Stary 29.11.2023, 13:27   #931
Terramex
Data rejestracji: 29.11.2023
Terramex w tym momencie nie ma Reputacji dodatnich ani ujemnych <0  pkt>
Hallo, any chance for this one to read UHDs ?
DVRTool v1.0 - firmware flashing utility for Pioneer DVR/BDR drives-209mbk.jpg
Terramex jest offline
Stary 29.11.2023, 16:27   #932
jadburner
Avatar użytkownika jadburner
Data rejestracji: 07.03.2017
Napisany przez RAO1 Podgląd Wiadomości
Hi I'd like to cross-flash Medion DVR-109DB into DVR-109 with newest firmware, please help.
Drive Information:
Model Name : PIONEER DVD RW DVR-109
Firmware Rev : 1.09
Extra Info : 05/01/19 PIONEER
Serial Number : DLDL095798WL
Buffer Size : 2000 kiB
Additional Drive Information:
Label Code : DVR-109DB
Hardware Rev : ATA 0009
Kernel Type : MEDION
Firmware Type : MEDION
Kernel Version : 0001
Drive is in normal mode.
Firmware flashing support : YES
Firmware dumping support : NO
Drive Capabilities:
CD-ROM : R BD-ROM : -
CD-R : R/W BD-R : -
CD-RW : R/W BD-R XL : -
DVD-ROM : R BD-RE : -
DVD-R : R/W BD-RE XL : -
DVD-R DL : - HD DVD-ROM : -
DVD-RW : R/W HD DVD-R : -
DVD+R : R/W HD DVD-R DL : -
DVD+R DL : R/W HD DVD-RW : -
DVD+RW : R/W LabelFlash : NO
DVD-RAM : R LightScribe : NO
Drive Region Settings:
RPC Scheme : RPC-2
Current Region : 0
Changes Left : 5 (available to user)
Resets Left : 4 (available only to vendor)
Region State : Region is not set
Welcome to the forums, RAO1. I will need to check with the developer of BDRFlash to see if it's possible to crossflash your drive. I will let you know as soon as I have an answer.
jadburner jest offline
Stary 29.11.2023, 16:31   #933
jadburner
Napisany przez Terramex Podgląd Wiadomości
Załącznik 204855
Welcome to the forums, Terramex! PM sent.
Stary 01.12.2023, 03:11   #934
RAO1
RAO1 w tym momencie nie ma Reputacji dodatnich ani ujemnych <0  pkt>
Thank you, I saw that it has been done before (same model)
Can you send me that version? Thanks.
RAO1 jest offline
Stary 01.12.2023, 03:43   #935
jadburner
DVRTool is obsolete and no longer distributed; BDRFlash has taken it's place. Check your PM.
Stary 01.12.2023, 11:23   #936
RAO1
Check your PM.
Inbox is empty.
RAO1 jest offline
Stary 01.12.2023, 18:41   #937
jadburner
Inbox is empty.
Strange. Sorry about that. Please check again.
Stary 02.12.2023, 03:04   #938
RAO1
Success! Medion DVR-109DB to Pioneer DVR-109 v.1.58
DVRTool v1.0 - firmware flashing utility for Pioneer DVR/BDR drives-dvr109-v158-nero.jpg
RAO1 jest offline
Stary 02.12.2023, 05:51   #939
jadburner
Congratulations!
Stary 07.12.2023, 15:04   #940
Terramex
Thank you very much !
How about that one ?
Kod:
Drive Information
OS device name: E:
Manufacturer: PIONEER
Product: BD-RW BDR-212D
Revision: 1.00
Firmware date: 2019-01-10
Bus encryption flags: 13
Highest AACS version: 61
LibreDrive Information
Status: Enabled
Drive platform: RS8F00
Firmware name: PIONEER BDR-212T
Firmware type: Original (unpatched)
Firmware version: 1.00/ID61
Or is it enough to just extract firmware from BDR-S12UHT_FW101EU.exe and flash the single file ?
EDIT: looking at Post #888 it seems i need the kernel as well
Ostatnio zmieniany przez Terramex : 07.12.2023 o godz. 16:29
Stary 07.12.2023, 19:51   #941
jadburner
Kod:
Drive Information
OS device name: E:
Revision: 1.00
Status: Enabled
Terramex - Check your PM.
Stary 08.12.2023, 12:06   #942
Sillywilly
Data rejestracji: 06.12.2023
Sillywilly w tym momencie nie ma Reputacji dodatnich ani ujemnych <0  pkt>
Hello everyone, I was lucky to get a Pioneer BDR-XD07 drive with 1.03 Fimware from before Dec 2022. Should be possible to crossflash it to BDR-XD07UHD, right?
Kod:
Drive Information
OS device name: R:
Product: BD-RW BDR-XD07
Revision: 1.03
Serial number: BFDL011774WL
Firmware date: 2020-08-20
Highest AACS version: 78
Status: Enabled
Drive platform: RS8D30
Firmware name: PIONEER BDR-BDS7
Firmware version: 1.03
DVD all regions: Yes
BD raw data read: Yes
BD raw metadata read: Yes
Unrestricted read speed: Yes
Kind regards
Sillywilly jest offline
Stary 08.12.2023, 14:27   #943
Terramex
Thanx again. Much appreciated !
And a final one from a defective Epson Discproducer
Kod:
Drive Information
OS device name: E:
Product: BDW-PR1EPDVPP100
Revision: 1.00
Firmware date: 2015-11-27
Bus encryption flags: 1B
Status: Enabled
Drive platform: RS8680
Firmware name: PIONEER BDR-209
Firmware version: 1.00/ID79
Ostatnio zmieniany przez Terramex : 08.12.2023 o godz. 16:18
Stary 08.12.2023, 23:09   #944
jadburner
Napisany przez Sillywilly Podgląd Wiadomości
Kod:
Drive Information
OS device name: R:
Revision: 1.03
Status: Enabled
Kind regards
Welcome to the forums, Sillywilly! PM sent.
Stary 08.12.2023, 23:13   #945
jadburner
Kod:
Drive Information
OS device name: E:
Revision: 1.00
Status: Enabled
PM sent.
dvrtool, pioneer
Pioneer BD Drive Utility czary2mary Programy do nagrywania, testowania, diagnostyki 16 05.02.2022 08:55
Linkownia\ firmware do CD\DVD\BluRay czary2mary Flashowanie/Firmware/Podkręcanie napędów optycznych 2 24.08.2019 18:09
[Komentarze] Flash Utility for LiteOn-made Drives i biblioteka biosów w wersji BIN -Sid-The-Rat=> Flashowanie/Firmware/Podkręcanie napędów optycznych 209 10.02.2006 15:01
Flash Utility for LiteOn-made Drives i biblioteka biosów w wersji BIN SoBal Flashowanie/Firmware/Podkręcanie napędów optycznych 0 28.09.2003 22:37
Wszystkie czasy w strefie CET. Aktualna godzina: 15:42.
