DVDFab Player 6.0.0.7
https://www.dvdfab.cn/download.htm
New: Added the support to quickly switch between different episodes when browsing the detailed episode information of TV Shows. New: Added the support to automatically play the next episode upon finishing the current one when playing back TV Shows. New: Added the shader feature in the right-click menu to play videos with different special effects, such as Anime 4K, Anime 1080p, LCD Angle Correction, Emboss, etc. |
DVDFab Player 6.0.0.6
New: Added the filter feature to quickly locate movies or TV Shows from library by country, genre or release year. Fix: A problem that the player cannot open any 4K Ultra HD Blu-ray discs after playing back a regular Blu-ray disc. Fix: A problem that the player cannot open protected 4K Ultra HD Blu-ray ISO files. Fix: A problem that the mouse cursor fails to turn invisible under full screen playback mode. |
DVDFab Player 6.0.0.5
New: Improved the disc import feature for better stability. Fix: A problem that the Title bar and Playback Control panel become inoperable under full screen mode. Fix: A wrong size problem when taking screenshots from DVDs. Fix: A problem that the Search box does not appear at My Computer section in certain cases. |
DVDFab Player 6.0.0.4
New: Added the support to import DVD & Blu-ray discs to local media library as ISO files. New: Improved the way to navigate the address bar of My Computer section. New: Added the support to play back protected Blu-ray ISO files. Fix: A problem that Player 6 does not appear in the contextual menu when right clicking on a media file. Fix: Some minor UI problems. |
DVDFab Player 6.0.0.3
New: Added the support to scrape metadata for Japanese adult DVDs. Fix: Some minor UI problems. |
DVDFab Player 6.0.0.2
New: Added the support to remember the last accessed section at the left navigation panel. New: Added the support to adjust the column width of the left navigation panel. Fix: A failure problem when authorized users check for updates. Fix: A problem that authorized users still encounter license expired alert in certain cases. Fix: A problem that the OSD fails to show up after a playlist finishes the playback. Fix: A problem that an empty folder still shows under the Collections tab despite the files inside have been fix-matched to the TV Show section. Fix: A problem that the file is still deleted despite clicking on the No button at the popup alert when deleting that file from the library at the metadata page. Fix: A problem that the file name does not show up in the popup alert when deleting that file from the library at the metadata page. Fix: Some minor changes and improvements. |
Piekna gra slow - jak ktos nie doczyta to sie przejedzie na wersji Standard:
DVDFab Player 6
Całkowicie nowy silnik odtwarzania, który jest szybszy i bardziej stabilny od poprzedniego , zintegrowano bibliotekę multimediów do zarządzania filmami, kolekcjami, programami telewizyjnymi i innymi filmami ,poprawiono lokalny eksplorator plików, aby efektywniej przeglądać wszystkie pliki multimedialne.
Zupełnie nowy interfejs użytkownika, który jest prosty, stylowy, nowoczesny i szybszy w działaniu . Obsługa menu nawigacji na DVD, Blu-ray i Blu-ray 4K Ultra HD, wyjścia audio HDR10 i Hi-Res . https://www.dvdfab.cn/media-player.htm?ad=player6_forum Załącznik 144872 |
DVDFab Player 5.0.3.2
http://www.dvdfab.cn/mlink/download....VDFAB_PLAYER_5
New: Added the support for some new Japanese adult DVDs. |
DVDFab Player 5.0.3.0
New: Introduced the new feature to adjust playback speed. Fix: A problem that certain DVD movie folders fail to play back. Fix: A problem that the Disable Screensaver feature does not work. |
DVDFab Player 5.0.2.9
Fix: A problem that the playback progress status is not displayed when playing back certain Blu-ray and 4K UHD sources. |
DVDFab Player 5.0.2.8 + DVDFab Player MAC 5.0.2.8
http://www.dvdfab.cn/mlink/download....VDFAB_PLAYER_5 Fix: A problem that automatically switch to HDR mode option does not work despite on Windows 10 installed with an HDR capable NVIDIA video card and connected with an HDR compatible TV or display monitor. Fix: A problem that only audio but no video is played when playing certain Blu-ray discs. DVDFab Player MAC 5.0.2.8 Fix: A problem that Bluetooth device is not displayed in the Output Device dropdown list at Settings > Audio http://www.dvdfab.cn/mlink/download....B_PLAYER_5_MAC |
Power DVD 19
DVDFab Player 5.0.2.7
New: Introduced the new feature to adjust the playback speed. Fix: Certain display color problems regarding internal subtitles during the playback process. Fix: An ISO opening failure problem due to source recognition failure if the ISO is mounted by the system default method on Windows 10. Fix: An ISO playback failure problem caused by the overlong path of the ISO file. Fix: A problem that user defined text font is not supported when playing with self-made ASS external subtitles. |
DVDFab Player 5.0.2.6
Fix: A problem that the option Remember the last playback position does not work properly.
Fix: A problem that the internal subtitles occasionally disappear when using the seek feature. http://www.dvdfab.cn/mlink/download....VDFAB_PLAYER_5 |
| Wszystkie czasy w strefie CET. Aktualna godzina: 19:59. |
