Stary 23.05.2009, 23:24   #1
kolo333
Data rejestracji: 23.05.2009
kolo333 w tym momencie nie ma Reputacji dodatnich ani ujemnych <0  pkt>
Problem z wypaleniem gry na Xbox 360...
Witam.
Mam wypalarke LG GSA-5160D na interfejs ATA. Problem polega na tym, ze nie moge na niej wypalic gry na Xboxa 360 (oczywiscie posiadam oryginal). Wypalam programem ImgBurn i podczas wypalania wyskakuje blad i plyta caly czas nadaje sie do uzytku.
Log:
I 16:43:04 ImgBurn Version 2.4.4.0 started!
I 16:43:04 Microsoft Windows XP Professional (5.1, Build 2600)
I 16:43:04 Total Physical Memory: 523*760 KB - Available: 344*288 KB
I 16:43:04 Initialising SPTI...
I 16:43:04 Searching for SCSI / ATAPI devices...
I 16:43:04 Found 1 DVD-ROM and 1 DVD***177;RW/RAM!
I 16:46:21 Operation Started!
I 16:46:21 Source File: C:\Downloads\Pro_Evolution_Soccer_2009_PAL_XBOX360-STRANGE\strange-pes2009.dvd
I 16:46:21 Source File Sectors: 3*825*924 (MODE1/2048)
I 16:46:21 Source File Size: 7*835*492*352 bytes
I 16:46:21 Source File Volume Identifier: XGD2DVD_NTSC
I 16:46:21 Source File Volume Set Identifier: 34672923
I 16:46:21 Source File Implementation Identifier: Sonic Scenarist 3.1
I 16:46:21 Source File File System(s): ISO9660; UDF (1.02)
I 16:46:21 Destination Device: [0:1:0] HL-DT-ST DVDRAM GSA-5160D A302 (F (ATA)
I 16:46:21 Destination Media Type: DVD+R DL (Disc ID: CMC MAG-D04-00) (Speeds: 4x)
I 16:46:21 Destination Media Sectors: 4*173*824
I 16:46:21 Write Mode: DVD
I 16:46:21 Write Type: DAO
I 16:46:21 Write Speed: 2,4x
I 16:46:21 Link Size: Auto
I 16:46:21 Lock Volume: Yes
I 16:46:21 Test Mode: No
I 16:46:21 OPC: No
I 16:46:21 BURN-Proof: Enabled
I 16:46:22 Book Type Setting: DVD-ROM
I 16:46:22 Optimal L0 Data Zone Capacity: 1*913*760
I 16:46:22 Optimal L0 Data Zone Method: Copied From Original Disc
E 16:48:21 Set L0 Data Zone Capacity Failed! - Reason: Write Error
E 16:48:21 Operation Failed! - Duration: 00:01:59
I 16:48:21 Average Write Rate: N/A - Maximum Write Rate: N/A
I 16:56:13 Close Request Acknowledged
I 16:56:13 Closing Down...
I 16:56:13 Shutting down SPTI...
I 16:56:13 ImgBurn closed!
Poprawnie powinno byc:
Set L0 Data Zone Capacity Succeeded!
Czy wiecie moze w czym tkwi problem? Nosnik - Platinum.
Z gory dzieki za odpowiedzi.
Pozdrawiam.
kolo333 jest offline   Odpowiedz cytując ten post
Stary 23.05.2009, 23:31   #2
[...] Czy wiecie moze w czym tkwi problem? Nosnik - Platinum. [...]
Prawdopodobnie tu tkwi problem.
To nie nośnik, tylko podstawka pod
Stary 23.05.2009, 23:32   #3
kolo333
Nie wydaje mi sie, poniewaz duzo osob wypala na tych plytach i wszystko jest ok. Macie jeszcze jakies inne pomysly?
Stary 23.05.2009, 23:36   #4
Bródka
Technik Informatyk
Avatar użytkownika Bródka
Data rejestracji: 22.01.2005
Nastepny niedowiarek, to ze duzo na tych plytach wypalasz nie znaczy ze one sa dobre, kup porządne plyty Verbatima lub Sony i nagraj
Optiarc AD-7703S v1.03
Mój Mondek - PolskaJazda.pl
Stary 23.05.2009, 23:39   #5
kolo333
No dobra, obadam sprawe na nosnikach Verbatim, chociaz i tak sie nie wypali. Ja stawiam na stara wypalarke, ktorej na interfejs ATA nigdy nie widzialem (nawet w necie nie ma). Tylko na USB.
Stary 23.05.2009, 23:39   #6
Spokoooooooojnie...
Skoro kolega wie lepiej, to niech kombinuje...
Ostatnio zmieniany przez czary2mary : 10.03.2015 o godz. 16:54
Stary 23.05.2009, 23:42   #7
kolo333
Ja tylko prosze o pomoc. A jezeli nie chcecie pomagac to przynajmniej nie nabijajcie postow. Moze ktos inny mial podobny problem i odpowie. W ogole pierwszy raz stykam sie z takim problemem. Jak juz wyskakuje blad (u innych) to w polowie wypalania, a nie przed wypalaniem (jak program probuje odczytac to "Optimal L0 Data Zone Capacity"). I dlatego nie wiem czego to jest wina.
Stary 23.05.2009, 23:51   #8
Bardzo przepraszam, jestem zażenowany i czuję się podle, bo nabiłem posta i zostałem zbesztany.
Jakkolwiek imgburn jest bardzo dobrym programem do nagrywania, to jego log daje niezbyt dużo przydatnych informacji w porównaniu z nero (heh, ciekawe, jeden dobrze nagrywa, drugi daje szczegółowe logi ).
Tu, na forum, najczęstsze problemy powodują shitowe nośniki, potem shitowe nagrywarki, a następnie userzy, którzy nie bardzo wiedzą czego chcą (broń boże nie bierz tego do siebie).
Dobry program już masz, więc kolejnym etapem pomocnym w dojściu do przyczyny problemu jest kwestia nośników - dlatego też dostałeś takie, a nie inne, rady.
Stary 24.05.2009, 08:43   #9
kolo333
W takim razie kupie markowa plyte (Verbatim) i zobacze. A nie uwazasz ze moja DVD-RW moze byc za stara? I jaka tania wypalarke polecasz (konkretnie do wypalania gier na X`a)? Z gory dzieki za odpowiedz.
Stary 24.05.2009, 10:25   #10
andrzejf
Data rejestracji: 28.11.2003
andrzejf w tym momencie nie ma Reputacji dodatnich ani ujemnych <0  pkt>
Wyłącz w Imageburner opcje sprawdania zapisu lasera(otimal), nagrywarke zmien na NECA, i sprawdz system, podobne sytuace mjałem i ja. A płytki nie mają tu nic do powiedzenia. Jedyna sytuacja z płytkami to jest taka że jeśli wypalałęś na (-) to zmień na (+) , Xbox pracuje bardzo dobrże z plusami , to jest prawdopodobnie główna przyczyna.
andrzejf jest offline   Odpowiedz cytując ten post
Stary 24.05.2009, 11:14   #11
Bródka
Technik Informatyk
Napisany przez andrzejf Podgląd Wiadomości
Nie pisz takich glupot bo ktos tu wejdzie i uwierzy ze to prawda jest, nagrywarki NEC to chyba najgorsze nagrywarki jakie sa, a pisanie ze plytki nie maja nic do tego no to juz chyba szczyt nie wiedzy tak samo pisanie ze minusy sa gorsze od plusow jak i tak xbox360 ma odtwarzacz multi któremu jest w sumie wszystko jedno czy to plyta plusowa czy minusowa
Stary 24.05.2009, 12:48   #12
Napisany przez kolo333 Podgląd Wiadomości
Słusznie.
Niewykluczone, niestety.
I jaka tania wypalarke polecasz (konkretnie do wypalania gier na X`a)? [...]
W tym temacie polecają pioneera z serii 216.
Stary 24.05.2009, 13:54   #13
kolo333
Jutro dam plyte kumplowi ktory wypalil juz mase gier na swojej wypalarce (Asus) i obadam co i jak. Dzieki za odpowiedzi. Pozdro.
Stary 24.05.2009, 15:48   #14
Grześiu748
Spamerzyna
Avatar użytkownika Grześiu748
Data rejestracji: 24.09.2006
I 16:46:21 Source File: CDownloads\Pro_Evolution_Soccer_2009_PAL_XBOX360-STRANGE\strange-pes2009.dvd
Taaa... Oryginał...
Stary 24.05.2009, 22:59   #15
Grzesiu748, jeśli ww. autor tematu nie posiada napędu, do którego napisano specjalny fw, a nie chce rozbebeszać konsoli to niestety nie zrobi obrazu gry. IMO zasysanie z sieci w takich przypadkach jest etycznie ok. (a prawnie to nie wiem, pewnie nie, ale nadgorliwość ponoć gorsza od faszyzmu ;])
AVI -> VCD [poradnik] sc0rpi0 DVD-Video 282 28.11.2011 12:34
Teksty nauczycieli Tribunal Off topic 47 11.04.2004 22:39
jestesmy narodem wybranym ;D mr_spock Off topic 3 03.11.2003 09:29
535 śmiesznych tekstów mallow Humor 6 01.06.2003 16:49
Wszystkie czasy w strefie CET. Aktualna godzina: 14:51.
