DVDFab 12.0.8.1
https://www.dvdfab.cn/download.htm
DVDFab 12.0.8.1 Changelog New: Added support for some new Java protections. Fix: A problem that the estimated output file size is incorrect when the MKV (Dolby Vision) conversion profile is used. Fix: A GUI display problem under certain displays with different resolution settings. |
DVDFab 12.0.7.9
DVDFab 12.0.7.9 Changelog New: Added support for some new Java protections. |
DVDFab 12.0.7.7
DVDFab 12.0.7.7 Changelog New: Added the support for some new Java protections. |
DVDFab 12.0.7.5
DVDFab 12.0.7.5 Changelog New: Added support for some new Java protections. Fix: A freeze problem when using the Enlarger AI module to upscale the VOB videos recorded by VHS camera devices. Fix: A crash problem when loading more than 6 DVD sources in the DVD to Blu-ray Converter module. Fix: A problem that the output Blu-rays created by the Blu-ray Creator module only display one line of subtitles despite there are two lines in the source files. Fix: A problem that the output M2TS videos converted from MP4 videos by the Video Converter module cannot play back normally. |
DVDFab 12.0.7.3
DVDFab 12.0.7.3 Changelog New: Added support for some new Java protections. New: Added a new Enlarger AI training model Real-CUGAN in the Ripper and Converter modules. New: Added the M2TS Passthrough conversion profile in the Video Converter module. |
DVDFab 12.0.7.1
DVDFab 12.0.7.1
https://www.dvdfab.cn/download.htm DVDFab 12.0.7.1 Changelog Fix: An update failure problem in certain cases. Fix: A crash problem when making DVDs with certain video files in the DVD Creator module. |
DVDFab 12.0.6.8
DVDFab 12.0.6.8 Changelog New: Added support for some new Java protections. |
DVDFab 12.0.6.7
DVDFab 12.0.6.7 Changelog New: Added support for some new Java protections. |
DVDFab 12.0.6.4
DVDFab 12.0.6.4 Changelog New: Added support for some new Java protections. New: Added support to enable IQS (Intel Quick Sync) hardware acceleration with the 12th-gen Intel CPUs. Fix: A crash problem when cropping the Tubi videos downloaded with StreamFab in certain cases. |
DVDFab 12.0.6.2
DVDFab 12.0.6.2 Changelog Fix: A startup crash problem due to altered DVDFab host information in the system hosts file. Fix: A startup crash problem on machines installed with AMD Radeon RX 480 video card. Fix: A subtitle display problem after burning the videos downloaded from Netflix to BD25 discs in the Blu-ray Creator module. |
DVDFab 12.0.6.1
DVDFab 12.0.6.1 Changelog Fix: A failure problem when copying certain Japanese DVDs in the Full Disc mode of the DVD Copy module. Fix: A problem that Japanese subtitles contain messy codes after burning to BD discs. |
DVDFab 12.0.6.0
DVDFab 12.0.6.0 Changelog Fix: A crash problem when trimming videos in the Video Converter module in certain cases. Fix: A crash problem when adjusting the size of subtitles in the Video Converter module. Fix: A failure problem when loading certain MP4 videos in the Blu-ray Creator module. Fix: A problem that the background art of the menu template in the DVD Creator module cannot be created. Fix: A crash problem when clicking on the Play with PlayerFab icon from the task queue to play the output files if the PlayerFab has been uninstalled. Fix: Some minor changes and improvements. Fix: A crash problem when loading sources in certain cases. |
DVDFab 12.0.5.8
DVDFab 12.0.5.8 Changelog New: Added the H265 encoding support when converting videos with the TS conversion profile in the Video Converter module. New: Some improvements on GUI display under higher DPI settings. Fix: A problem that the live update window still pops up after uninstalling all the DVDFab related products. Fix: A problem that the text introduction in the Streaming menu template of the Blu-ray Creator module can be manually removed. Fix: A problem that the cloned ISO files of the 4K Blu-rays recorded by Panasonic DMR-4CW200 cannot play back. |
DVDFab 12.0.5.7
DVDFab 12.0.5.7 Changelog Fix: A failure problem when loading videos from the OneDrive directory. Fix: A failure problem when saving the changes after resetting the directory of log files in the Settings panel. Fix: A failure problem when opening the output directory after the conversion finishes in the Blu-ray Creator module. Fix: A problem that the menu settings cannot be remembered in the Creator modules. |
DVDFab 12.0.5.6
DVDFab 12.0.5.6 Changelog New: Added support for some new Java protections. |
| Wszystkie czasy w strefie CET. Aktualna godzina: 02:23. |
