Stary 11.11.2026, 14:15   #31
secretgarden
Data rejestracji: 09.11.2026
secretgarden zaczyna zdobywać reputację <1 - 49 pkt>
Another interesting thing is that we also posted this tool on the a UHD disc ripping software's official forum and Reddit subreddit, but those posts have since been deleted. That's interesting, I think it might be because I posted them in the wrong place.
The reason I posted there is that users there have also long been plagued by low-quality Pioneer drives. though maybe I'm just overthinking it.
Ostatnio zmieniany przez secretgarden : 11.11.2026 o godz. 14:29
secretgarden jest offline   Odpowiedz cytując ten post
Stary 11.11.2026, 15:02   #32
Oinker
Data rejestracji: 08.11.2022
Oinker zaczyna zdobywać reputację <1 - 49 pkt>
Napisany przez secretgarden Podgląd Wiadomości
The new version primarily addresses an issue with the disc loading counter. We maintain that our method for calculating loading cycles is correct, a conclusion we verified through testing on actual hardware (There may well be edge cases that haven't been covered, but none have actually been discovered so far). The empty load cycles is not necessarily a negative thing; it may simply reflect a user's habit of operating the drive periodically, as opening the tray does not always imply that a new disc is being inserted
The results of your disc quality scan also confirm that the drive has been operating within normal expectations.
One thing though, the quality scans have been done with other drives, the Pioneer does not support BD-R quality scanning, unfortunately. So the number of discs loaded in the 208D do not include the scanned discs.
Oinker jest offline   Odpowiedz cytując ten post
Stary 11.11.2026, 15:10   #33
secretgarden
Napisany przez Oinker Podgląd Wiadomości
I understand what you mean. You can also open the tray a few times yourself to test the accuracy of the data growth. So far, we haven't found any more about software-related issues, so we can only assume that this is how the data is.
Stary 11.11.2026, 18:12   #34
Oinker
Post
There is no issue with reading calibration data, whether using a brand-new laser or a used one.
Załącznik 218227
Załącznik 218228
Załącznik 218229
Begs the question is that laser calibration data hardcoded in the firmware, or stored in some extra location or EEPROM, so it could be changed with a tool like the EEPROM tool for LiteOn writers? Would be nice if I could give my 206Ds with their problems an extended life. Their write quality is among the best, on the level of 208s.
Stary 11.11.2026, 19:38   #35
Stingray
Data rejestracji: 12.02.2024
Stingray zaczyna zdobywać reputację <1 - 49 pkt>
thanks but nothing changed for my drives.
see for example loading cycles to low
Stingray jest offline   Odpowiedz cytując ten post
Stary 12.11.2026, 02:16   #36
secretgarden
Napisany przez Stingray Podgląd Wiadomości
This issue only occurs on certain drives. If the load counter hasn't changed between the old and new versions, it means your drive is not affected by this issue.
Stary 12.11.2026, 08:07   #37
Stingray
this issue.
ok, but there is another issue, please check my screen for SAT 8801
empty cycles =0! it is not true
and loading cycles 118 < total loaded 249
for another drives I see that
total + (empty) = loading cycles
but this formula not working on my screen above
249+0 = 118 not true
Stary 12.11.2026, 08:16   #38
secretgarden
You've reminded me, this is actually the first time I've seen a situation where the number of discs loaded exceeds the number of load cycles. I'll make a note of this issue.
Stary 14.11.2026, 16:49   #39
Oinker
Smile
Almost unused Verbatim Pioneer UD03 (1.11) I just got, flashed to UD04 1.14.
Stary 15.11.2026, 03:52   #40
secretgarden
Almost new
Stary wczoraj, 06:40   #41
The laser units used in the BDR-207/S07 and BD-ROM BDC-207 models are the same as those found in the BDR-206/S06 series.
Calibration data is very similar across all these second-generation drives, much like it is with DVD laser units. It is difficult to notice any difference after swapping or replacing the lasers without performing a recalibration.
Stary wczoraj, 08:20   #42
secretgarden
By the way, could you export the data from this drive as JSON and send it to me? I'll try to look into it further, if you're willing to help improve the tool.
Stary wczoraj, 19:56   #43
Stingray
I sent 2 files for this drive via PM
blue-ray, diagnostic, drive, optical, pioneer, tool
Wszystkie czasy w strefie CET. Aktualna godzina: 00:08.
