I'm a newbie here but I have 2 Pioneer drives (BDR-209DBK and BDR209EBK) manufactured in 2018 that I'd like to cross-flash to enable reading of BDXL and possibly rip my 4K BR with MakeMKV. Would that be possible with BDRflash? If yes, how to get this tool and the firmwares? Thank you in advance for your help. PS : I also have a I-Odata slim external drive (basically a Pioneer BDR-UD02 - platform RS8410 - in USB 3.0 I-Odata enclosure) that cannot be used with MakeMKV. Any idea why? |
Welcome to the forums, DaveRiscman. Although the BDR-TD05 is capable of writing to quad-layer discs, since it's a BDXL drive, it never received a firmware update from Pioneer to enable it. That's why it won't properly recognize your SONY-NQ1 media. Unfortunately, I'm not aware of alternate firmware for the drive that would enable QL support.
Does it see that it's BD XL, quite possible that it does not have writing strategy for this particular BD XL.
The Sony discs are model 10BNR4VAPS4 if that's of any importance. |
Does it recognizes it's XL BD ?
Hello. I have a Pioneer BDR-TD05 drive inside of a Logitec casing (LBD-PME6U3). Logitec offered firmware up to 1.02, which I installed over the stock 1.00.
It's able to read standard BluRay videos, but if I try to burn 128GB Quad-Layer SONY BDXL discs, it's incompatible (ImgBurn reports "Incompatible Medium Installed"). The unit has a external power as well as USB, so I thought external power would fix it, but it didn't. I believe this issue is because of the firmware. My firmware is dated 2014, while the discs were only beginning to be manufactured in 2018. I downloaded every Logitec and Pioneer firmware available on their respective websites and parsed the firmware microcode file headers to see if there is a model with the same "Hardware Version", but there wasn't any. I found a mysterious 2.02 firmware on Fujitsu's website for the BDR-TD0. Fujitsu is using their own firmware flasher rather than the signed Pioneer one, and it's reporting my device as incompatible, though the microcode file embed in the flasher is the same format. My firmware: Kod:
S8211000.102Kod:
S8211721.202 |
Good day, guys!
I have BDR-TD05AS that doesn't read any disc (CD, DVD, or BD). I think it can be because of firmware (now its version is 1.01), but i can't find a way to update it. Could you give me advice what to do? Thanks! |
Skąd można pobrać najnowszą wersję z GUI? Mam problem z flashowaniem DVR-215D po USB. Może ten soft coś pomoże...
Thank you. :) A BDR-XD07T i want to crossflash to BDR-XD07TUHD. |
What drives are you trying to crossflash to/from? |
Hello,
i´m trying to crossflash my Pioneer Drive. All tries with DVRTool from Post 1 haven´t worked. I have extracted the Firmware Binarys (131 and 132) from the official Updater but no success to Flash them to the Drive. I´m looking for the introduced BDRFlash Tool, but couldn´t find it. Can someone help out? Awesome what you guys are doing here. Thanks in advance. |
Use Opti Drive Speed. The program is free. Opti Drive Speed.
Hello. Is there possibility to limit cd reading speed with DVRTool on DVR-XD10T?
Hello i have a BDR-212DBK drive and i would like to flash it to an 212UBK. Is it only possible with the BDRTool or is there a nother method?
Thanks to blackened2687 and jadburner my 208Ds are 208Ms now. :D
https://forum.cdrinfo.pl/attachments...208dto208m.png |
Oh, thanks jadburner! I usually checked this page for firmware updates:
https://pioneer.jp/device_e/product-...v00001r_e.html And there is only one for the 211EBK/UBK drives. I don't mind waiting, blackened2687 being busy is a positive thing here. :) Looking forward to the firmware archive. ;) |
With respect to the S11, you can find 1.53 firmware for the BDR-S11J-BK and BDR-S11J-X here. Some, but not all, official flashers from Pioneer include both a kernel and firmware, which you can extract from the unpacked EXE. However, some flashers include only the firmware. In that case you need to either extract the kernel from a drive you have, or use one from the extensive archive that blackened2687 is assembling. A really neat feature of the latest version of BDRFlash is that you can drag and drop an official flasher on top of the program and it will automatically extract the firmware and (if it exists) the kernel in the same directory as the flasher. Many thanks to blackened2687 for adding that feature. :spoko: Hopefully you'll hear from blackened2687 soon, but he is very busy lately. |
Btw, if there's a kernel required, is it enough to unpack the updater exe and use the two files that get extracted in the BINARY folder then? They are about the same size, just have different filenames, e.g. the 208M firmware 1.40 had files S8301000.140 (69 kb) and S8301001.140 (1833 kb), the 1.50 firmware has 131 (69 kb) and 132 (1836 kb), i.e. there is no additional encryption of any kind on the newer files? And is it correct that there is no 1.53 available for the S11 like there is for the 211M model (i.e. the EBK/UBK drives)? |
if there is a chance i can try it :-) i have 209D :-)
Ilość załączników: 11
Thanks to @blackened2687, I've had the opportunity to test his latest tool BDRFlash. The tool is currently at a v0.99 beta level, so it should be generally available real soon now. :)
One of the very useful features of the tool is the ability to crossflash between drives with similar attributes. As an example, here's the process for crossflashing a BDR-209D into a BDR-S11JBK. This allows the drive to utilize BDXL media and take advantage of new MIDs and other features of newer firmware. Here's the device information for a BDR-209D before any crossflashing. Załącznik 189749 As you can see, the drive lacks support for BDXL media. To begin, we start BDRFlash and select the drive to crossflash: Załącznik 189750 The Select command menu includes options to flash firmware and put the drive in kernel mode: Załącznik 189751 Since we want to crossflash the drive, we choose the Flash firmware option. We then need to use the file browse option to select the kernel and firmware files we want to flash to the drive. Since you need to select both files, you can use Ctrl-click to select them both. Załącznik 189752 Załącznik 189754 Załącznik 189753 blackened2687 provides the firmware/kernel files in folders, in this case a folder named BDR-S11JBK_1.52_v1. Once you've selected the files to flash, click the START button. If the program's internal consistency checks are satisfied, you'll see the confirmation dialog. Załącznik 189755 Select Yes, and a series of messages will appear as the program flashes the files. Here's one example: Załącznik 189756 When the flashing is complete, you'll see a success message. Here's the device information for our crossflashed drive. You can see that the drive is now a BDR-S11 and has support for BDXLmedia. Załącznik 189757 As final proof that the process worked, here's plots showing creation of a BDXL test disc and a quality scan of it. Załącznik 189758 Załącznik 189759 The process is really quite easy, and the program contains numerous checks to ensure that the drive and files to crossflash are matched. Great job, @blackened2687! |
Or BDR-209EBK ?
Now I have 2 mechanically defective BDR-PR1EPDV drivers.
can i backup these drivers with dvrtool and overwrite them on BDC-207DBK? Thank you very much for your interest and help. |
Hallo u need to wait only two person who can share this is czary2mary and blackened2687 |
Pioneer DVR-111DBK OEM Bufallo fw.8.25
Ilość załączników: 3
Pioneer DVR-TD08TBM
Ilość załączników: 2
PIONEER DVD-RW DVR-212 (GBDP003101WL)
tak samo nie pamiętam kiedy kupiłem :( Załącznik 151211 Załącznik 151212 |
Pioneer BDC-TD03RS firmware dump
Co myślicie czy jest jakaś szansa żeby naprawić ten napęd ?
Blackened2687: linki usunięte, napisałem do PW. :> |
fakt ubity podczas flashowania
Acer oficjalnie nigdy nie wydał firmware w postaci instalatora do tego modelu.
Możesz zapytać się suportu czy nie dysponują firmware do tego modelu. https://www.acer.com/ac/pl/PL/content/support |
Ja nic, taki dostałem, jest martwy, ale widoczny w systemie, DVRflash zwraca informację, że jest w kernel mode.
Mam taki napęd BDC-TD03RS czy da się go uratować ? Może ktoś posiada do niego firmware ? |
Ilość załączników: 5
na natywnym kontrolerze IDE wszystko poszło bez problemu
Załącznik 133324 |
corssflash na VIA RAID Controller VT6421A
ale 111D normalnie poszła do 111 przepnę do natywnego IDE i się zobaczy |
PIONEER BDR-211UBK
Pioneer BDR-PR1 MC-U 200 Almedio JIZ 6017
poproszę na pw. :-)
Crossflash Pioneer DVR-216BK do Plextor PX-830SA
Ilość załączników: 6
Bez żadnego problema ....:) DVRTool .... ma moc .....;)
Plex Tools nie wykrywa tego modelu Jedyna dodatkowa opcja możliwa do zmiany to tryby pracy napędu w DVRTool Załącznik 128241 Załącznik 128242 Załącznik 128243 Załącznik 128244 Załącznik 128245 Załącznik 128246 |
Plex Tools nie wykrywa tego modelu przynajmniej na USB ...sprawdzę jeszcze po crossflash jak na kontrolerze SATA to wygląda ..:) |
no proszę :-) można 216 :-) przerobić
są jakieś opcje w Plex tools ? |
Nareszcie ......
Pioneer DVR-112DBK Primera
there is no possibility
Sorry, how it is possible to download DVRTool_v1.0298?
Sorry for long delay, everyone... Was really, really busy on my job.
You must wait - he is very busy
very hard to contact with him
iam also beta tester not alowed to share it sorry |
and where do I get it?
Yes ;)
Can I test it? I have many of these drives laying around.
It is not available yet. |
Hello!
Where can I find version 1.0.298? With version 1.2 I get: Device: \\.\N: Drive Information: Model Name : PIONEER BDW-PR1EPDVPP100 Firmware Rev : 1.00 Extra Info : 15/11/27 PIONEER Serial Number : PGDL006113WL Buffer Size : 4000 kiB Additional Drive Information: Label Code : ---- Hardware Rev : SAT 8680 Kernel Type : ID79 Firmware Type : ID79 Kernel Version : 0000 Drive is in normal mode. Firmware flashing support : NO Firmware dumping support : NO Drive Capabilities: CD-ROM : R BD-ROM : R CD-R : R/W BD-R : R CD-RW : R/W BD-R XL : - DVD-ROM : R BD-RE : R DVD-R : R/W BD-RE XL : - DVD-R DL : R/W HD DVD-ROM : - DVD-RW : R/W HD DVD-R : - DVD+R : R/W HD DVD-R DL : - DVD+R DL : R/W HD DVD-RW : - DVD+RW : R/W LabelFlash : NO DVD-RAM : R/W LightScribe : NO Drive Region Settings: RPC Scheme : RPC-2 Current Region : 0 Changes Left : 5 (available to user) Resets Left : 4 (available only to vendor) Region State : Region is not set |
Ilość załączników: 10
Ilość załączników: 9
Thanks for answer. The translation add in works on your forum so hope you get this reply. I also replied in the Club Myce forum. |
Change kernel \ firmware
kernel :S1030000.106 firmware :S1030001.106 DVRTool command: Cytat:
Firmware \ kernel: http://www90.zippyshare.com/v/83tX4arm/file.html |
DVRTool 1.02 Pioneer 206D
Here is screen shot. I tried to flash my Pioneer BDR 206DBK Załącznik 117258and now computer says it is not an optical drive. Says it is USB ASMT 2115 USB Drive. I tried flashing it with firmware S1030611.106
What did I do wrong as now it is recognized as a USB storage drive and it will not eject etc. |
ten fabryczny fw. można porównać do jakiego odpowiednika z 217 ?
PLEXTOR DVDR PX-860SA
Ilość załączników: 7
Pioneer DVR-A07U 2004r
Pioneer DVD-129P
tak to wygląda po crossflash
zaawansowane funkcje są dostępne ale nie aktywne Załącznik 115147 Załącznik 115148 Załącznik 115149 |
| Wszystkie czasy w strefie CET. Aktualna godzina: 02:25. |
