thorgal to ciota
Data rejestracji: 12.04.2002
creative zen + firmware
witam
mam taki problem - po próbie aktualizacji firmware'u w zenie (zen touch) pojawia sie menu RECOVERY MODE i... nic :/ co dalej - czy odtwarzacz przepadł? czy da sie cos zrobić jeszcze? PROSZĘ o pomoc pozdrawiam, Marcin |
| #ads | |
ClassicGOD
Data rejestracji: 24.02.2004
http://forums.creative.com/creativel...d=20693#M78262
How do I reload the OS? Firstly, make sure you have downloaded a firmware for your player. 1. Select the Reload OS menu option (or Reload Firmware for the Zen Micro) from Rescue Mode. 2. The display shows that your player is removing the current firmware. 3. Connect your player to your computer with the USB cable. 4. In the folder where you downloaded this firmware update, double-click the .EXE file, and follow the instructions that appear on your screen. 5. When prompted, click the Upgrade option. 6. When the upgrade is complete, your player restarts. 7. A "rebuilding the library" message appears on your player's LCD. This message disappears when your player has finished rebuilding the music library. 8. You can now use your player.
![]() God's Final Message to His Creation: "We apologise for the inconvenience" |
Data rejestracji: 23.08.2004
co daje zmiana firmware ?
#4 | |
thorgal to ciota
problem z tym że po reloadzie on potrzebuje połączenia z kompem a komp go nie widzi :/ |
ClassicGOD
Sam niestety nie mam takiego playerka i jedyne co moge ci polecic to przeczytanie http://www.nomadness.net/modules.php?name=FAQ tego faq'a.
