Stary 18.04.2026, 21:17   #1
pepst
Data rejestracji: 15.02.2010
pepst niedługo stanie się sławny ;) <50 - 149 pkt>pepst niedługo stanie się sławny ;) <50 - 149 pkt>
Verbatim 2x BD-RE DL
Lite-On iHBS212 2 HL05, 45.11 GB burned at 1x speed
sold as "Verbatim 2x BD-RE DL"
MID: VERBATIM1 (000)
manufactured in Taiwan by CMC Magnetics
Thank you to EZ647 for sending this disc.
Verbatim 2x BD-RE DL-20260418_185853.jpg   Verbatim 2x BD-RE DL-20260418_185915.jpg   Verbatim 2x BD-RE DL-disc_quality_18-aprila-2026.png
pepst jest offline   Odpowiedz cytując ten post
Stary 19.05.2026, 18:05   #2
cribog
Data rejestracji: 16.05.2026
cribog w tym momencie nie ma Reputacji dodatnich ani ujemnych <0  pkt>
Hi, Did you burned it on the Liteon ?
I ordered myself a dozen of these to use them on a UD04FAL and BU40N.
cribog jest offline   Odpowiedz cytując ten post
Stary 22.05.2026, 19:24   #3
pepst
Yes, but so far I've only tried this burn-in test at 1x speed (I think I have something set up wrong in Opti Drive Control).
Stary 22.05.2026, 19:28   #4
cribog
Nah it's the setup from imgburn. You should enable (check) the option to fast write.
In Tools, settings, write page 1 - DVD-RAM / BD-RE Fast write.
Stary 22.05.2026, 19:53   #5
pepst
Thanks for the advice. I haven't used optical media much in the last 15 or 16 years, so I'd completely forgotten about the quirks of testing optical discs.
Stary 31.05.2026, 19:11   #6
cribog
Napisany przez pepst Podgląd Wiadomości
Burned on verbatim 43890 (bu40n fw 1.05)
Imgburn 2.5.8 no OPC 2x fast write enabled.
Verbatim 2x BD-RE DL-43890_1.05_2x_usb2.0_initio_verbatim1_imgburn_noopc_29.05.2026.png
Stary 01.06.2026, 20:24   #7
pepst
Terrible results - even worse than mine (and mine were bad enough). These media are barely usable. It seems that we aree truly witnessing the twilight of optical media.
Stary 04.06.2026, 00:24   #8
Stingray
Data rejestracji: 12.02.2024
Stingray zaczyna zdobywać reputację <1 - 49 pkt>
it is old Sony/Panasonic bought from Japan yahoo. recorded by Pioneer 209MBK->S11JX
Stingray jest offline   Odpowiedz cytując ten post
Stary 06.06.2026, 20:19   #9
cribog
@Stingray, that is like night and day.
I've got a new burner and tested again the same disc - s12uht fw1.02 @2X
This media is bad.
Verbatim 2x BD-RE DL-bdr-s12uht_1.02_2x_usb3_verbatim1_imgburn_noopc_06.06.2026.png
2x, bd-re, dl, verbatim
Wszystkie czasy w strefie CET. Aktualna godzina: 04:25.
