Stary 10.11.2026, 22:49   #16
Stingray
Data rejestracji: 12.02.2024
Stingray zaczyna zdobywać reputację <1 - 49 pkt>
Napisany przez Oinker Podgląd Wiadomości
2288 empty tray cycles!?
interesting.
I just loaded one empty BDR disc to my S12JX; the empty tray counter increased by one,
but the total number of discs loaded increased by two. Then I loaded a data disc, and the same thing happened. So, the total counter counts each inserted disc as two, because both counters add one. If you simply open the tray, everything is correct;only one empty tray is added.
Ostatnio zmieniany przez Stingray : 10.11.2026 o godz. 23:06
Stingray jest offline   Odpowiedz cytując ten post
Stary 10.11.2026, 22:59   #17
Stingray
BD loads does not make any sense.
It seems that the disk count on different models is not quite right.
I've checked about 10 Pioneer drives
one of my drive:
Loading Cycles 118 cycles
Total Discs Loaded 244 cycles (Empty cycles: 0)
CD Loads 204 cycles
DVD Loads 16 cycles
BD Loads 24 cycles
Ostatnio zmieniany przez Stingray : 10.11.2026 o godz. 23:08
Stary 11.11.2026, 04:34   #18
secretgarden
Data rejestracji: 09.11.2026
secretgarden zaczyna zdobywać reputację <1 - 49 pkt>
Ok, I checked my quality scans, I have almost 600 screenshots of quality scans from BD-Rs written with just that particular 208D, and I've written even more discs with it over the years, so I can confirm 100% positive that the number of BD loads does not make any sense.
Write quality is not directly related to diagnostic data, nor is it related to the number of BD loads. The upper limit of write quality depends on the drive's ability to control the OPU, and the duration of reliable write quality is limited only by the OPU's remaining lifespan. The data displayed by this diagnostic tool does not directly indicate the OPU's remaining lifespan.
If you believe that relying on a single data source is unreasonable, you should cross-reference it with additional quantifiable data.
secretgarden jest offline   Odpowiedz cytując ten post
Stary 11.11.2026, 04:37   #19
secretgarden
Napisany przez Stingray Podgląd Wiadomości
is it possible to change the calibration data in case of laser replacement?
I see data for old laser of my BDR-PR1M
Calibration 69136161763101500254171178+043-042+083271522C387A3+019+008+003-004901904403317071728301665
but it was replaced
In theory, it's feasible, but since these data come from Pioneer's production line, we need to know the production processes they use.
Stary 11.11.2026, 04:42   #20
secretgarden
interesting.
The load count is a feature that was added in the most recent version; the accuracy of the data parsing algorithm still requires further testing by everyone.
Stary 11.11.2026, 08:34   #21
secretgarden
Thank you all for your feedback. We have released version v1.4.1.0, which I believe will resolve the issue with the discs loaded. We look forward to your further testing and feedback!
https://github.com/RevokeTime/pion-b...es/tag/1.4.1.0
Stary 11.11.2026, 08:39   #22
secretgarden
Also added some explanations of the data:
About "Loading Cycles": A cycle is counted whenever the drive's tray or cover completes a single ejection or pop-up action, whereas a "Discs Loaded" event is only counted after the drive successfully recognizes and ejects a disc. Therefore, "Empty cycles" simply means that some ejection actions are performed solely to open the drive when there is no disc inside, which is why empty cycle counts exist, the calculation method is the "Loading Cycles" count minus the "Total Discs Loaded" (the sum of the number of CDs, DVDs, and BDs loaded).
Stary 11.11.2026, 10:50   #23
Napisany przez secretgarden Podgląd Wiadomości
There is no issue with reading calibration data, whether using a brand-new laser or a used one.
Pioneer blu-ray optical drive diagnostic tool-screenshot_2026-11-11-09-14-27-071_com.xiaomi.scanner.jpg
Stary 11.11.2026, 11:28   #24
Oinker
Data rejestracji: 08.11.2022
Oinker zaczyna zdobywać reputację <1 - 49 pkt>
Oh, little misunderstanding here, what I meant is I did quality scans of almost 600 discs written with that particular 208D, and I've written more than that, because I didn't scan all discs.
Question: Is it posstible that it's more than 1000 discs, and the tool just shows 3 digits?
Oinker jest offline   Odpowiedz cytując ten post
Stary 11.11.2026, 11:45   #25
Oinker
x64 Windows version gets killed because Trojan:Win32/Wacatac.C!ml.
Stary 11.11.2026, 11:51   #26
Oinker
Ok, these numbers are more realistic, and confirm my thoughts, it is three digits only, now correctly more than 1000 discs loaded:
Still interestingly high number of empty tray loads though.
Ostatnio zmieniany przez Oinker : 11.11.2026 o godz. 12:39
Stary 11.11.2026, 12:40   #27
Oinker
Talking
My 213E/M@S13JX and my S13U@S13JX, those numbers look right.
Pioneer blu-ray optical drive diagnostic tool-213mdiag1410.jpg   Pioneer blu-ray optical drive diagnostic tool-s13udiag1410.jpg
Stary 11.11.2026, 13:49   #28
secretgarden
Perhaps the solution to this problem is to purchase a "code-signing certificate", which essentially means indirectly paying those cyber security companies. I am indeed considering this option, though I don't plan to do so for the time being.
Stary 11.11.2026, 13:59   #29
secretgarden
The new version primarily addresses an issue with the disc loading counter. We maintain that our method for calculating loading cycles is correct, a conclusion we verified through testing on actual hardware (There may well be edge cases that haven't been covered, but none have actually been discovered so far). The empty load cycles is not necessarily a negative thing; it may simply reflect a user's habit of operating the drive periodically, as opening the tray does not always imply that a new disc is being inserted
The results of your disc quality scan also confirm that the drive has been operating within normal expectations.
Stary 11.11.2026, 14:02   #30
secretgarden
Załącznik 218227
Załącznik 218228
Załącznik 218229
Thanks to czary2mary for the hardware testing! Calibration string may be the only valid data currently available that can be directly linked to the OPU.
blue-ray, diagnostic, drive, optical, pioneer, tool
Wszystkie czasy w strefie CET. Aktualna godzina: 00:20.
