Stary 22.11.2026, 15:07   #46
secretgarden
Data rejestracji: 09.11.2026
secretgarden zaczyna zdobywać reputację <1 - 49 pkt>
I checked some brand-new BDR-212 drives, taken from factory bulk 5-pack packaging ,they all show identical readings: 1 hour and 14 minutes of "power on" time, the same number of power cycles, identical CD/DVD/BD timing results, and the same percentage values.
It seems they are tested at the factory using some kind of diagnostic software or simulation; I find it hard to believe that each individual drive would undergo over an hour of testing at the factory, though.
Załącznik 218257
The data looks fine. You might also want to try updating the software.
secretgarden jest offline   Odpowiedz cytując ten post
Stary 22.11.2026, 15:42   #47
Napisany przez secretgarden Podgląd Wiadomości
The latest version shows the same usage data for CD, DVD, and BD.
The drives are brand new, unused, and have been connected for the first time.
Since they all show the same data, they must undergo some form of diagnostic simulation at the factory. It is impossible for them to spend over an hour testing each individual drive on the production line.
Stary 22.11.2026, 16:00   #48
secretgarden
Załącznik 218258
The accuracy of the data can be verified by manually powering on the device for testing. I believe we can only speculate about what happens at the factory. Some resellers also retest and repackage the drives themselves; to be honest, one hour isn't really that much time. Moreover, the cumulative playback time for CDs, DVDs, and BDs is within a reasonable range.
Stary 22.11.2026, 16:06   #49
The drives come in their original factory master cartons, sourced directly from Pioneer distribution. The master cartons have never been opened; a few units were selected at random and tested, all show identical data, with a time value of 1:14, and display the exact same specifications for CD, DVD, and BD media.
Stary 22.11.2026, 16:29   #50
secretgarden
For your reference, here are the specifications for my brand-new XD05, which is currently functioning normally. The data preloaded on the drive can be set to a fixed value by production line tools before it leaves the factory; that's all I know at this point.
Stary 22.11.2026, 16:43   #51
Załącznik 218262
Most likely, there is some kind of final diagnostic test on the production line that simulates CD/DVD/BD read/write operations, as well as the opening and closing of the disc tray, at the end of the manufacturing process.
Stary 22.11.2026, 16:50   #52
secretgarden
Yes, in theory, all of this is part of the quality control within the standard production process.
Stary 23.11.2026, 19:58   #53
Oinker
Data rejestracji: 08.11.2022
Oinker zaczyna zdobywać reputację <1 - 49 pkt>
Talking
One of my 208Ds I got via eBay, like the UD03 almost unused as well.
Oinker jest offline   Odpowiedz cytując ten post
Stary 24.11.2026, 09:39   #54
secretgarden
Napisany przez Oinker Podgląd Wiadomości
You have a lot of great drives.
blue-ray, diagnostic, drive, optical, pioneer, tool
Wszystkie czasy w strefie CET. Aktualna godzina: 01:31.
