-   Zabezpieczenia CD/DVD/Blu-ray (https://forum.cdrinfo.pl/f11/)
-   -   DVDFab 12 (https://forum.cdrinfo.pl/f11/dvdfab-12-a-98316/)
czary2mary 05.12.2021 10:14
DVDFab 12.0.5.5
https://www.dvdfab.cn/download.htm
DVDFab 12.0.5.5 Changelog
New: Added support for some new Java protections.
Fix: A problem that the option to select Japanese audios and subtitles by default is missing when loading certain Blu-rays into the Blu-ray Ripper module if the OS language is Japanese.
Fix: A problem that Blu-rays larger than 40GB cannot be compressed onto DVDs in the Blu-ray to DVD Converter module.
czary2mary 26.11.2021 10:21
DVDFab 12.0.5.4
DVDFab 12.0.5.4 Changelog
New: Added a new AI model DAIN to convert videos with Smoother AI.
Fix: A problem that DVDFab 365 subscribers get incorrect expiration date in certain cases.
czary2mary 23.11.2021 07:03
DVDFab 12.0.5.3
DVDFab 12.0.5.3 Changelog
Fix: A problem that the Cinavia removal feature in the Blu-ray Ripper module does not work despite having purchased the Blu-ray Cinavia Removal.
Fix: A problem that the DVD Creator module cannot remember the menu mode user previously selected.
czary2mary 04.11.2021 19:28
DVDFab 12.0.5.2
DVDFab 12.0.5.2 Changelog
New: Some minor changes and improvements.
Fix: A problem that DVDFab Mini cannot switch display languages.
Fix: A problem that the posters are not updated when searching for certain movies.
Fix: A freeze problem when enlarging videos with Enlarger AI in the DVD Ripper module.
czary2mary 22.10.2021 15:52
DVDFab 12.0.5.1
DVDFab 12.0.5.1 Changelog
New: Some improvements on the H264 conversion engine.
Fix: A problem that the output video has incorrect duration when splitting DVDs in the DVD Copy module.
czary2mary 13.10.2021 11:21
DVDFab 12.0.5.0
DVDFab 12.0.5.0 Changelog
New: Added support for the new Windows 11 operating system.
Fix: An incorrect resolution problem when converting 4K Ultra HD Blu-rays to SDR 1080p MKV format in the UHD Ripper module.
Fix: A failure problem when converting with the MP4.Passthrough profile in the Ripper and Video Converter modules.
czary2mary 29.09.2021 07:56
DVDFab 12.0.4.9
DVDFab 12.0.4.9 Changelog
Fix: A failure problem when converting GIF images with Enlarger AI in Video Converter.
Fix: A problem that the frame rate of the created video is inconsistent with the conversion settings when converting certain .m2ts files in Video Converter.
czary2mary 15.09.2021 11:13
DVDFab 12.0.4.7
DVDFab 12.0.4.7 Changelog
New: Added the Rife 3.0 and Rife 3.1 models in the Smoother AI.
New: Added support for the MP4.4K.DolbyVision.H265.10Bit conversion profile in the UHD Ripper module to render subtitles.
czary2mary 27.08.2021 12:08
DVDFab 12.0.4.5
DVDFab 12.0.4.5 Changelog
New: Added support for the new CAIN model in the Smoother AI module to work with the DVD Ripper and Video Converter modules.
Fix: A black screen problem when playing the videos converted from certain HEVC encoded MP4 videos.
czary2mary 20.08.2021 02:59
DVDFab 12.0.4.3
DVDFab 12.0.4.3
DVDFab 12.0.4.3 Changelog
New: Added the new AI model named CAIN for the Smoother AI in the Blu-ray Ripper module.
Fix: A problem that certain Blu-rays made by the Blu-ray Creator cannot play back.
Fix: A crash problem when selecting the BD50 output size in the Blu-ray Creator module if the OS language is Japanese.
Fix: A display problem under high DPI settings in certain cases.
czary2mary 04.08.2021 14:22
DVDFab 12.0.4.1
DVDFab 12.0.4.1 Changelog
New: Added support for the Smooth AI module to work with the Video Converter module.
Fix: A problem that the edited movie titles change back to the originals after pressing the Enter key on the keyboard.
czary2mary 23.07.2021 21:22
DVDFab 12.0.4.0
DVDFab 12.0.4.0 Changelog
Fix: A crash problem when loading sources with the Main Movie mode of the DVD Copy module in certain cases.
czary2mary 02.07.2021 16:05
DVDFab 12.0.3.6
DVDFab 12.0.3.6 Changelog
New: Some GUI improvements.
Fix: A failure problem when converting certain Blu-rays in the Blu-ray Ripper module.
czary2mary 23.06.2021 11:01
DVDFab 12.0.3.4
DVDFab 12.0.3.4 Changelog
Fix: A problem that the EAC3 audio track of the output video contains only 6 channels despite there are 8 in the source when converting Blu-rays in the Blu-ray Ripper module.
Fix: A problem that the titles are displayed in the Playlist order by default after opening Blu-rays in the Blu-ray relevant modules.
Fix: A crash problem when converting certain BDAV discs in the Blu-ray Recorder Ripper module.
Fix: Some minor changes and improvements.
czary2mary 08.06.2021 13:56
DVDFab 12.0.3.2
DVDFab 12.0.3.2 Changelog
Fix: A problem that the Menu Settings panel is missing from the UHD to Blu-ray Converter module.
Fix: An installation failure problem when installing other DVDFab products recommended in the Updater window if the display language is Japanese.
Wszystkie czasy w strefie CET. Aktualna godzina: 06:00.
