, no disc pos, no patch infos, orig at #138421): write at #138421 09:09:46 #28 Text 0 File ThreadedTransferInterface.cpp, Line 2926 Verifying disc position of item 9 (not relocatable, no disc pos, no patch infos, orig at #157034): write at #157034 09:09:46 #29 Text 0 File ThreadedTransferInterface.cpp, Line 2926 Verifying disc position of item 10 (not relocatable, no disc pos, no patch infos, orig at #183558): write at #183558 09:09:46 #30 Text 0 File ThreadedTransferInterface.cpp, Line 2926 Verifying disc position of item 11 (not relocatable, no disc pos, no patch infos, orig at #214063): write at #214063 09:09:46 #31 Text 0 File ThreadedTransferInterface.cpp, Line 2926 Verifying disc position of item 12 (not relocatable, no disc pos, no patch infos, orig at #261877): write at #261877 09:09:46 #32 Text 0 File ThreadedTransferInterface.cpp, Line 2926 Verifying disc position of item 13 (not relocatable, no disc pos, no patch infos, orig at #288297): write at #288297 09:09:46 #33 Text 0 File Mmc.cpp, Line 17655 StartDAO : CD-Text - Off 09:09:46 #34 Text 0 File Mmc.cpp, Line 21661 Set BUFE: Buffer underrun protection -> ON 09:09:46 #35 Text 0 File Mmc.cpp, Line 17883 CueData, Len=240 01 00 00 01 00 00 00 00 01 01 00 00 00 00 00 00 01 01 01 00 00 00 02 00 01 02 00 00 00 03 05 2a 01 02 01 00 00 03 07 2a 01 03 00 00 00 05 26 29 01 03 01 00 00 05 28 29 01 04 00 00 00 09 0a 21 01 04 01 00 00 09 0c 21 01 05 00 00 00 0c 13 39 01 05 01 00 00 0c 15 39 01 06 00 00 00 11 20 01 01 06 01 00 00 11 22 01 01 07 00 00 00 15 33 45 01 07 01 00 00 15 35 45 01 08 00 00 00 1a 1b 17 01 08 01 00 00 1a 1d 17 01 09 00 00 00 1e 2d 2e 01 09 01 00 00 1e 2f 2e 01 0a 00 00 00 22 35 3b 01 0a 01 00 00 22 37 3b 01 0b 00 00 00 28 2f 21 01 0b 01 00 00 28 31 21 01 0c 00 00 00 2f 22 0d 01 0c 01 00 00 2f 24 0d 01 0d 00 00 00 3a 0b 34 01 0d 01 00 00 3a 0d 34 01 0e 00 00 00 40 03 48 01 0e 01 00 00 40 05 48 01 aa 01 01 00 4c 37 19 09:09:46 #36 Text 0 File ThreadedTransfer.cpp, Line 275 Pipe memory size 83836800 09:18:05 #37 Text 0 File WriterStatus.cpp, Line 245 <F: PIONEER BDR-PR1EPDVPP100> start writing Lead-Out at LBA 346000 (54790h), length 0 blocks 09:18:19 #38 Text 0 File DVDPlusDualLayer.cpp, Line 1464 SetDriveCaps: Set LAST LBA of layer 1 to 0 09:18:19 #39 PHASE 37 File dlgbrnst.cpp, Line 2108 Burn process completed successfully at 10x (1*500 KB/s) 09:18:19 #40 Text 0 File SCSIPTICommands.cpp, Line 454 SPTIDismountVolume - completed successfully for FSCTL_DISMOUNT_VOLUME 09:18:19 #41 Text 0 File Cdrdrv.cpp, Line 12297 DriveLocker: UnLockVolume completed 09:18:19 #42 Text 0 File SCSIPTICommands.cpp, Line 617 UnLockMCN - completed sucessfully for IOCTL_STORAGE_MCN_CONTROL ![]() ![]() ![]() ![]() ![]()
#11 |
Data rejestracji: 02.09.2016
Bardzo ładny wynik. Osobiście jeszcze nie zdarzyło mi się, aby ten model nie nagrał jakiejś płyty
#12 | |
#13 |
@czary2mary - Thanks to @wujooj I now have a BDR-PR1EPDV. Where did you find the 1.01 firmware?
#14 | |
Posted on PM. We are waiting for your tests ..
#15 |
| PureRead - Pioneer DVD\BluRay Drive | czary2mary | Audio/Stacjonarne nagrywarki i nośniki CD-R Audio | 12 | 06.10.2017 08:17 |
| Wybór nagrywarki LG BH10LS lub LITEON IHBS 112 ORAZ PIONEER BDR 205 BK | rysieksat | Napędy optyczne Blu-ray, Ultra HD Blu-ray, HD DVD | 0 | 27.05.2011 20:19 |
| Problem z wypalaniem CD na Pioneer DVDR-112D | noe | Napędy optyczne CD | 4 | 02.06.2007 17:38 |
| Nagrywarka mi zjada płyty | DriX | Napędy optyczne DVD | 22 | 20.05.2006 12:35 |
| Problem z nagrywaniem Dvd+r (pioneer 110-d) | Davidian | Napędy optyczne CD | 6 | 24.03.2006 16:26 |
