Stary 27.11.2004, 18:10   #2131
pawelblu
Recydywista - Wielokrotny
Avatar użytkownika pawelblu
Data rejestracji: 17.01.2003
Sony po 3 zl. w Geant (te DPR120N2):
Media Information
Media code/Manufacturer ID RICOHJPNR01
Media Product Revision Number 02h
Free Blocks 405405696
Free Capacity 4.38GB(4.70GB)
Book Type DVD+R
Media Type DVD+R
Default DVD+RW book type DVD-ROM
Default DVD+R book type DVD-ROM
Media Id Code Speed 4.0x 5540KBps
Available Write Descriptor CLV 8.0x 11080KBps
Available Write Descriptor CLV 5.9x 8112KBps
Available Write Descriptor CLV 4.0x 5540KBps
Available Write Descriptor CLV 2.4x 3324KBps
Linear Density Blank Disc
Track Density Unknown
Number of Layers 1
No i jeszcze minusik:
Media code/Manufacturer ID SONY04D1
Format Capacity Not Formatted
Free Blocks 411107328
Free Capacity 4.38GB(4.71GB)
Book Type DVD-R
Media Type DVD-R
Available Write Descriptor CLV 2.0x 2770KBps
Write Strategy Speed 4.0x 5540KBps
2x Speed OPC beta 09
2x Speed OPC power 11
2x Write Strategy field 1 11 87 78 90
2x Write Strategy field 2 A8 82 00 20 00 00
4x Speed OPC beta 06
4x Speed OPC power 17
4x Write Strategy field 1 0D 0F 0B 0B
4x Write Strategy field 2 98 08 0F 0B
4x Write Strategy field 3 00 00 00 00
4x Speed OPC beta multi-pulse 06
4x Speed OPC power multi-pulse 1C
4x Write Strategy field 4 15 97 77 75
4x Write Strategy field 5 98 AB 88 80 00 00
4x Write Strategy field 6 00 00 D0 00 00
Data area starting sector 30000h
Linear Density 0.267um/bit
Track Density 0.74um/track
Number of Layers 1
Ostatnio zmieniany przez pawelblu : 27.11.2004 o godz. 18:12
pawelblu jest offline
Stary 27.11.2004, 19:57   #2132
mensir67pl
***3665;***1769;***1758;
Avatar użytkownika mensir67pl
Data rejestracji: 21.04.2004
Na probe kupilem 2 Mint_y DVD-r oto jeden znich
plyta odtwarz sie bez problemowo w stacjonarnych
NOSNIKI DVD-R/+R-lite-on_dvdrw_sohw-832s_vs0e_27-november-2004_18_47.jpg
DVD+-RW: BenQ 1640
DVD+-RW: Pioneer DVR-215/D
mensir67pl jest offline
Stary 27.11.2004, 23:09   #2133
MZiol
Avatar użytkownika MZiol
Data rejestracji: 18.11.2004
Witam eXpertów.
Wytłumaczcie mi wkońcu jak to jest z tą trwałością, jakością, wytrzymałością.
Niby płyta DVD powinna bez problemu wytrzymać ok 10-15 lat a tu jeden z Was przetestował swoją płytkę nagraną 1 rok temu i okazało się że jakość płyty jest 2x gorsza niż zaraz po nagraniu.
Dochodze do wniosku że troche strach jest nagrywać jakieś ważne materiały - dane na płyte dvd, skoro za ok 2-3 lata nie będzie z niej można nic odczytać.
Chodzi mi też o to że nagrane przezemnie 8 lat temu płyty CD-R czytają się bez żadnego proglemu (TDK, Verbatim, ale i dużo AKOS-ów, a tak naprawde to wszystkie płyty CD-R jakie mam)
Więc wypowiedzcie się na temat tego na czym najbezpieczniej jest nagrywać
DVD czy CD
MZiol jest offline
Stary 27.11.2004, 23:16   #2134
legion
XII
Avatar użytkownika legion
Data rejestracji: 02.06.2004
Napisany przez MZiol
Witam eXpertów.
DVD czy CD
to zalezy od jakosci nosnika wiec najlepiej nagrywac na markowych plytkach
typu TDK,Verby i itp wtedy jest gwarancja ze nosnik przetrwa zab czasu choc czasem i te markowe daj wiele do zyczenia
cd sa bardziej trwale a dvd mniej trwale (bardziej delikatne ) czasem wystarczy mala ryska i plyta do smieci
Ostatnio zmieniany przez legion : 27.11.2004 o godz. 23:18
legion jest offline
Stary 27.11.2004, 23:25   #2135
MZiol
legion a wiesz coś może o rozklejaniusie płyt dvd, to chyba największe fizyczne uszkodzenie jakie może zagrozić danym
bo jeśli chodzi o cd to zdarzało mi się że wierzchnia warstwa płytki zaczęłacię utleniać od środka bub na brzegach płyty
MZiol jest offline
Stary 27.11.2004, 23:50   #2136
legion
XII
no rozklejanie sie to standartow przypadlosc plyt dvd zalezy na jak partie trafisz
legion jest offline
Stary 28.11.2004, 01:26   #2137
Mane
Mane w tym momencie nie ma Reputacji dodatnich ani ujemnych <0  pkt>
Napisany przez legion
no wlasnie nagrywam na espery od 5-6 lat i wszystkie plyty dzialaja bez problemow, a w tym samym czasie wiele verbo i plationum wywalilem do kosza, zyzyly sie lezac w pudelkach (BOX) na plukach a Esperom nie przeszkadza lezenie w kopertach lub w cake.
Mane jest offline
Stary 28.11.2004, 02:30   #2138
dk75
Avatar użytkownika dk75
Data rejestracji: 10.05.2003
Ja nagrywałem Espery na Ricoh'u (CDR) i zaraz po nagraniu miały parę korygowalnych błędów na końcu. TDK i Verbatimów nie próbowałem. Dysany zwykłe były jak Espery Black - również ok. 60% płytek miało na końcu parę korygowalnych błędów. Dysany Black i Harlequin (zarówno srebrne i czarne) zero błędów zaraz po nagraniu.
A co do mojego opisu "dwa razy gorszy odczyt po roku od nagrania". Nie dwa razy tylko na około 1,4 a to i tak 11x poniżej normy.
Ale tak jak już tu pisano - DVD są delikatniejsze. Jednak nie mam miejsca w domu na 1000 płytek CD - DVD to będzie 167szt.
I'm going down...
Hardware:
Software:
dk75 jest offline
Stary 28.11.2004, 03:51   #2139
Hal_Breg
Data rejestracji: 20.11.2004
Hal_Breg w tym momencie nie ma Reputacji dodatnich ani ujemnych <0  pkt>
kupiłem w markecie taką taniutka płytkę -- Msonic DVD+R 4x (1.50PLN) wypaliłem i czytałem na SOHW-832S V0E:
ciekawe ile pożyją na niej dane ;-)
Hal_Breg jest offline
Stary 28.11.2004, 11:47   #2140
mbar
Data rejestracji: 28.12.2003
mbar zaczyna zdobywać reputację <1 - 49 pkt>
Nanya Plastics ma dobrą chemię.
mbar jest offline
Stary 28.11.2004, 12:06   #2141
Przykład markowej płyty, która okazała się bublem.
TDK +R 1-8x na TDK 002
Test prędkości nagrywania
Mimo certifikatu 1-8x test dopuszcza prędkość 2.4-4x.
Test jakości na błędy TE (asymetria ścieżki prowadzącej) i FE ( wyważenie i równość nośnika)
QScan prędkość 8x
QScan prędkość 4x
QScan prędkość 2.4x
Przy żadnej zalecanej prędkości nie można prawidłowo nagrać testowanej płytki.
Pozostaje reklamacja lub kosz.
Dla porównania wysokiej jakości nośnik: Philips +R 1-4x
Podpis pod wykresem w kolorze zielonym oznacza małe błędy i jednocześnie najwyższą jakość testowanego nośnika przy wskazanej prędkości.
NOSNIKI DVD-R/+R-smart-mode-raport-tdk-r1-8x.png   NOSNIKI DVD-R/+R-qscan-tdk-rx8-8x.png   NOSNIKI DVD-R/+R-qscan-tdk-rx8-4x.png   NOSNIKI DVD-R/+R-qscan-tdk-rx8-2.4x.png
Ostatnio zmieniany przez slawekj : 28.11.2004 o godz. 16:12
slawekj jest offline
Stary 28.11.2004, 12:40   #2142
dk75
Ale kiedy pisałem, że TDK z nośnikami TTG01, TDK01 i TDK02 to nie są "markowe" płytki to nikt nie chciał mnie słuchać - taaaaak, TDK ma własne linie produkujące nośniki DVD... ;PPPp Nie ma żadnej teorii spiskowej i OEMów produkwanych dla TDK przez najgorsze i najtańsze firmy...
Ja też trafiłem na TDK-Rx4 Scrachproof z TDK002 i deskryptorami na x2 tylko. Płytkę wyrzuciłem, zresztą nagrywarka nie chciała jej odczytać po nagraniu a napęd DVD-ROM dał radę.
I'm going down...
Hardware:
Software:
dk75 jest offline
Stary 28.11.2004, 14:10   #2143
kowanski
Avatar użytkownika kowanski
Data rejestracji: 25.02.2003
Napisany przez baski
DVD+R Vobis
Plasmon - co to za firma?
Unique Disc Identifier : [DVD+R : POMSC001-002-000]
Disc & Book Type : [DVD+R] - [DVD+R]
Manufacturer Name : [Plasmon]
Manufacturer ID : [POMSC001]
Media Type ID : [002]
Product Revision : [Not Specified]
Disc Application Code : [General Purpose]
Recording Speeds : [1x , 2.4x , 4x]
Blank Disc Capacity : [2,295,104 Sectors = 4,482.6MB = 4.38GB (4.70GB)]
[ DVD Identifier - http://DVD.Identifier.CDfreaks.com ]
PLN 1,22 za sztukę.
Chcę tego używac do nagrywania "na teraz", do archiwizacji używam TDK i Verbatim.
Opinie?
Kupiłem i wypaliłem x4 na 401s@811s HS0P Mod4
i druga palona x8 na NEC-2500A 107V2B5DLBS
NOSNIKI DVD-R/+R-vobis-dvd-r-4x-hs0p.png   NOSNIKI DVD-R/+R-vobis-dvd-r-8x-nec-2500a.png
Ostatnio zmieniany przez kowanski : 28.11.2004 o godz. 19:58
kowanski jest offline
Stary 28.11.2004, 15:17   #2144
sonon
Data rejestracji: 22.07.2004
Slawekj, możesz zrobić test płytki Platinum DVD+R x8? Ciekaw jestem co wyjdzie, bo te płytki, chociaż od Ricoha, to nie wyglądają na oko na dobrze wykonane (mają taką dziwną falbankę na krawędzi) ale palą się rewelacyjnie na moim Necu 2500A. Ciekaw jestem jakby je zdiagnozował Benq.
sonon jest offline
Stary 28.11.2004, 16:37   #2145
pawelblu
Slawek nagraj tego 'niemarkowego' TDK x4 lub x8 na NECu i pokaz jaki bedzie wynik.
TDK oczywiscie ma wlasne linie produkcyjne i sa to plyty z oznaczeniami TDK001 TDK002 i TTG (zdarzaja sie nosniki jakis krzaczastych marek, ktore maja wpisane kody tych fabryk, ale to sa wlasnie podrobki a TDK od TDK to firmowy produkt - oczywiscie nie taj dobry jak ricoh).
Co wiecej. Teraz maja byc TDK produkowane w MPO ale nie widomo co z tego bedzie. W tej chwili jakies 80% wszystkich DVD marki TDK pochodzi z wlasnych linii produkcyjnych TDK.
Wszystkie czasy w strefie CET. Aktualna godzina: 13:58.
