-   -   Ultra HD Blu-Ray (https://forum.cdrinfo.pl/f107/ultra-hd-blu-ray-94685/)
czary2mary 08.03.2019 11:25
DVDFab Player 5.0.2.5
Fix: A no sound problem once playback starts unless the default audio track is selected.
Fix: A problem that the playback button is occasionally missing from the main interface after loading a disc from the optical drive.
Fix: A problem the subtitles fail to show up when seeking forward if external subtitles are added to Blu-ray sources.
Fix: A no video but only sound problem when playing the Blu-ray version of the concert Meltdown: Live in Mexico City.
http://www.dvdfab.cn/mlink/download....VDFAB_PLAYER_5
czary2mary 26.01.2019 09:25
DVDFab Player 5.0.2.4
New: Improved the playback support for the HDR contents of 4K UHD sources in SDR mode.
New: Added the option "Play with DVDFab Player 5" in the contextual menu on the supported file sources.
New: Added the support to jump from the last chapter of the currently being played source directly to the next source.
Fix: A problem that the program does not respond when clicking the Stop button during the process of opening a source.
Fix: A failure problem when opening the DVD & Blu-ray ISO files if there are Japanese, Simplied Chinese or Traditional Chinese characters in the file path or file name.
czary2mary 20.12.2018 12:15
DVDFab Player 5.0.2.3
New: Added the Swedish language support.
New: Introduced the Cloud Decryption Service 3.0 to open Blu-rays in around 10 seconds.
czary2mary 07.11.2018 06:14
DVDFab Player 5.0.2.2
Fix: A problem that the executable file is not signed.
czary2mary 03.11.2018 08:38
DVDFab Player 5.0.2.1
New: Added the playback support for certain discs with some new Java protections.
Fix: Some minor UI display problems.
Fix: An MP3 playback problem under Windows 7.
Fix: A no sound problem when playing back Spider Man 2 with the Menu mode.
czary2mary 31.08.2018 09:16
DVDFab Player 5.0.2.0
New: Added the audio playback support to the Playlist feature.
Fix: A problem that the playback progress bar displays incorrect timestamp on audio files.
Fix: A problem that adding audio files to the playlist by folder does not work.
czary2mary 20.08.2018 04:46
DVDFab Player 5.0.1.9
Fix: A crash problem after opening 4K UHD discs in random cases.
Fix: A problem that the shuffle playback feature in the Playlist does not work properly.
Fix: Improved the playback stability.
czary2mary 02.08.2018 04:58
DVDFab Player 5.0.1.8
New: Added the support to play back BDAV discs.
New: Added the support to allow Kodi to use Player 5 to play the contents in its media library.
Fix: A problem that the playback progress bar shows incorrect timestamp after entering a selected scene from menus.
Fix: A crash problem when trying to play DVDs if the license has expired.
czary2mary 21.07.2018 07:17
DVDFab Player 5.0.1.7
Fix: A crash problem in certain cases.
czary2mary 19.07.2018 02:15
DVDFab Player 5.0.1.6
New: Added the support to play the next and the previous frame.
New: Added the support to preset output color range at Settings panel.
New: Added the support to turn on/off the on-screen tips for playback status.
New: Added the shortcut tips in the right-click menu and playback control dock.
New: Improved the support for 4K Ultra HD Blu-ray discs.
Fix: A problem that the playback progress bar displays incorrect time stamp on certain sources.
Fix: A problem that the playback button is missing for certain discs.
Fix: A problem that the video color turns a little bit blue if the hardware acceleration is enabled under AMD Radeon Pro 455 video card.
Fix: A problem that temporary IFO files are created during the playback process.
Fix: Removed the popup dialog when quitting the playback under the TV mode.
czary2mary 29.06.2018 08:10
DVDFab Player 5.0.1.5
New: Improved the playback support for Blu-ray discs.
New: Improved the UI display support under high DPI displays.
Fix: A problem that the TrueHD/DTS-HD audios cannot be selected in certain cases.
Fix: A problem that the menus of movie Tron are improperly displayed.
Fix: A problem that the option to turn off the subtitles preselection does not work when playing back DVDs under Simple Mode.
czary2mary 07.06.2018 20:11
DVDFab Player 5.0.1.4
New: Added the proxy relevant settings at Settings panel > Network.
New: Added the support to preselect audio devices at Settings panel > Audio.
New: Added the right-click menu feature in the Playlist panel.
New: Added the support for the XMOS audio converters.
Fix: An abnormal menu display problem in certain cases.
Fix: A playback problem of certain 4K Ultra HD Blu-rays.
Fix: A problem that the seek feature does not work when playing back certain 4K videos under Windows 7.
Fix: A crash problem upon startup in certain cases.
Fix: A playback freeze problem in certain cases.
Fix: A problem that part of the playback screen becomes transparent when maximized in certain cases.
Fix: A problem that the movie title does not show up when playing back certain discs or virtual drive mounted ISO files with the Playlist feature.
Fix: A problem that the analysis reports incorrect HDR support status when analyzing the hardware under Windows 7 in certain cases.
Fix: A problem that the Open Containing Folder feature does not work in certain cases.
Fix: A problem that PGS subtitles are not displayed when playing back some special sources in certain cases.
czary2mary 24.05.2018 21:20
DVDFab Player 5.0.1.3
New: Improved the support for the playlist feature.
czary2mary 23.05.2018 20:17
W nowych wydaniach UHD Fury i Patriot odkryto nowe wersje "kopio-odporne" AACS2.1.
Na razie nie ma "lekarstwa"
czary2mary 18.05.2018 07:20
DVDFab Player 5.0.1.2
New: Added the 4K HDR playback support on Windows 7/8/8.1.
New: Added the new playlist feature.
New: Added the drag & drop support when adding external subtitles.
New: Added the support to preselect the display language for menus, audios and subtitles.
New: Added the support to play back videos and music from Windows Media Library under TV Mode.
Fix: A problem that certain DVD discs, such as My Little Pony, cannot open under Simple Mode.
Fix: A problem that certain DVD discs, such as Power Ranger, still play with menus even under Simple Mode.
Fix: A problem that subtitles fail to load from unmapped NAS path (via SMB protocol).
Fix: A problem that the Germany version of Arrival cannot play back the main movie title under Menu Mode.
Wszystkie czasy w strefie CET. Aktualna godzina: 23:36.
