Stary 03.02.2024, 23:15   #991
techguru
Data rejestracji: 09.01.2024
techguru w tym momencie nie ma Reputacji dodatnich ani ujemnych <0  pkt>
for file BDR-S11JX_FW153EU.exe
there is 2 folders extracted from it
11TM_BDR-S11JX_FW153EU
11T_BDR-S11JX_FW153EU
if im flashing a 209D any idea which one I should use
the TM one contains a kernal file
the T one doesn't
techguru jest offline
Stary 04.02.2024, 06:33   #992
jadburner
Avatar użytkownika jadburner
Data rejestracji: 07.03.2017
Napisany przez techguru Podgląd Wiadomości
the T one doesn't
11T_BDR-S11JX_FW153EU.exe is for hardware SAT 8800.
11TM_BDR-S11JX_FW153EU.exe is for SAT 8801.
If your 209D has hardware SAT 8600, use the SAT 8800 firmware. If your 209D is SAT 8601, use the SAT 8801 firmware.
jadburner jest offline
Stary 05.02.2024, 06:59   #993
techguru
@jadburner
just so you know the 209d/m doesn't seem to wanna take the BDR-S11J-X firmware
Stary 05.02.2024, 17:28   #994
jadburner
@jadburner
That crossflash should work. You must be using incorrect files or not checking the "Force flash" box.
Stary 05.02.2024, 18:38   #995
techguru
flash
tried both
BDR-S11J-X_FW150EU
BDR-S11JX_FW153EU
and defiantly checked force flash
Stary 05.02.2024, 19:21   #996
jadburner
tried both
BDR-S11J-X_FW150EU
BDR-S11JX_FW153EU
What is the hardware version of your BDR-209? SAT XXXX.
Stary 05.02.2024, 19:26   #997
techguru
type
SAT8600
Stary 05.02.2024, 19:32   #998
jadburner
SAT8600
Check your PM.
Stary 05.02.2024, 19:43   #999
techguru
flash
Check your PM.
think I figured out why
its not a 209d/m its a 209UBK
I probably modified the firmware when I first got it
basically its a BDR-2209
Stary 06.02.2024, 17:48   #1000
Oinker
Data rejestracji: 08.11.2022
Oinker zaczyna zdobywać reputację <1 - 49 pkt>
Shouldn't be a problem, I flashed my 209E/M (which is identical to 209U/2209) to S11J-X.
DVRTool v1.0 - firmware flashing utility for Pioneer DVR/BDR drives-209m-s11jx.png
Oinker jest offline
Stary 07.02.2024, 07:11   #1001
techguru
flash
Napisany przez Oinker Podgląd Wiadomości
I guess mine is not compatible then... either that or some driver is interfering with it
I might try flashing it on another pc sometime
Stary 07.02.2024, 12:44   #1002
Oinker
Which firmware is your 209M currently on? Must be 1.54 or below. 1.55 contains the downgrade/crossflash protections already. Did you try the firmware and kernel files that jadburner gave you?
Oinker jest offline
Stary 07.02.2024, 21:07   #1003
techguru
1.51
yea I tried them as well
Stary 07.02.2024, 22:45   #1004
Oinker
1.51
Did you select both firmware and kernel files together, so both show up under "Select file(s)" then? If just one file is shown there, it won't work. What actually happens? Do you get some error message?
Oinker jest offline
Stary 12.02.2024, 03:44   #1005
Delta8791
Gość
Posty: n/a
I have the following 3 pioneer models (as listed on serial label) with the indicated stock pioneer firmware:
1) BDR-212V, Rev 1.01, Firmware date 2021-07-20
2) BDR-212DBK, Rev 1.02, Firmware date 2022-03-16
3) BDR-213ULBK, Rev 1.02, Firmware date 2022-04-06
Is it possible to receive a copy of BDRFlash to do the following crossflashes:
BDR-212V and BDR-212DBK --> BDR-S12UHT v1.02 (firmware BDR-S12JBK_UHT_FW102EU.exe)
BDR-213ULBK --> BDR-S13U-X v1.03 (firmware BDR-S13JX_UX_EX_CX_FW103EU.exe)
From what I understand:
1) In all cases, the new model/firmware being crossflashed to:
a) is compatible with the original old model/firmware.
b) will enable BDXL writing and UHD ripping on the drive (using the appropriate software).
c) is dated <= Nov 30, 2022 and thus not among the Pioneer firmwares that prevent crossflashing/downgrading and disable libredrive.
2) I won't be stuck with my choice of crossflashed firmware: if, for some reason I'm unhappy with the results, I can use BDRFlash again to crossflash to a different (compatible) firmware, provided I have the firmware (and kernel) files.
Is this all correct? By all means, please advise if a different model/firmware version would be a better choice for any of the models, especially if I am choosing too high of firmware versions.
Also, I would be doing the crossflashing over a sata to usb y-connector (Vantec CB-ST00U3). Please let me know if this could be problematic and if another connector (or direct sata to pc motherboard) is advisable.
Thanks so much in advance to all the contributors to this excellent forum/topic, especially @blackened2687, who I understand is the OP and creator of the fantastic softwares DVRTool and BDRFlash, and @jadburner for his great and informative posts and helpful guidance!
dvrtool, pioneer
Pioneer BD Drive Utility czary2mary Programy do nagrywania, testowania, diagnostyki 16 05.02.2022 08:55
Linkownia\ firmware do CD\DVD\BluRay czary2mary Flashowanie/Firmware/Podkręcanie napędów optycznych 2 24.08.2019 18:09
[Komentarze] Flash Utility for LiteOn-made Drives i biblioteka biosów w wersji BIN -Sid-The-Rat=> Flashowanie/Firmware/Podkręcanie napędów optycznych 209 10.02.2006 15:01
Flash Utility for LiteOn-made Drives i biblioteka biosów w wersji BIN SoBal Flashowanie/Firmware/Podkręcanie napędów optycznych 0 28.09.2003 22:37
Wszystkie czasy w strefie CET. Aktualna godzina: 06:55.
