DVDFab 12.0.1.2
https://www.dvdfab.cn/download.htm
DVDFab 12.0.1.2 Changelog Fix: A freeze problem upon startup in certain cases. |
DVDFab 12.0.1.1
DVDFab 12.0.1.1 Changelog New: Minor improvement on the Online Installer. New: Major improvement on the H.265 software encoding to speed up the conversion by 20% ~ 50%. New: Minor improvement on the burning engine. New: Added the support to delete the source from the Converter module when conversion finishes. |
DVDFab 12.0.0.9
DVDFab 12.0.0.9 Changelog New: Added the support for some new Java protections. |
DVDFab 12.0.0.8
DVDFab 12.0.0.8 Changelog Fix: A problem that the Advanced Settings panel does not display normally if the source loaded is an FLAC file in the Video Converter module. Fix: A switch failure problem from the Mini version to the normal version. Fix: A crash problem when opening certain types of files in certain cases. |
DVDFab 12.0.0.7
DVDFab 12.0.0.7 Changelog New: Added the support for some new Java protections. New: Temporarily removed the MP4.Passthrough conversion profile from the DVD Ripper module due to certain conversion problems. Fix: A crash problem when switching display language. |
DVDFab 12.0.0.5
DVDFab 12.0.0.5 Changelog New: Added the support for AI conversions with AMD Ryzen CPUs. Fix: A conversion failure problem in the DVD & Blu-ray Ripper modules in certain cases. Fix: A problem that the option of Output both AAC and AC3 audio tracks is gone missing from the Advanced Settings panel if MP4 profile is selected in the Ripper and Video Converter modules. Fix: A problem that the custom conversion profiles are gone missing after updating to ver. 12.0.0.4. |
DVDFab 12.0.0.4
DVDFab 12.0.0.4 Changelog New: Added the support for some new Java protections. New: Added the support to access the information of forced subtitles from cloud server. Fix: A crash problem if a trial user repeatedly tries a certain feature of the Video Converter module. Fix: A conversion failure problem when batch processing videos in the Video Converter module. Fix: A problem that the metadata information of the movie is not written into the MP4 file system during the conversion after searching that movie in the Video Converter module. Fix: A problem that the UHD Drive Tool shows as unauthorized in certain cases. |
DVDFab 12.0.0.3
DVDFab 12.0.0.3 Changelog Fix: A problem that the Live Update feature does not work in certain cases. |
DVDFab 12.0.0.2
DVDFab 12.0.0.2 Changelog Fix: An H.265 custom setting problem in the Video Converter module. Fix: A problem that the HDR10 content in certain videos cannot be recognized. |
DVDFab 12.0.0.1
DVDFab 12.0.0.1 Changelog Fix: A startup crash problem in certain cases. Fix: An OCR failure problem when outputting SRT subtitles in the Ripper modules on PCs with older CPUs. Fix: A problem that GPU load shows as 0% during conversion. |
DVDFab 12
Kolejna edycja "kombajnu" do edycji i kopi zapasowych video DVD/BluRay/UHD BluRay
Z głównych nowości dodanych w DVD Fab 12 to nowy nowoczesny interfejs , oferujący wiele nowych opcji i szybki dostęp do funkcji,nowe profile zwłaszcza dla urządzeń mobilnych, konwerter Blu-ray na UHD do konwersji zwykłych Blu-Ray oraz UHD Blu-Ray do zwykłych Blu-Ray , wprowadzono technologię Cloud Speedup , znacznie szybciej deszyfrowane są starsze pozycje DVD i BluRay, nowa wersja UHD Drive Tool,ulepszono moduł Blu-ray Creator,ulepszono moduły Ripper i Video Converter, aby umożliwić niestandardowe ustawienia H.264 / H.265, Załącznik 164704 |
| Wszystkie czasy w strefie CET. Aktualna godzina: 06:22. |
