DVDFab Player 5.0.1.1
New: Added the support to play back 3D Blu-rays, side-by-side and top-and-bottom 3D videos, under Windows 10 for the time being.
Fix: A problem that the Blu-ray menu language does not match the preselected language at the Settings panel. http://www.dvdfab.cn/mlink/download....VDFAB_PLAYER_5 |
Player 5.0.1.0 Beta
New: Added the 3D playback support for 3D Blu-rays, Side-by-Side 3D videos and Top & Bottom 3D videos.
Fix: A playback crash problem under fullscreen mode in certain cases. https://s3.amazonaws.com/dl-dvdfab/d...layer_5010.exe |
Power DVD 18
Oficjalnie został zaprezentowany Power DVD 18
https://www.cyberlink.com/products/p...n_EU.html?&r=1 Załącznik 118721 |
DVDFab Player 5.0.0.9
New: Ushered in the brand-new decryption technology to decrypt and play back genuine 4K Ultra HD Blu-ray discs.
Improved: The playback support for DVDs and non-4K Blu-rays. http://www.dvdfab.cn/mlink/download....VDFAB_PLAYER_5 |
DVDFab Player 5.0.0.8
New: Added the Smart Preview feature for digital video files.
New: Added the support to remember the playback position if the main screen is closed during the playback process. Improved: The playback support for DVDs. Fix: A minor UI display problem. Fix: A problem that the added external subtitles do not show up under Windows 7. Fix: A problem that the list of available audio devices does not refresh automatically if plugging in the audio device after Player 5 starts up. Fix: A problem that the video file cannot be deleted after the playback stops. Fix: A no sound problem during the playback in some rare cases. Fix: A problem that the Japanese subtitles do not show up when playing back Blu-ray discs. Fix: An abnormal UI display problem when splitting the screen if there are two display monitors connected to one computer. Fix: A problem that the added external subtitles are messed up in certain cases. http://www.dvdfab.cn/mlink/download....VDFAB_PLAYER_5 |
DVDFab Player 5.0.0.7
New: Added the support to display the cover art when playing back MP3 and M4A music files.
New: Added the support to boost the volume beyond 100% but no more than 200%. New: Added the support to read and then display the chapter information of the video file being played. New: Added the snapshot feature with the hotkey of S on the keyboard. New: Added the switch display feature under the TV Mode if there are two displays connected to the same computer. New: Added the floating infobox under the PC Mode to show the volume change, playback status and some other tips. New: Added the last playback position infobox when opening an unfinished file, if the option of remembering last playback position is not enabled at the Settings panel. Fix: A low volume problem during the playback process. Fix: A problem that the hotkey T for Always on Top doesn***8217;t work if no playback is in progress. Fix: A problem that the settings of external subtitles don***8217;t work. Fix: A problem that the functions of Flip Vertically and Flip Horizontally are inverted. Fix: A problem that the Enter key on the numpad does not work on DVD/Blu-ray menus. Fix: A problem that the slider position on the volume bar is not remembered. Fix: Some minor changes and improvements. http://www.dvdfab.cn/mlink/download....VDFAB_PLAYER_5 |
Power DVD 18
Cyberlink przypadkowo na chwilę umieścił nowe Power DVD 18 na swojej stronie .
Nie znamy daty premiery ani ceny . Załącznik 115636 Cytat:
DVDFab Player 5.0.0.6
New: Added the support to open external subtitles.
New: Added the support for right-click menus at the main screen when there is no playback in progress. Improved: The playback support for DVDs and Blu-rays. Improved: The way to open media contents from the right-click menus. Fix: A no sound problem during playback on certain PCs. Fix: A problem that menu fonts are messed up on cetain 4K Ultra HD Blu-rays. Fix: A problem that the status of the selected menu option does not change on certain 4K Ultra HD Blu-rays. Fix: A low volume problem if the audio output is set to Passthrough when playing sources with Dolby TrueHD audios. http://www.dvdfab.cn/mlink/download....VDFAB_PLAYER_5 |
DVDFab Player 5.0.0.4
New: Added the file association feature.
New: Added hotkey support to fast forward 10 seconds (Ctrl+Right) and rewind 10 seconds (Ctrl+Left). New: Added the support to play back AVCHD sources. New: Added the option to open log folder from the Settings menu. New: Added the support to show the current timestamp when pointing the mouse at the playback progress bar. New: Added the support to show the current movie title in the title bar of the playback window. Improved: The playback right-click menu by graying out the Top Menu and Pop Menu options under Simple Mode. Improved: The adapted resolution for the TV Mode on displays with a native resolution lower than 1920*1080. Improved: The audio related settings for an easier audio configuration. Improved: The CPU utilization for a better performance. Fix: A crash problem when checking for update if the network is in an unfavorable condition. http://www.dvdfab.cn/mlink/download....VDFAB_PLAYER_5 |
DVDFab Player 5.0.0.3
DVDFab Player 5.0.0.3 Changelog:
Improved: The playback support for 4K Ultra HD Blu-rays. Fix: A problem that the player does not launch up on certain PCs. Fix: A problem that the UI fonts are quite small on 4K displays. Fix: A problem that the "Fatal Error" dialog pops up during the playback process. Fix: A problem that the menu options are hardly identifiable on large-screen TVs. Fix: A problem that the player cannot play back the ISO files mounted by a virtual drive. Fix: A problem that certain movies are displayed with inaccurate runtime. Fix: A problem that the player cannot play back the files from SMB server, if the path is named with some special characters. Fix: A problem that the player cannot play back 4K videos under Simple mode. https://www.dvdfab.cn/mlink/download...VDFAB_PLAYER_5 |
DVDFab Player 5 Standart \Ultra
DVDFab Player 5.0.0.2
New: Added the support to playback 4K Ultra HD Blu-rays from UHD-friendly drives by accepting external key files. New: Added the drag & drop support to the PC Mode. New: Added the support to associate media files. New: Added the HDR entry in the Info panel. Improved: The HDR support for video cards from Nvidia, Intel and AMD. Improved: The software launch speed. Improved: The seeking algorithm to make the seeking process smoother. Fix: A display error problem when switching UI language. Fix: The menu playback problem when playing movies from discs. Fix: The incorrect hotkey assignation problem of the Space key. https://www.dvdfab.cn/media-player.htm https://www.dvdfab.cn/mlink/download...VDFAB_PLAYER_5 |
Zapomnij - tylko Windows 10 posiada wsparcie dla UHD\ 4K
Tu podstawowe informacje : Ultra HD Blu-Ray \ 4 K na PC |
Szybkie pytanie - Warto kupić, buduje media center oparty na windows7 i myślę nad odtwarzaczem dla filmów DVD i BR oraz własnych w formacje FullHD i 4K, jest przecena z kodem na ~71$. Posiadam napęd BR.
Ukazała się najnowsza wersja DVDFab Media Player 4K \ UHD
Wszyscy dotychczasowi płatni klienci DVDFab Media Player 3 otrzymają całkowicie za darmo nową wersję DVDFab Player 5 Ultra . Według producenta DVDFab Player 5 oferuje całkowicie nowy silnik odtwarzania, który znacznie poprawia stabilność, kompatybilność i płynność odtwarzania. Całkowicie przeprojektowany został interfejs użytkownika, który posiada zaawansowane tryby odtwarzania na komputerze i telewizorze, które obsługują menu nawigacyjne na płytach DVD, Blu-ray , Blu-ray 4K Ultra HD, z oryginalnymi audio HDR10 i Hi-Res, w tym Dolby Atmos, Dolby TrueHD, DTS-HD Master i DTS . https://www.dvdfab.cn/media-player.htm Załącznik 110569 |
DVDFab Media Player v3.2.0.0 4K UHD
Aktualizacja programu (November 03, 2017)
New: Improved the support for the playback of Ultra HD Blu-rays ISO files and folders. New: Added the support to play back the Ultra HD Blu-ray sources in HDR mode (a NVIADIA video card of Pascal/Geforce GTX 10 series or above, and an HDR compatible display monitor are required). Fix: A crash problem when starting up the media player in certain cases. http://www.dvdfab.cn/mlink/download.php?g=MEDIA_PLAYER |
| Wszystkie czasy w strefie CET. Aktualna godzina: 21:51. |
