-   Hardware (https://forum.cdrinfo.pl/f105/)
-   -   PS3 "Jailbreak" (https://forum.cdrinfo.pl/f105/ps3-jailbreak-86545/)
frog 25.10.2010 20:16
@MAXiu wszystko pod ciebie ;)
Przy okazji newsow. Zobaczcie najladniej prezentujacego sie kolejnego brejka. Lejdis and Dzentelmans milo mi wam zaprezentowac BRAD NEW P3Go GT Break
http://www.ps3hax.net/wp-content/upl...1410951992.jpg
http://www.ps3hax.net/wp-content/upl...1410951993.jpg
http://www.ps3hax.net/wp-content/upl...1410951991.jpg
NICE cooooo ?!??!!? ;> No i przydatny prdolnik dla SLIMowcow ;>
M@X 25.10.2010 20:03
Najpierw geohot dumpujacy firmware konsoli, teraz netkas... Zaczyna tu pachniec jablkami :-P...
frog 25.10.2010 19:56
@Obibox sprytnie rozmieszczone. Zgrabnie ci to wyszlo.
A ja przy okazji zapodam ciekawego newsa z dzis ;> :
Netkas, the legendary hackintosh hacker/programmer (essentially the DarkAlex of the OSX world), has just posted a short but interesting PS3 related post on his blog.
To quote :
Here is something from lv2 dump
CELL_FS_
UTILITY:HDD0
CELL_FS_UFS
/dev_hdd0
ufs is a fs used by bsd systems
ps3 also supports iso9660, udf, fat, netfs (?)
but it seems for now only fat can be used on usb drive.
also, filesystem of /dev/flashX is FAT
UFS file system support obviously comes with BSD, but can be added to Windows (FFS, or Crossmeta), Linux (compiled into the kernel), OSX, Solaris and so forth.
It opens up quite a few possibilities. The most obvious is the ability to read/write to a PS3 formatted harddrive once its removed from your console. A far more interesting possibility would be finding a way to allow the PS3 to use UFS on USB devices. The FAT 4GB file size barrier would then become a non-issue.
EDIT
This has been known for quite some time
UFS
The PlayStation 3 game console uses UFS2 on HDD. The PlayStation 2 HDD used UFS as well.
It is great that someone else is studying the PS3 though :)
mc5 25.10.2010 19:47
Panowie podziwiam Was za chęć zabawy, ale ja już kolejny raz kupiłem sobie przedmiot z tej stronki (zresztą na Allegro większość jest z tej stronki) i może trwało to tydzień , ale mam i cena mi odpowiada.
obibox 25.10.2010 17:01
Berion - co do podstawki to twoje wątpliwości rozwieje jak tylko znajdę suwmiarkę, po tych podstawek do 18F2550 mam wiele, kupiłem właśnie pod ten układ i okazały się zbędne, zmierzę i napisze, o!
edit:
http://img513.imageshack.us/img513/4...ypodstawki.jpg
tylko te moje to nie są precyzyjne a zwykłe, precyzyjne sa bardziej odporne na wielokrotne wyjmowanie/wkładanie ukladu ale wymiary powinny być identyczne.
Wszelkie inne wątpliwości rozwiewa nota aplikacyjna układu http://ww1.microchip.com/downloads/e...Doc/39632e.pdf np wymiary dla SDIP (potocznie DIL) są na stronie 413 tego dokumentu.
Dla chcących wykonać identyczne jak moje Picgroove mam jeszcze 3płytki pod tajle w smd (kondensatory), układ montuje se po stronie druku, zero wiercenia
http://img183.imageshack.us/img183/6396/plytki.jpg
mateusz232 25.10.2010 16:54
wieeelkie dzięki chłopaki :D
Berion 25.10.2010 16:52
Wszystkie nowe gry, wydane w nadchodzące święta.
A te które wymagają płyty to nie wiem. Prędzej czy później coś na nie wymyślą żeby tylko z HDD wstawały. ;]
mateusz232 25.10.2010 16:48
Napisany przez tom12342 (Post 1124858)
To kupuj u mnie break ja mam tanie i w niektóre gry pograsz a w przyszłości moze kupisz napęd gdzieś.
Po ile masz brejki ? (znajomy ma do sprzedania za 50zł bo mu na 3,5 nie smiga i właśnie tego breaka sobie upatrzyłem :D) I jakie gry nie będą działać jakąś lista jest ?
tom12342 25.10.2010 16:44
Napisany przez mateusz232 (Post 1124857)
Tak konsola śmiga w menu
mateusz232 25.10.2010 16:41
Napisany przez tom12342 (Post 1124855)
A działa ci konsola bez napędu (wjęty), menu i wogóle, jak tak to jest szansa bo na jakimś formu czytałem ze ludzie z padniętymi laserami sie ucieszyli ze jest break. Gry byś mógł właśnie z dysku usb wrzucać lub przez kabel sieciowy.
Berion 25.10.2010 16:41
@mateusz232
Tak, nie wszystkie. I tylko do gier, które wymagają co najwyżej fw 3.42.
Napisany przez obibox (Post 1124848)
Podstawka pod SOIC28 = "SOICT28" no problem - tada: http://elecena.pl/product/62691/soict28
170zł? :wow:
Huh, czyli dla mnie nadaje się tylko SDIP.
A powiedz mi: czyli 28pinowy PIC18xxxx wejdzie mi na tą małą podstawkę (na fotce parę postów wstecz)? Tj. na 28 pinową "wąska-precyzyjną" (jak ją babka w sklepie nazwała), tak? Dla 40 pinowego PICa potrzebowałbym takiej samej tylko 40 pinowej tak? A więc ta "szeroka-uniwersalna" mi się nie przyda?
tom12342 25.10.2010 16:39
obibox 25.10.2010 16:38
na 99% tak, ale zapomnij o grach wymagających mimo wszystko płyty z grą z napędzie np. GOW3 wersja europejska
mateusz232 25.10.2010 16:30
Pytanie do posiadaczy tego sprzęciku :)
Padł mi napęd w konsolce i wyjąłem go z myślą naprawy a uwalili mi go w moim serwisie w mieście :(
Da rade bez napędu z tego sprzęciku odpalać gry np z Pendrive ?
Dzieki za odpowiedz :)
frog 25.10.2010 16:28
@Gruszka PL3 to kolejny payload czyli wsad ktory wrzucamy na naszego JBLa. Obojetnie , wgraj najnowszy PL3 lub HERMES v4b. Bedzie OK.
@Kuras 1001 i @krystiane50 jesli chcecie uruchamiac gry ktore wymagaja 3.42 to tak najprosciej wgrajcie sobie GAIA MANAGER 1.02 i powinno byc po problemie ;>
@Nerii sprawdz sume MD5 twojego pliku z softem 3.41 ktorym aktualizowales czy ma wartosc e07d2b84c9e9691c261b73e5f1aada20 jak podal @Pawlakoss
obibox 25.10.2010 16:04
wszystko da się w elektronice zrobić tylko nie zawsze się opłaca (szczególnie na produkcję jednostkową)
SMD to zbyt ogólny opis ponieważ obudów dla smd jest wiele ale pewnie chodziło o SOIC ponieważ PIC18F2550 występuje tylko w dwóch typach obudowy SDIP (wzykła nóżki) i
SOIC (króciutkie nóżki + zmniejszona obudowa) Apel:posługujcie się nazwami z not katalogowych to będzie łatwiej doradzić :)
Berion 25.10.2010 15:20
:hmm:
SMD > http://en.wikipedia.org/wiki/Surface-mount_technology
DIP > http://en.wikipedia.org/wiki/Dual_in-line_package
W jaki sposób więc mógłbym PICa SMD wrzucić w podstawkę? Po mojemu to się nie da przecież.
StoQ 25.10.2010 11:44
tak będziesz mógł jeśli włożysz w podstawkę :) a mój jest smd więc trzeba by robić pajączka :) mi się niestety do tej pory nie udało odpalić programatora.. niby komp go widzi ale winpic800 nie widzi mojego micro :)
Berion 25.10.2010 10:42
Czyli Twój jest w SMD, a więc z tego wychodzi, że go nie wsadzę w podstawkę tak? No to odpada, bo ja chce na jednej płytce zrobić programator i jb - bo jak rozumiem, to będę mógł wyjąć PICa z jb i przełożyć w podstawkę do programatora, tak?
StoQ 25.10.2010 10:34
Pod pic zwykly czyli nie smd w normalnej obudowie bedzie ta 28 pinowa waska podstawka..
pod pic w obudowie smd nie ma podstawki. przylutowuje sie do tych 4 nużek po druciku :) i starczy, albo robi się nową płytkę ale to trzeba trawić :) chodzi o to że jakbyś chciał upchać psgroopic do jakiegoś starego pendrive to takiego zwyklego w dużej obudowie nie zmieścisz a w obudowie smd dasz rade :) bo jest dużo mniejszy :)
Berion 25.10.2010 10:30
Zgubiłem się. Jaki to jest zwykły a jaki "niezwykły" PIC?
StoQ 25.10.2010 10:24
smd jest 3 razy mniejszy od normalnego :) i pod zwykly pic18f2550 dobra bedzie ta wąska 28 pinowa podstawka :)
Berion 25.10.2010 10:18
Pytałem o szerokość bo co jeśli ten 28pinowy będzie szerszy od podstawki. ???
I co to znaczy, że "jest w obudowie smd". Nie znam się. ;]
Czym się różni PIC18F2550-I/SP od PIC18F2550? Może byłbym chętny.
StoQ 25.10.2010 10:05
Pic18f2550 ma 28 nóżek czyli ta wąska mniejsza.. a pic18f4550 ma 40 nóżek więc ta większa. wszystko zależy od tego który użyjesz i którego dostaniesz w shop :)
tak przy okazji mam do sprzedania pic18f2550 i/co w obudowie smd przez co można fajnie zmiejszyc psgroopic i upchać go np w starym pendrive :):) cena to 17 + koszt listu :) PW
a przy okazji. programować ktoś tego pic może za pomocą PICKIT2? Bo okazało się że moja uczelnia takie posiada programatory :) i chciałbym spróbować tam to zrobić.. Czy program MPLAB to pociagnie? bo właśnie tego dedykowanego tam uzywają i nie pozwalają wgrać nic innego :)
Berion 25.10.2010 09:33
Napisany przez NeRii (Post 1124749)
kurcze wtopilem. tez mialem 3.40 wersje robilem update tydzien temu i ku wa nie moze jej zupdatowac. Co wlacze to w kolko probuje bez sktutku. w sumie sciagalem wersje z poradnika na programosy bez sprawdzania czy ktos mial podobny problem? ogolnie w ps mialem niepewny dysk czy to mozliwe ze od tego nie moze wbic aktualizacja?
ps. dzieki za schemaciki
3.41 RevA miał problem z update'm jeśli dysk był inny niż ten oryginalny. Jak rozumiem, to konsola się już nie włącza poprawnie tylko loopuje z tą instalacją tak? Jeśli tak to masz poważny problem. Trzeba było użyć 3.41 RevB, który naprawił tego buraka.
Napisany przez robotm
Elotrolado właśnie wypuściło update OM 2.1G
OBM jest obecnie w najwyższej wersji 1.17. To jest ichnia wariacja, oparta o stare źródła. Ponoć najlepszy obecnie to Gaia Manager v1.02.
Tak BTW to wszystkie te programy są ubogie. Nie robi się opcji na buttonach, tylko na menusach. Pliki językowe mogły być wczytywane z zewnątrz, a nie każda wersja skompilowana osobno pod język, co za bzdura (już wiem co będą ludziom wgrywać teraz na allegro :D).
Mógłby mi ktoś podać rozmiary PIC18xxxx? Nie wiem jaką podstawkę zalutować, a nigdzie tego info nie mogę znaleźć. Mam takie dwie i nie wiem, która się nada:
http://forum.cdrinfo.pl/attachments/...anty_do_jb.jpg
roxman 25.10.2010 06:44
a co jeszcze oprócz jezyków w nim nowego ? bo polski mało potrzebny akurat tutaj jest a czytając po włosku nic nie rozumiem
robotm 24.10.2010 23:56
Co ciekawe :
"Added two new languages, Polish and German."
Nie wiem kto przyłożył "rękę" do lokalizacji, ale z tego miejsca :
WIELKIE DZIĘKI !!!
http://www.elotrolado.net/hilo_open-...xterno_1504137
NeRii 24.10.2010 22:53
krystiane50 24.10.2010 18:00
allegro.pl/psgroove-jailbreak-teensy-hermes-v4b-dziala-i1286914492.html
Od tego sprzedawcy możesz smialo brać to Teensy 1.0 na dobrym układzie. Problemem jest to, ze jest sczepione z obudową SD/MMC aby aktualizować paylody trzeba nacisnąć tzw RESET button. W kazdym badz razie dobry wybor.
Najlepszym sposobem jest firmware 3.41 zaktualizuj z tej strony
czy na tego teensy da sie wgrac najnowszego PL3 na którym działają gry wymagające 3.42??
O! I czy jest na nim już wszystko wgrane, że wystarczy podłączyć i grać czy trzeba wgrac tego hermesa??
gruszka89 24.10.2010 16:50
moze ktoś wyjaśnic o co chodzi z tym PL3? to jest odpowiednik hermesa? działają na nim te same managery? i skąd to wziąć tak przy okazji ;)
tomekmaster8 24.10.2010 16:31
Dzięki za odpowiedź upewniłem się i zamawiam teensy :)
Pawlakosss 24.10.2010 12:48
@tomekmaster8
http://www.eurasia.nu/wiki/index.php/Ps3OsRels
Sciągnij v3.41 Aug 02 2010
Silent second full release (PS3UPDAT.PUP). This works with PS Jailbreak. Make sure you verify the MD5 before install!
Mozesz się upewnić sciągając http://www.softpedia.com/progDownloa...oad-22900.html tym celu musisz:
-Sciągnij powyzszy program MD5
-Wklej e07d2b84c9e9691c261b73e5f1aada20
-Wybierz scięzke do firmware 3.41
-Kliknij Verify
Jesli kod bedzie sie zgadzał mozesz zaktualizować ;)
@mikas masz wyżej :P
mikas 24.10.2010 12:20
Napisany przez tomekmaster8 (Post 1124609)
dodam że mam soft 3.40 i czy Jailbreak będzie śmigał na nim czy jednak koniecznie musi być soft 3.41
Sam mam obecnie soft 3.40 i kupując teensy muszę uaktualnić do 3.41. Tylko dla pewności chciałem upewnić się na forum czy soft z tego linka będzie pasował ?
http://downloads.exophase.com/685/ps3-firmware-341/
Czy ten soft jest uniwersalny pod wszystkie regiony i będzie miał polski język itp. Wolę się upewnić niż coś skopać i potem tego żałować.
tomekmaster8 24.10.2010 11:22
Witam wiem że to już było nie raz ale mam pytanie czy to jest opłacalny zakup tzn czy można go w pełni bez problemowo aktualizować
tak jak samoróbki
z góry dziękuje za odp :)
kuras1001 24.10.2010 08:02
Zainstalowałem ten soft pl3 najnowszy ale Medal of honor nie działa.Komunikat na ekranie :aktualizuj soft do 3.42:.Oczywiście klikam na nie.Jak odpalić gre która wymaga softu 3.42
obibox 24.10.2010 07:08
Napisany przez pawelekk24 (Post 1124582)
instaluj v4b mi niektóre gry nie dzialaly na v3 teraz jest ok choc juz jest nowy soft PL wlasnie go testuje i jest ok dzialaja gry co wymagaja 3.42
jesli ktos zainteresowany jest mam gotowe JB na picu dziala upgrade w obudowie
cena jak dla osob z forum 85zl roboty jest przy tym troche i nerwow i prosze nie marudzic ze drogo przy kupnie prosze pisac forum cdrinfo http://allegro.pl/ps3-jailbreak-aktu...283326822.html
bez obrazy, ale po cholerę to co sprzedajesz jest takie dupne? jeszcze piszesz że te "jednoczęściowe" są fe bo się mogą zepsuć,to pudło dopiero ma szanse na awarię:
z kilku powodów:
- niepotrzebne użycie kabla który może się poskręcać,połamać urwać
- masę własną w przypadku upadku wróżę zgon
- zastosowanie obudowy, kabla , elementów mocujących płytkę i o zgrozo ten paskudny przelącznik podnosi tylko koszta niepotrzebnie i wprowadza Cię w nerwowy stan przy montażu i kosztuje więcej czasu przy montażu
Nie ma w nim nic takiego czego nie da się zrobić na płytce 1.5mm. 50mm maksymalnie że o mobilności tego nie wspomnę .... i dlaczego śmiesz nazywać to Jailbreak skoro jest PSGrooPIC :sciana: Ciekaw jestem co tyle miejsca tam zajmuje oprócz powietrza i jak jest przymocowana płytka do obudowy, byle nie na klej... pokaż środek :)
pawelekk24 24.10.2010 04:20
kuras1001 23.10.2010 23:14
Mam pytanie odnośnie softu, mam hermesa v3 czy warto instalować v4 ,cz jest jakaś różnica.
arcade 23.10.2010 20:08
Ano, ten LPT będzie bolesny. Nie mam jak go zamontować (nie mam z czego zrobić obudowy).][/QUOTE]
Berion nie martw się dlatego napisałem żeby płytka ciasno wchodziła między piny, jak polutujesz piny to lut już zacementuje płytkę pomiędzy pinami tak ze się nie będzie wyrywać dodatkowo możesz oblutować tez puste piny żeby lepiej trzymało.
robotm 23.10.2010 17:38
Napisany przez elwin88 (Post 1124333)
Witam mam problem może wynikający z mojej niewiedzy mogli byście mi podać jakieś schematy ponieważ chciałem zrobić w domu usb TEENSY 1,0 oparty na układzie Atmela Atmega 32U2 flash 32 kb. Jednak wszystkie schematy które znalazłem są na Picu .Jeśli mogli byście podać jakieś linki do sprawdzonych schematów to będę wdzięczny .
http://www.pjrc.com/teensy/schematic.html
Napisany przez krystiane50 (Post 1124460)
zadam pytanie nieco z innej beczki które byc może już padło (ale raczej nie w tym wątku). Codzi o wymianę dysku w konsoli:
-to, że 2,5" to wiem, ale nie wiem czy konsola musi mieć SATA czy może też być SATA II (i w ogóle czym się różnią oprucz ceny?)
-5400 obr czy 7200? niby jest różnica w poborze prądu (ale to mnie akurat nie interesuje zbytnio :P) i nagrzewaniu się - czyli jeśli zrobię sobie dłyższy seansik przy konsoli albo zostawię na noc to przepali mi się ona czy co?
-i ile ma pamięci cache standardowy dysk? 8 czy 16mb?
A może tak :
http://www.ps3hax.net/showthread.php?t=14877
Taniej :) i jak się postarać to można też i elegancko ...
frog 23.10.2010 17:18
Napisany przez Berion (Post 1124503)
PS: co to jest chomik? Ja niedzisiejszy chyba. ;]
http://chomikuj.pl/ ;P zeby tak popularnego gryzonia nie znac ;P
Berion 23.10.2010 16:53
Dokształciłem się już na czym polega różnica pomiędzy LVP a No LVP. ;]
tom12342 23.10.2010 15:12
Berion, co do tego wtyku LPT to miałem taki sam, musisz go tylko solidnie zamontować zeby jak połączysz z płytką przewodami ci sie nie urwały. Ja mój programator Art2003 umieściłem w obudowie, jak chcesz możesz zobaczyć na moim chomiku, nazwa chomika to tom12342
arcade 23.10.2010 14:54
Witam Berion
kondensatory masz dobre to sa nie wartosci na nich tylko kod odczytu 104=100nf 224=220nf kwarc tez moze być,reszte napisze wieczorem dalszą cześć tot-urialu.
tom12342 23.10.2010 14:39
Na kondensatorach mam 224 i 104 - to jest ok bo to jest 22icztery zera=220000 pikoF =po skróceniu 3 zer daje 220nF (bo 1nF to 1000pF).
Co do rezystorów to tam napewno masz 220 Ohm czyli cerwony brązowy brązowy i czwarty pasek zależny od tolerancji (srebrny albo złoty), zresztą jak wpiszesz w google kody rezystorów to w grafice powinien być rysunek co i jak.
Kondensator na 25V będzie ok bo on wytrzyma pracując na 25V a jak miałeś tam niższe to może być. Pozdrawiam tom12342
Dołoże tu moje pytanie mam w moim urządzeniu móżkę 26 połączoną do masy bo programuje z Art2003 (co prawda z przeróbką bo napięcie brane jest z USB) ale zaznaczam tam to LVP, A na tych schematach gość daje rezystor 10kOhm miedzi n 26 i mase, czy to jest konieczne mój wcześniejszy schemat miał po prostu do masy. Nie moge zrozumieć tego co napisał o tym LVP pod schematami. Zamieszcze tu ten cytat:
If you do use LVP to program your PIC then its a MUST to use the schematic on the right to build. There is a very good reason for this. When you program a PIC with LVP enabled (aka checkmarked in winpic800) but do not ground the LVP pin using a 10kohm resistor (i have heard 4.7k ohm resistor will work too) the PIC may randomly enter LVP mode (the result is your pic will constantly be recognized then not recognized over usb). A downside to using LVP is if you have LVP disabled (aka unchecked in winpic800) and you require LVP to program, you will lock yourself out of that PIC and will require a different method to flash the PIC with your programmer.
Berion 23.10.2010 14:09
To ja już się zgubiłem trochę z tym rezonatorem/oscylatorem. Byłem dziś w sklepie i co prawda potrzebnego PICa nie było, to kupiłem stuff pod programator i jb. Jako, że są niepodpisane albo ja jestem ślepy, zawierzyłem babce moją kartkę i o to efekty (w załączniku; pewnie coś jest nie tak ;)).
Na rezonatorze (?) napisane mam tylko 12000Hz, czyli chyba ok.
LPT i podstawki wygrzebałem z szuflady (nie wiem czy któraś się nada), mam też jedno męskie i jedno żeńskie USB, których nie ma na zdjęciu. Nie wiem czy dobre to LPT ale innych chyba nie ma - no i problem będzie z zamontowaniem... są może takie, tylko prostopadłe?
Na kondensatorach mam 224 i 104. To normalne czy mnie oszukali w sklepie i muszą być koniecznie 220 i 100?
47uf 15V - kondensator elektrolityczny
Na tym co ja mam jest 25V. Czyli nie nadaje się?
Nie wiem też jak odczytywać te kolorki. Jest gdzieś jakaś ściągawka?
tom12342 23.10.2010 13:17
Berion tam gdzie pisałem o kondensatorach 22 piko to są kondensatory do kwarcu, na tym schamacie nie są narysowane bo tam jest generator z kondensatorami i kwarcem juz w środku, ten gość napisał ze tak jest prościej bo mniej miejsca zajmuje na płytce niż osobno kwarc + dwa kondensatory do niego. Natomiast te kondensatory narysowane na schemacie są OK 100nF i 220nF (w moim urzadzeniu mam 470nF zamiast 220nF, według innego schematu i też dizła).
frog 23.10.2010 12:45
SATA od SATA2 roznia sie szybkoscia transferu danych. Oczywiscie w PS3 tego zbytnio nie odczujesz ( to samo z buforem 8MB starczy) wiec bier tanszy. Obroty tez lepiej 5400 zeby mniejszy piecyk w konsoli byl. Lepiej dodac $ w wieksza pojemnosc niz w te lepsze atrybuty jesli chodzi o ps3 takie moje zdanie.
krystiane50 23.10.2010 12:33
Berion 23.10.2010 10:56
Napisany przez marynarz (Post 1124269)
LVP = Low Voltage Programming
To czytałem, ale jaka jest różnica pomiędzy low level a high level - dla mnie jaka jest to różnica? Bo nie wiem którego schematu używać.
Przeciez wiekszosc jest wytlumaczona w tekscie pod rysunkami bardzo latwym angielskim.
Rzecz w tym, że nie chodzi o angielski, tylko o sens zdań. Jest to mój drugi w życiu epizod z lutownicą i składaniu jakiś wynalazków.
Napisany przez Tom12342
Chyba chodziło ci o wartość 22pF (piko Farrand). 22pF daje sie do kwarca (rezonatora) 8MHz.
Pozdrawiam tom12342
Czyli na schematach jest błąd? To są piko (pF) nie nano (nF)?
Napisany przez arcade
Witam ,no widzę Berion ze wreszcie się zdecydowałeś spróbuję ci pomóc.
Czasy takie, że trzeba się nauczyć i zrozumieć (albo płacić kupę kasy za nic...). Ale spoko, dam radę. :]
Dzięki za pomoc.
Zacznij od programatora Art2003 najprostszy i najtańszy koszt około 5zł. Pająka możesz potem zrobić ale programator obowiązkowo potrzebny,bootloader-a musisz nim najpierw wrzucić dlatego podstawka IC dla wygody potrzebna ci będzie.
Niezbędne materiały:
W sumie można, mam dostęp do różnych programatorów dlatego pominąłem tą kwestię, ale chyba jednak zrobię samemu.
arcade 22.10.2010 22:35
Witam ,no widzę Berion ze wreszcie się zdecydowałeś spróbuję ci pomóc .
  • 2 x 28 lub 40 pinowe gniazdo(podstawka w zaleznosci jaki mamy PIC czy 28-40 pin) IC
  • 1 x 220Ohm - rezystor 1/4W
  • 1 x 47uf 15V - kondensator elektrolityczny
  • 8 x 1N4148 lub 1N4448 diody
  • 1 x D25 - męskie LPT czyli wtyczka z kabla od drukarki.
  • płytka uniwersalna ,według mnie najlepsza najtańsza bez żadnych ścieżek tylko dziurki o rozstawie takim jaki ma podstawka pod mikrochip i grubości 1.5 mm żeby się klinowała ciasno między rzędami pinów LPT od strony lutowania. Ok a teraz do dzieła ,z tyłu LPT ma ponumerowane piny (tzn od strony lutowania) przyjrzyj się dobrze pod światło to znajdziesz numerki ,więc korzystając ze schematu patrz na numerki nie na zdjęcia wtyczki bo się pomylisz.
  • jak polutujesz te diody (pamiętaj diody nie jest obojętnie którą stroną lutujesz ) korzystaj ze stronki w google wpisz art2003 widać doskonale jak je przylutować.
  • kondensator ma pasek z jednej strony to jest oznaczenie ze z tej strony jest minusowa nóżka(ceramiczne maja minus na prawej nodze jeśli patrzymy na napis na nim )
  • jeśli wszystko polutowałeś wejdź do biosu swojego peceta i sprawdź czy wejście LPT pracuje w opcji ECP jeśli nie to wybierz ją zapisz bios i ruchom ponownie PC.
  • ściągnij winpic800 i zainstaluj
  • ściągnij Microchip MCHPUSB Bootloader hex
  • zamontuj PIC-a w tym programatorze podepnij do portu LPT i uruchom Winpic800 w okienku po prawej stronie wybierz PICf18 i następnie twój model
  • następnie kliknij kwadracik ze zieloną strzałeczką i napisem pod-spodem (dev) winpic800 powinien wykryć twój chipset jeśli nie wykrywa zamknij winpic800 dociśnij porządnie programator (pewnie nie siedzi dobrze w gnieździe )
  • jeśli wykryje twój układ wybierz plik hex bootloader i naciśnij czerwoną strzałeczkę układ powinien się zaprogramować w 3-5 sek. możesz jeszcze dać zweryfikuj jeśli jest ok. to możesz zaczynać robić pajączka ale również na podstawce IC tak jest najwygodniej.
  • A zapomniałbym dla wygody nie załuj mazaka i sobie zaznacz gdzie jest 1 pin (patrząc na układ z jednej strony ma wyzłobienie lewy to pin 1 prawy to 28 lub 40) z resztą na schemacie od iLLNESS-a jest to super widoczne
  • Powodzenia.
elwin88 22.10.2010 21:18
marynarz 22.10.2010 19:34
Oczywiscie ze piko. Z rozpedu napisem nano ale nie moge juz edytowac posta.
tom12342 22.10.2010 18:22
Oscylator ma w obudowie kondesatory (rzedu 22-30nF i kwarc). Rezonator (2 nozki) nie ma i trzeba dolozyc.
Poza tym jest duzo tanszy. Tutaj ma znaczenie dlugosc drutow. Podlaczasz obie nogi do procka i dodatkowo kazda noge przez 22nF do GND.
Napisane ze ma byc podzielny przez 4. wiec kupujesz np. 12.000MHz jak autor.
Pozdrawiam tom12342
marynarz 22.10.2010 17:31
Takie male kondensatory to ceramiczne moga byc http://www.nikomp.com.pl/opisy/KA000/KAE00000.htm
Rezystory weglowe 470 Ohm http://www.nikomp.com.pl/opisy/RC000/RCA02040.htm
Sa do diody LED wiec nie musza byc precyzyjne. Ten 10k to pewnie podciagajacy wiec tez bez znaczenia.
Oscylator ma w obudowie kondesatory (rzedu 22-30nF i kwarc). Rezonator (2 nozki) nie ma i trzeba dolozyc. http://www.nikomp.com.pl/cgibin/shop?search=rezonator
MCLR is the pin that resets the PIC or enables the PIC. Czyli jest to wejscie reset. Opis po angielsku jest dobry.
RB i RC to porty a te zolte i niebieskie piny moga tez sluzyc do podlaczenia LEDow.
Berion 22.10.2010 13:25
Zdecydowałem się zbudować samemu i prawdopodobnie będzie to droga przez ból, ponieważ nie umiem odczytywać schematów.
No więc tak, na warsztat biorę schematy stąd:
http://psx-scene.com/forums/f178/ill...-thread-67940/
A teraz pytania:
1.) Jakie to są kondensatory (trochę ich jest)? Obojętnie jakie byleby miały 100 i drugi 220 nano Faradów?
2.) Podobnie jak wyżej, jaki to ma być opornik? Istotna jest tylko jego "oporowość" (czyli 470/10000 Ohmów - zależnie od schematu)?
3.) Oscylator:
Na schemacie nie zaznaczony (w zastępstwie rezonator?). Nie rozumiem też tego:
You can use a crystal instead, but you need to use 2 capacitors as well with it increasing your board size and the complexity of the circuit. If you do use crystals, you must make sure the crystals connect to the OSC1 and OSC2 legs of the PIC as well the capacitors for this crystal connect to one leg each of the crystal with the other leg to gnd.
Czy to ilu MHzowy będzie, ma znaczenie przy programowaniu kości (w programie widzę taką opcję)?
4.) MCLR
If you follow my hexes exactly and do not hold pin1 high, then make sure MCLR is disabled
5.) Jakie ma znaczenie LVP?
6.) Co oznaczają na schemacie: RC0/1 RB1/4/5 i czemu są tak pokolorowane?
I've marked the LED compatible output pins in YELLOW so it's easy to see, as well as added a second type of LED marked in BLUE, RC1
Nie rozumiem tego.
7.) USB może być żeńskie?
8.) Czy można użyć zamiast płytki, kabelków (innymi słowy: zrobić pająka)? Powiedzmy, że kynarowych. Jeśli tak to czy długość ma znaczenie (podejrzewam, że duże)?
mikas 22.10.2010 13:06
Napisany przez Pawlakosss (Post 1124143)
Jeszcze mam takie pytanie, z aukcji Teensy 1.0
http://allegro.pl/teensy-1-0-usb-dev...266183924.html
Gosciu mowił, ze to bedzie AT90USB162 a dostałem, gdy instalowałem sterowniki Amtela - Atmega32U2. Jest to jakaś róznica ? Gdy w przyszłosci bede chcial updatetowac to na jaką płytkę mam wybrac payload ?
Też chciałem kupić od tej osoby i wydaje mi się że ten układ Atmega32U2 jest lepszy ale jeśli nie to poprawcie mnie.
pawelekk24 22.10.2010 12:50
jakos nie przekonuje mnie ta przeróbka chyba kupie xboxa z Jtag xbr wieksze mozliwosci
frog 22.10.2010 12:40
Chcesz sprzedac ? No nie wiem. W sklepach najtaniej po 899zl nowe konsole sa z wiekszym dyskiem. Zerknij na allegro. Tyle ze masz tego JB. No ale mysle ze napewno nie tyle co nowa. Chociaz moze ktos akurat poszukiwac FATA ktorego juz ciezej dostac ;>
pawelekk24 22.10.2010 12:24
mam pytanie ile jast warty ps3 80gb fat z psgroopic dopiero od kilku dni troche go testuje jak zrobilem JB jeszcze na gw do grudnia
malo uzywany bo kupilem go tylko ze wzgledu na teekena 6 i grand turismo 5 ale tekken wyszedl na xboxa 360 wiec dalej lezal w pudle i gralem na xboxie
frog 22.10.2010 12:14
Dales linka do PS3 BREKA nie JAILBREKA.
Zaden uklad nie wspiera wyzszego firmwaru.... Moze kiedys.... Na szczescie patent na gry wymagajace wyzszego jest. I dziala..... poki co....
pawelekk24 22.10.2010 11:57
http://allegro.pl/jailbreak-najnowsz...264516404.html
niestety nowy JB nie dal zadnych nowych zmian nadal tylko soft 3.41
wgrany hermes v4b
programowalem uklad pic 18f4550 najnowszym wsadem z tego JB nie dziala pewnie jakis inny schemat budowy zastosowali
frog 22.10.2010 11:27
Napisany przez pawelekk24 (Post 1124158)
najlepsza ciekawostka ze nowy jb v1.2 jest na picu
a tak bozyli na niego wszyscy chcieli amtela
Nowy Jailbreak ? Nie slyszalem o nim. Pokaz linki jak mozesz...
Moze masz na mysli nowy uklad MAXIMUSA ? or inny ;P Bo ten faktycznie jest na PICu. A z prostego powodu... JEst swiatowy deficyt na uklady atmela i jest tanszy.
pawelekk24 22.10.2010 04:02
pawelekk24 22.10.2010 03:58
Napisany przez perlas (Post 1123431)
witajcie
ogarnalem pare stron tego tematu i mam jedno pytanie do znawców :D
jeżeli JB może być wykryty przez korzystanie z PSN, nawet jeżeli go wyciągne mogą dojść po obecności na dysku loadera czy innych plików...
a co jeżeli miałbym drugi mniejszy dysk tylko do grania online?
Zapomnij o graniu online nie polaczysz sie z psstore granie online wymaga zawsze najnowszego softu chyba ze cos wymysla na wysze softy ale watpie
arcade 22.10.2010 00:52
Pewnie hex nie pasuje i dlatego miga ale nie trybi.
W komputerze zachowuje się inaczej niż w konsoli to normalne.
Witam angielski kompletny tuto-rial na PIC-a , działający na 100%.
Made in iLLNESS.
Jeśli ktoś ma czas to by go przetłumaczył na PL.Jeśli ktoś umie angielski to jest to jedyny jaki znalazłem tak wyczerpujący opis na ten temat i nie robiący wody z mózgu.
Na psgroopic jest niby wszystko ale niestety te hex-y trzeba przerabiać i po wgraniu nie chodzi to tak jak powinno ,bo schemat jest inny niż te hex-y niby do niego.
100% zrobił iLLNESS z psx scene.Dopracował hexy hermesa i KaKaRoTo tak żeby śmigały bez żadnego problemu według jego schematu .
Jest to kompletny scenariusz jak zrobić to na pic-a i hex-y są również na tej stronie ,najbardziej aktualne w sieci i działają na pewno na 3.15 ,3.41 sprawdzone.
Po krótko powiem ze części to znajdziemy w domu na pewno, potrzeba tylko sam mikrochip kupić.
Programator Art2003 wpisać w Google ,jest tez potrzebny ale jest tak prosty ze w godzinę go zrobimyUkład najpierw trzeba zaprogramować tzn. wgrać mu bootloaderBootloader hex
Soft do programowania Winpic800 jest tam również do zassania jak i schemat.
frog 21.10.2010 23:45
Pawlakoss u mnie zaswieca sie jak w konsoli tylko na chwile przy uruchomieniu. A w komputerze tylko jak nacisne buttona i jest w trybie programowania...
Pawlakosss 21.10.2010 23:20
Rurka termokurczliwa ? ;)
Dokładnie dzięki mig
:P
W ogole świeci Wam sie tam dioda jak załączacie jailbreak ? Bo u mnie tylko po włozeniu do kompa ;)
mig25 21.10.2010 19:19
NeRii , tu masz najbardziej aktualny i rozwojowy temat odnośnie PSGrooPIC : http://psx-scene.com/forums/f178/ill...-thread-67940/
Jeśli kupisz na aukcji ,np od kolegi tom12342 to nie bedziesz go musial programowac programatorem ,bo juz bedzie zaprogramowany i bedzie mial bootloader ,czy li bedzie go mozna pozniej programowac podlaczajac do usb komputera ,bez zadnego programatora.
A co do kosztów , to tyle za ile jestes w stanie kupic PICa... reszta czesci mozna znalesc np w starym pendrive ;) ,kwarc,kondensatory,wtyczke USB ,nawet obudowę.
NeRii 21.10.2010 18:17
Napisany przez tom12342 (Post 1123949)
Witam. Ja polecam urządzenie które zrobiłem sam, na PICu 18f2550.
Urządzenie bardzo solidnie zrobione, możliwość aktualizacji po przełożeniu zworki,
psgroopic cały czas sie rozwija (obecnie wersja 1.8b i 1.9).
Mam pytanie do osób mających i szukających takiego urządzenia. Co wam sie nie podoba w dostępnych urządzeniach?
to jak nie trzeba miec zadnego programatora? ile wychodzi koszt jb na picu? jaki flash?
qwerty123 21.10.2010 17:13
Witam wszystkich.
Mam jedno pytanie. Który z kluczy dostępnych na allegro jest najlepszy? Pojawiło się tyle klonów i podróbek że nie wiem który kupic. Zależy mi aby była możliwośc odpalania "kopii zapasowych" i aktualizacji klucza.
mig25 21.10.2010 16:55
Rurka termokurczliwa ? :)
Pawlakosss 21.10.2010 16:07
Mam pytanie z natury technicznej ;)
Nie wiecie moze jak sie nazywa fachowo ta guma,którą czech nakłada na teensy ? :)
frog 21.10.2010 10:46
@wltk orginal ps3key wystepuja z Atmela & Silabs chipsetami. Jak ludzmie maja atmele to czytalem wpisy ze 3x wlozyc i wylozyc dongla z portu USB i wtedy wchodzil w tryb programowania. Przy silabsach niby tego nie trzeba bylo robic tylko wlozyc i poczekac troche az sie tam na niebiesko zaswieci. Sproboj moze tak.
wltk 21.10.2010 10:12
[QUOTE=mig25;1123868]Podróbka ps3key czyli co tam w środku jest ? Pic czy atmel ?
Może spróbowa orginałami do PS3Keya:
no wlasnie problem polega na tym ze nie chce przejsc w tryb update ale wyglada ze to jest atmel ktos juz sie spotkal z takim problemem???
tom12342 21.10.2010 09:30
Napisany przez mikas (Post 1123878)
To nie lepiej kupić to samo taniej, chyba że się mylę i jest to coś innego?
frog 21.10.2010 01:12
@mikas widzialem juz troche komentarzy co kupowaly od magicboxa i byly zadowolone takze mozna tez od niego.
gruszka89 20.10.2010 23:42
powinno działać tak samo, jednak to to musi stwierdzić ktoś kto to kupił, cięzko stwierdzić jakość wykonania
mikas 20.10.2010 23:11
Napisany przez gruszka89 (Post 1123855)
u czecha jest teensy 1.0, zbudowane na at90usb162 16MHz o ile się nie mylę
http://allegro.pl/teensy-1-0-usb-dev...276754722.html
Berion 20.10.2010 22:51
Napisany przez roxman (Post 1123864)
i wież mi znam ten ból kiedy człowiek pyta się i otrzymuje odpowiedź i nie wie co z nią zrobić
Wierzę - i wyobraź sobie, że mnie też to niekiedy dotyka. Można "zapytać o odpowiedź", nie gryziemy (chyba, że są to już naprawdę pytania sięgające podstaw obsługi komputera). ;]
No dobra, chcesz FAQ. Inni pewnie też. Możemy takie coś zmontować na forum, jednakże potrzebowałbym pomocy od strony hardware (ja mam dwie lewe ręce). Więc tutaj apel to tych co już budowali te wynalazki i/lub mają jakieś doświadczenie w, nazwijmy to trywialnie, elektronice. Ja mogę jedynie zająć się stroną softu.
Możliwe, że później przeniesie się na główną - możliwe, że nie. Zobaczymy.
mig25 20.10.2010 22:45
Może spróbowa orginałami do PS3Keya: http://psx-scene.com/forums/f6/ps3ke...-v4-0-a-69084/
wltk 20.10.2010 22:09
wie kto moze jak dokonac update dla podrobki ps3key??? bardzo podobna do orginalu tylko gumka ta niebieska krotsza ;)
roxman 20.10.2010 21:51
Spoko ja pisałem na swoim przykładzie konsole mam może od 2 tygodni a może i tego nie pierwsze kroki robiłem tutaj na tym forum czytając to od deski do deski i wież mi znam ten ból kiedy człowiek pyta się i otrzymuje odpowiedź i nie wie co z nią zrobić teraz już kumam o wiele więcej i jak widać cały czas śledzę temat sam nie gram bo szkoda mi czasu ale mam 2 małych dzieci które mogą sobie w weekend czas umilic tym bardziej że zbliżają się długie zimowe wieczory kupiłem koło 12 oryginałów na początek starszych tytułów ale wiem że maluchom to szybciutko się znudzi i wole wiedzieć że mam jakąś alternatywę a czy z niej skorzystam czy nie czas pokaże na chwilę obecną bawię się w celach edukacyjnych i bardzo żałuję że nie jestem programistą bo z chęcią bym się pobawił w tworzenie czegoś według swego uznania ale na chwilę obecną brak wiedzy mi na to nie pozwala ale jeszcze troszeczkę czasu przedemną i zobaczymy a to że dużo ludzi idzie na łatwiznę to prawda ale faq właśnie tworzony jest po to aby nie pisali głupich powtarzających się postów tylko nie chcąc się angażować zrobić swoje i kwitnąć przed ekranem całą noc albo i dwie
gruszka89 20.10.2010 20:59
mikas 20.10.2010 19:21
Czy te układy czecha są na Teensy 1 bo tak mi napisał w emailu a myślałem że to wersja 2 ?
Berion 20.10.2010 17:12
Nie wiem, ale moją uwagę Zwróciła inna rzecz, obudowa. Czy taki gigant pomieści się z innym pendrakiem obok? ;]
mikas 20.10.2010 15:05
A czy to tez bedzie uklad teensy 2 jak u czecha, bo on ma obudowe i moze szybciej dojdzie
allegro.pl/jailbreak-ps3-przerobka-psgroove-ps3-key-teensy-i1272274706.html
Berion 20.10.2010 13:33
@roxman
Chodziło mi o to, aby pokazać że pewne rzeczy trzeba wiedzieć bo my ich z fusów nie wywróżymy. Nie wiem co wgrywają na alledrogo i na co, nie wiem też czy sprzedawcy są skorzy udzielać takich informacji swoim klientom. Rzeczywistość jest w tym przypadku (i w przytoczonym przeze mnie X360) taka, że jeśli nie wiesz co masz to nie bardzo jak jest pomóc (nie da się wszystkiego sprawdzić na odległość).
Co innego jeśli ktoś jest w stanie powiedzieć: "się nie znam, ale na kości jest napisane ABC, takie a takie gry chodzą, takie nie, mam taki a taki program, takie i takie komunikaty się pokazują, kupiłem wtedy a wtedy". To już może dać jakieś minimalne rozeznanie.
Sprawa druga: nie jestem zdania, że forum jest od pomocy (tylko i wyłącznie). Staram się promować ideę "potrzebuję - uczę się". I po to m.in się pomaga - aby uczyć się wzajemnie od siebie. Chciałbym i próbuję zainteresować nowo przybyłych sceną, zaszczepić w nich chociaż kawałek tej pasji. Zapewne daremnie... I absolutnie szkoda mi mojego czasu na osoby które chcą się tylko wiedzieć "jak odpalać piraty co je teraz ściągnęli, aha i szybko!!11!!1 oneoneone" (jednakże nie jestem sam na tym forum, to jest i dla nich światełko w tunelu ;P).
Scena nie jest dziś zamkniętą i elitarną "grupką 5 osób" (po za naprawdę ważnymi aplikacjami, ale nie mówimy tutaj o publicznych forach a zamkniętych + IM), także każdy może sięgnąć po w miarę spory kawałek wiedzy. Problemem może być nieznajomość angielskiego, są też inne, równie dobre niemieckie, hiszpańskie, francuskie i przede wszystkim ruskie borady.
Myślałem nad FAQ czy nawet tutorialami, ale dopóki nie wyklaruje się sprawa ze SCEA i pozwami serwisów nie chcę niczego takiego publikować (nie mam zresztą jeszcze żadnego JBka). Może w przyszłości, tymczasem polecam FAQi na psx-scene.com.
Z tym narzekaniem to nie wybiegaj tak daleko w stosunku do mojej osoby. Spójrz na PSX, PS2 i Xbox. Myślę, że napisałem nie jeden ciekawy FAQ i tutorial, często których nigdzie indziej nie ma (chyba, że mi ukradziony, co się często zdarza...). Także akurat ja to zbyt wiele nie mam sobie do zarzucenia. :P
Bartez 20.10.2010 12:42
Napisany przez roxman (Post 1123775)
No kochany to powiedz mi w takim bądz razie do czego jest to forum do intelektualnej dyskusji 5 snobistycznych osób zaznajomionych w temacie ?!?!! bo mi raczej sie wydaje że fora są tworzone po to aby się uczyć i poszerzać wiedzę w danym temacie. Jeżeli ktoś nie ma bezpośredniego kontaktu ze sceną która przeważnie jest zamkniętą dobrze znającą się grupą osób to skąd ludzie mają czerpać informacje ? wymiana wiedzy i doświadczeń tylko i wyłącznie przez forum. Jeżeli ty jako moderator zadecydujesz że temat został wyczerpany a dalszej dyskusji nie życzysz sobie na tym konkretnie forum to proszę zamknąć temat a ludzie przeniosą się na inne forum gdzie tego typu komentarze nie będą padać. A na innych forach aby bezsensowne pytania nie padały w kółko te same to robią działy FAQ gdzie są zebrane najczęściej zadawane pytania i odpowiedzi pod spodem ale komu się by chciało wybiegać przed szereg kiedy ponarzekać jest dużo łatwiej. Taka jest już nasza mentalność narodowa NARZEKAĆ na co się da zamiast się wziąść do roboty.
Forum jest zdecydowanie po to, żeby poszerzać swoją wiedzę i wymieniać się doświadczeniami i wnioskami. Problem w tym, że jest bardzo duża grupa osób, która chciałaby dostać wszystko na tacy, najlepiej od razu po napisaniu posta i bez jakiegokolwiek zaangażowania z własnej strony.
To właśnie pokazuje przykład przytoczony przez Beriona. Żeby komuś pomóc, to ten ktoś musi wiedzieć, o co pyta i musi znać jakiekolwiek podstawy, które można znaleźć w sieci po 10s z google. Ale po co, lepiej oczekiwać, że ktoś to zrobi za taką osobę.
frog 20.10.2010 12:30
@Mikas
http://allegro.pl/teensy-developer-u...265422533.html
@Roxman no zgodzie sie ze FAQ moglo by byc ale wiesz ze na innych forach mimo FAQ ludzie pytaja o podstawowe rzeczy ktore bez problemu mozna wyczytac z tematu o brejku lub faq jesli jest. Nie trzema miec dostepu do sceny i zagranicznych for do tego. I to jest wkurzajace. Ja osobiscie caly ten temat od dechy do dech czytalem i na innych pl forach. Niestety troche trzeba poswiecic jak chce sie tym bawic. A jak ktos nie chce nawet troche tego czasu poswiecic no to niech sie nie dziwi ze skorych do pomocy mniej.
roxman 20.10.2010 12:22
Napisany przez Berion (Post 1123752)
Już czuję w kościach, że nie długo zaleje nas fala ludzi, którzy kupili na allegro, "sprzedawca powiedział że działa", a nic na ten temat nie wiedzą...
- Jaki masz payload?
- Nie wiem.
- Na co wgrany?
- Nie wiem.
- Jaka pamięć?
- Nie wiem.
- Upgrade'owalny z poziomu PC?
- Nie wiem.
- Jaki backup manager?
- Nie wiem.
- Jaka jego wersja?
- Nie wiem.
- Używasz patch mode i jakiego?
- Nie wiem.
- No to nie możemy Ci pomóc.
- Do dupy to wasze @#$%^ forum wy %^&*@#$!
Już to czuję w kościach. ;) To jak z X360, jego fw i grami.
mikas 20.10.2010 12:10
move to dla mnie swietna sprawa a co do roznicy 300 zl to jest ona o wiele mniejsza kupujac ja w zestawie z konsola(na pewno w marketach).
Ale mam jeszcze jedno pytanko, wszyscy polecaja klucze od czecha, bo ma je tanie. Rozumiem ze jak sam nie chce go robic to kupujac je od niego uruchomie na tym wszystko nie tak jak na tanszych ukladach ? A jakis kontakt z ta osoba lub nick do aukcji mozna prosic.
frog 20.10.2010 11:19
neee napewno nie ja. Nic nie wiem o brejkach powyzej 3.41. @Berion kwestia gustu. Jeden lub miachac zarowka inny grzebac w homebrewach ;P Kazdy na swoj sposob robi uzytek z pleja ;P Dla mnie tez poki co to za drogi wydatek. No i tak jak @MAX napisal raczej na krotkie imprezowe zabawe niz zeby cala gre tym przelazic np ResidentEvil. Ciekaw jestem jak to ludzie ocenia na podstawie nowego Stara Wars Force Unleashed bo chyba ma obslugiwac..... Ludziom nadgarstki padna od machania mieczami swietlnymi ;D
loki7777 20.10.2010 10:55
Napisany przez frog (Post 1123754)
@Berion juz jest pelno takich pytan, tylko nie na tym forum bo tu ograniczone pole dyskusji jest ;p
A propo allegro to mnie ciekawi ta pozycja. Jak ten patenciarz to robi na firmware 3.50 bo jeszcze nie doczytalem na necie jak to wykminic :>
http://allegro.pl/show_item.php?item=1272795260
Nie dziala:) Ktos pisal o tym ze trzeba miec 2 ps3(czasami nie ty?). Bylem na oryginalnej stronie tego break'a i tez nic nie ejst napisane.
M@X 20.10.2010 10:51
Sports Champions - zabawa jest pierwszorzedna i to we wszystkich konkurencjach. To jest fajne w machaniu zarowka, a RE 5 i HR Move Edition to chybione pomysly - komu by sie chcialo robic to przez tyle godzin? Tylko i wylacznie krotkie, proste imprezowe gry!
Berion 20.10.2010 10:47
I co jest ciekawego w machaniu żarówką? :P Jak dotąd jedyne GRY, które używają Move to RE5 GE i HR. Ździebko mało, że by kupować coś co szybko będzie tanieć.
M@X 20.10.2010 10:40
po co Ci Move? ;] Warto za to dokładać 300zł?
Bezsprzecznie warto!
frog 20.10.2010 10:40
Berion 20.10.2010 10:33
Ja bym kupił gołą konsolę bez gówien. Po co Ci EyePet? Nawet po co Ci Move? ;]
Napisany przez Pawlakosss (Post 1123681)
Ja spotkałem sie z taką instalacją:
1. Skopiować folder GRA* do PS3: /dev_hdd0/game
2. Skopiować plik GRA.pkg* na zewnętrzny nośnik USB (dysk, pendrive)
3. Zainstalować GRA.pkg (Install Package Files) na konsoli PS3 w trybie Jailbreak
gdzie:
GRA* i GRA.pkg <- to nazwa gry ;)
A po co ten punkt pierwszy? Bezsens. Jeśli chodzi o drugi to lepiej było napisać: usb_0:/<nazwa paczki>.pkg ;]
I tak jak mówiłem, trzeba mieć payload wspierający instalowanie paczek retailowych. Pierwsze payloady pozwalają na instalację tylko debugowych. Można jeszcze wrzucić do tempa, wtedy XMB będzie ją rozpoznawał jako taki bąbel i z niego można zainstalować (jak ściągałeś kiedyś coś z PSN to pewnie wiesz co mam na myśli), tyle że do tego trzeba wygenerować jakiś bazodanowy plik (*.pdb), a nie widziałem nic takiego na sieci.
- Nie wiem.
- Na co wgrany?
- Nie wiem.
- Jaka pamięć?
- Nie wiem.
- Nie wiem.
- Nie wiem.
- Jaka jego wersja?
- Nie wiem.
- Nie wiem.
frog 19.10.2010 23:48
@mikas u nas ostatnio w media i w saturnie byly po 1399 z jakas gra Sports Champions. Wydaje mi sie wiecej frajdy niz ten eyepet no i ciut taniej Takze pozerkaj jeszcze po tych marketach jakie maja aktualne zestawy.
Wszystkie czasy w strefie CET. Aktualna godzina: 01:34.
