Data rejestracji: 15.02.2010
Verbatim 2x BD-RE DL
Lite-On iHBS212 2 HL05, 45.11 GB burned at 1x speed
sold as "Verbatim 2x BD-RE DL" MID: VERBATIM1 (000) manufactured in Taiwan by CMC Magnetics Thank you to EZ647 for sending this disc.
Data rejestracji: 16.05.2026
Hi, Did you burned it on the Liteon ?
I ordered myself a dozen of these to use them on a UD04FAL and BU40N. |
Yes, but so far I've only tried this burn-in test at 1x speed (I think I have something set up wrong in Opti Drive Control).
Nah it's the setup from imgburn. You should enable (check) the option to fast write.
In Tools, settings, write page 1 - DVD-RAM / BD-RE Fast write. |
Thanks for the advice. I haven't used optical media much in the last 15 or 16 years, so I'd completely forgotten about the quirks of testing optical discs.
#6 | |
Imgburn 2.5.8 no OPC 2x fast write enabled. |
Terrible results - even worse than mine (and mine were bad enough). These media are barely usable. It seems that we aree truly witnessing the twilight of optical media.
Data rejestracji: 12.02.2024
@Stingray, that is like night and day.
I've got a new burner and tested again the same disc - s12uht fw1.02 @2X This media is bad. |
| Tagi |
| 2x, bd-re, dl, verbatim |
