Stary 23.06.2023, 18:55   #856
ultrahorst
Data rejestracji: 22.06.2023
ultrahorst w tym momencie nie ma Reputacji dodatnich ani ujemnych <0  pkt>
Napisany przez tucker Podgląd Wiadomości
Hello,
I'd like to crossflash a BDR-S12XLT (FW 1.01) to a UHD friendly version, possibly S12UHT. Could you please help?
Thanks and best regards,
Mik
Thanks to the help of jadburner, I was able to crossflash the same drive/firmware combination to a BDR-S12UHT with firmware 1.02 - works perfectly with UHDs.
It seems that the BDR-S12UHT drive is currently not on sale anywhere in Europe, which is what I wanted to buy in the first place.
If anybody is looking for a (still) flashable BDR-S12XLT, try German Amazon, search for B0887XPT2Q. The drive I ordered there recently was new and manufactured in April 22, still has the compatible firmware 1.01
ultrahorst jest offline
Stary 30.06.2023, 21:39   #857
MeisterProper
Data rejestracji: 30.06.2023
MeisterProper w tym momencie nie ma Reputacji dodatnich ani ujemnych <0  pkt>
Hello to all,
it would be awesome if I could flash my Pioneer BDR-XS07TS to a XS07TUHD.
Thanks in advance and have a nice weekend
MeisterProper jest offline
Stary 01.07.2023, 06:50   #858
jadburner
Avatar użytkownika jadburner
Data rejestracji: 07.03.2017
Napisany przez MeisterProper Podgląd Wiadomości
Hello to all,
Welcome to the forums, MeisterProper! PM sent.
jadburner jest offline
Stary 03.07.2023, 12:32   #859
daleski
Data rejestracji: 03.07.2023
daleski w tym momencie nie ma Reputacji dodatnich ani ujemnych <0  pkt>
Hi Everyone I am so glad I have found this website, I won't be getting much sleep! I have managed to source a pioneer 212EBK and would like to cross flash, can someone please point me in the right direction for the BDR Flasher tool? Thanks
daleski jest offline
Stary 03.07.2023, 21:18   #860
jadburner
Napisany przez daleski Podgląd Wiadomości
Welcome to the forums, daleski! PM sent.
Stary 18.07.2023, 13:36   #861
xenon2
Data rejestracji: 18.07.2023
xenon2 w tym momencie nie ma Reputacji dodatnich ani ujemnych <0  pkt>
Hi I would like also to cross-flash my drive to support pure audio features (if possible).
My drive is:
BDR-212M 1.04v 22/12/20
I'm not sure what is recommended firmware for that, would be grateful for any information.
Ostatnio zmieniany przez xenon2 : 18.07.2023 o godz. 14:15
xenon2 jest offline
Stary 20.07.2023, 06:19   #862
jadburner
Napisany przez xenon2 Podgląd Wiadomości
My drive is:
Welcomer to the forums, xenon2! PM sent.
Stary 27.07.2023, 23:04   #863
zuzuzuzu
Data rejestracji: 27.07.2023
zuzuzuzu w tym momencie nie ma Reputacji dodatnich ani ujemnych <0  pkt>
Hello everyone! I'm new on this forum and I'm really happy that found it. I have BDR-212V and bought it to write on 100Gb millennium disk. Unfortunately it can not recognize Verbatime M-Disk. I have no other brand disk to check whether my drive can recognize it. I wonder if is it possible to cross-flash my Pioneer to some other BDR-212 or whatsoever to do my job done. Any help highly appreciated.
zuzuzuzu jest offline
Stary 27.07.2023, 23:46   #864
Oinker
Data rejestracji: 08.11.2022
Oinker zaczyna zdobywać reputację <1 - 49 pkt>
Pioneer lists a whole bunch of new firmwares now all the way down to the 208 series, I assume they all implement the new protections against downgrading and crossflashing, i.e. it's not recommended to flash any of them atm? They also list a whole bunch of new 213 series drives, e.g. a 213EBK, seems the 213 series is finally coming to Europe.
Oinker jest offline
Stary 28.07.2023, 05:51   #865
jadburner
Napisany przez Oinker Podgląd Wiadomości
You're correct, it is definitely not recommended to upgrade the firmware on your Pioneer drive to any firmware dated December 2022 or later. Otherwise you will prevent downgrading or crossflashing that drive.
Stary 28.07.2023, 05:59   #866
jadburner
Napisany przez zuzuzuzu Podgląd Wiadomości
Welcome to the forums, zuzuzuzu! We're glad you found this site and hope you find it useful.
The BDR-212V only reads/writes to BD-R SL and DL discs. It does not recognize BDXL (triple layer, quad layer) media.
I've sent you a PM to follow up on crossflashing your drive.
Stary 28.07.2023, 20:32   #867
zuzuzuzu
Thank you very much for your kind attention. Unfortunately I was not able to PM, so I posted here. My drive has vinpower specific firmware version 1.02 according to their specification. Here is the DVRTool log:
Device: \\.\D:
Drive Information:
Model Name : PIONEER BD-RW BDR-212V
Firmware Rev : 1.02
Extra Info : 22/05/31
Serial Number : AFDL014703WL
Buffer Size : 4000 kiB
Additional Drive Information:
Label Code : ----
Hardware Rev : SAT 8F00
Kernel Type : ID06
Firmware Type : ID06
Kernel Version : 0000
Drive is in normal mode.
Firmware flashing support : NO
Firmware dumping support : NO
Drive Capabilities:
CD-ROM : R BD-ROM : R
CD-R : R/W BD-R : R/W
CD-RW : R/W BD-R XL : -
DVD-ROM : R BD-RE : R/W
DVD-R : R/W BD-RE XL : -
DVD-R DL : R/W HD DVD-ROM : -
DVD-RW : R/W HD DVD-R : -
DVD+R : R/W HD DVD-R DL : -
DVD+R DL : R/W HD DVD-RW : -
DVD+RW : R/W LabelFlash : NO
DVD-RAM : R LightScribe : NO
Drive Region Settings:
RPC Scheme : RPC-2
Current Region : 0
Changes Left : 5 (available to user)
Resets Left : 4 (available only to vendor)
Region State : Region is not set
Stary 29.07.2023, 01:03   #868
jadburner
Device: \\.\D:
Drive Information:
Firmware Rev : 1.02
Label Code : ----
Kernel Type : ID06
Drive Capabilities:
RPC Scheme : RPC-2
Current Region : 0
zuzuzuzu - Please check your messages.
Stary 29.07.2023, 10:09   #869
zuzuzuzu
Thank you for the message. I've already replied but not sure whether my PM has been sent or not because I can't see it in the list. Please let me know. Thanks!
Stary 30.07.2023, 00:07   #870
jadburner
Yes, I did receive your PM and replied. Happy crossflashing!
dvrtool, pioneer
Pioneer BD Drive Utility czary2mary Programy do nagrywania, testowania, diagnostyki 16 05.02.2022 09:55
Linkownia\ firmware do CD\DVD\BluRay czary2mary Flashowanie/Firmware/Podkręcanie napędów optycznych 2 24.08.2019 19:09
[Komentarze] Flash Utility for LiteOn-made Drives i biblioteka biosów w wersji BIN -Sid-The-Rat=> Flashowanie/Firmware/Podkręcanie napędów optycznych 209 10.02.2006 16:01
Flash Utility for LiteOn-made Drives i biblioteka biosów w wersji BIN SoBal Flashowanie/Firmware/Podkręcanie napędów optycznych 0 28.09.2003 23:37
Wszystkie czasy w strefie CET. Aktualna godzina: 01:01.
