-   Zabezpieczenia CD/DVD/Blu-ray (https://forum.cdrinfo.pl/f11/)
-   -   DVDFab 12 (https://forum.cdrinfo.pl/f11/dvdfab-12-a-98316/)
czary2mary 01.06.2021 16:13
DVDFab 12.0.3.1
https://www.dvdfab.cn/download.htm
DVDFab 12.0.3.1 Changelog
New: Added the support for some new Java protections.
New: Some improvements on GUI display on 4K displays with high DPI settings.
Fix: A B-Frame conversion problem when converting videos to MKV format on machines installed with NVIDIA Turing graphics card.
czary2mary 16.05.2021 07:34
DVDFab 12.0.2.9
DVDFab 12.0.2.9 Changelog
Fix: A failure problem when converting certain Blu-rays to MP4 videos in the Blu-ray Ripper module.
Fix: A crash problem when converting certain DVDs to MP4 videos in the DVD Ripper module.
Fix: A failure problem when switching to DVDFab Mini in certain cases.
Fix: A crash problem when starting up the DRM Removal module in certain cases.
Fix: Some minor changes and improvements.
czary2mary 30.04.2021 11:25
DVDFab 12.0.2.7
DVDFab 12.0.2.7 Changelog
New: Added the support to convert SRT subtitles to IDX format when converting videos in the Video Converter module.
New: Added the support to convert the PCM 24 audios from Blu-rays to PCM 16 audios in the Blu-ray Copy and Blu-ray Ripper modules.
Fix: A problem that the tabs on the upper navigation menu do not respond in certain cases.
Fix: A failure problem when merging DVDs in the DVD Copy module in certain cases.
Fix: A problem that the output DVDs converted from certain Blu-rays contain no audios.
Fix: A problem that the output file size is 0KB when converting certain Blu-rays to MP4 using the MP4.Apple.Prores profile.
Fix: A failure problem when converting certain videos in the Video Converter module.
czary2mary 27.04.2021 12:35
DVDFab 12.0.2.6
DVDFab 12.0.2.6
DVDFab 12.0.2.6 Changelog
New: Added some 5K relevant MKV, MP4, MOV and M2TS conversion profiles in the Video Converter and Ripper modules.
Fix: An update failure problem if the OS language is Japanese.
Fix: A freeze problem when upscaling Blu-rays with Enlarger AI on machines installed with certain NVIDIA video cards.
Fix: A failure problem when converting Blu-rays with MKV.H265 profile in the Blu-ray Ripper module.
Fix: A minor GUI display problem when adjusting the width of the Title column on the main interface.
czary2mary 14.04.2021 12:35
DVDFab 12.0.2.5
DVDFab 12.0.2.5 Changelog
Fix: A startup failure problem in certain cases.
czary2mary 09.04.2021 21:53
DVDFab 12.0.2.4
DVDFab 12.0.2.4 Changelog
New: Added the support to output FLAC audios in the MP4 relevant profiles in the Ripper and Converter modules.
New: Added two 8K MOV relevant profiles in the Ripper and Converter modules.
czary2mary 02.04.2021 10:21
DVDFab 12.0.2.3
DVDFab 12.0.2.3
DVDFab 12.0.2.3 Changelog
New: Some improvements on the Enlarger AI conversion engine.
New: Added the support to output ALAC audios when converting with MKV relevant profiles in the Ripper and Video Converter modules.
New: Added the MOV conversion profile in the Ripper and Video Converter modules.
Fix: A freeze problem when converting certain DVDs to Blu-rays with the 32-bit version DVDFab 12.
Fix: A freeze problem when converting certain M2TS videos to MP4 videos with TrueHD audios.
Fix: A problem the output files are still sent to One Drive despite selecting another output path when merging Blu-rays in the Blu-ray Ripper module.
czary2mary 23.03.2021 13:23
DVDFab 12.0.2.1
DVDFab 12.0.2.1
DVDFab 12.0.2.1 Changelog
New: Some improvements on memory usage when upscaling videos with Enlarger AI.
New: Some improvements on the software stability when upscaling DVDs to Blu-rays with Enlarger AI.
New: Added the support to output FLAC audios in the MKV relevant conversion profiles.
Fix: A failure problem when converting certain DVDs in the DVD Ripper module.
Fix: A failure problem when converting DVDs using the MKV.Apple.ProRes conversion profile in the DVD Ripper module.
Fix: A freeze problem when copying certain 4K Ultra HD Blu-rays with the Full Disc mode in the UHD Copy module.
Fix: A failure problem when converting certain types of videos in the Creator modules.
Fix: A minor GUI display problem.
czary2mary 17.03.2021 20:02
DVDFab 12.0.2.0
DVDFab 12.0.2.0 Changelog
New: Added the support to output 7.1-channel TrueHD audios when converting Blu-rays and 4K Ultra HD Blu-rays containing DTS-HD audios in the Ripper modules.
Fix: A problem that certain conversion profiles appear twice in the profile library when installing a new version over the previous one.
Fix: A freeze problem when converting m2ts videos in the Video Converter module in certain cases.
Fix: A problem that the Volume Up settings at the Advanced Settings panel does not work with the Video Converter module.
czary2mary 03.03.2021 07:25
DVDFab 12.0.1.9
DVDFab 12.0.1.9 Changelog
New: Discontinued the OS support for the Enlarger AI module on older Windows versions, only Windows 10 64-bit is supported now.
New: Added the Apple Prores codec output support in MP4/MKV passthrough conversion profiles.
Fix: A problem that the Clear Opening History feature does not work.
Fix: A problem that the Metadata of the output files by the Ripper module contain messy codes.
Fix: A crash problem upon clicking the Choose Other Titles button in certain cases.
Fix: A problem that the output videos by the MKV.3D.MVC conversion profile in the Blu-ray Ripper module are not 3D.
Fix: A problem that the output videos by the UHD Ripper module contain no Dolby audios.
Fix: A conversion failure problem in the Blu-ray Recorder Ripper module in certain cases.
Fix: A text display problem in the Menu Settings panel of the Blu-ray Creator module.
czary2mary 02.02.2021 17:54
DVDFab 12.0.1.8
DVDFab 12.0.1.8 Changelog
New: Added the support to convert DVDs to Hi-Fi audio files in the DVD Ripper module.
New: Improved the support for the AI conversion with NVIDIA Graphics Cards.
New: Improved the live update feature.
Fix: A Cinavia removal failure problem.
czary2mary 23.01.2021 21:03
DVDFab 12.0.1.7
DVDFab 12.0.1.7 Changelog
New: Added the TrueHD audio conversion profile in the Ripper and Video Converter modules.
New: Added the MP4.Apple.ProRes and MKV.Apple.ProRes video conversion profiles in the Ripper and Video Converter modules.
Fix: A title bar display problem.
Fix: A Cinavia removal failure problem on certain Blu-rays.
czary2mary 30.12.2020 06:44
DVDFab 12.0.1.5
DVDFab 12.0.1.5 Changelog
New: Added the ***8220;For Old Movie***8221; training model in the Enlarger AI to enlarge the old movies before 1980.
New: Added the ***8220;Ultra+Deinterlace (Fast)***8221; training model in the Enlarger AI to deinterlace videos much better and faster than ***8220;Ultra".
New: Added the support for TrueHD 5.1 audio encoding in MKV relevant conversion profiles in the Ripper and Video Converter modules.
New: Added the support for WMV videos as source in the Creator module.
Fix: A problem that the auto-shutdown feature does not work in certain cases.
czary2mary 26.12.2020 10:47
DVDFab 12.0.1.4
DVDFab 12.0.1.4 Changelog
New: Added the MP4.TrueHD.eARC conversion profile in the Blu-ray Ripper and UHD Ripper modules to preserve the TrueHD audio tracks. (To play back the TrueHD audio, your TV needs to support the HDMI-eARC.)
New: Improved the Live Update feature.
Fix: A problem that the movie cover fails to show up at the main interface in certain cases.
Fix: A problem that the DVD to Blu-ray conversion still shows as success despite being cancelled in the middle of the conversion.
czary2mary 23.12.2020 03:43
DVDFab 12.0.1.3
DVDFab 12.0.1.3
DVDFab 12.0.1.3 Changelog
New: Improved the support for Enlarger AI.
New: Added the support to upscale videos with Enlarger AI on machines installed with NVIDIA GeForce RTX 30 Series Graphics Cards.
New: Added the support to choose the Premium Quality or Ultra Quality when upscaling Blu-rays with Enlarger AI.
New: Added the support to output 720p quality when upscaling DVDs with Enlarger AI.
New: Added the support to output WebM videos in the Ripper and Converter modules.
Fix: A problem that the "Download More Menu" button does not show up under high DPI settings.,,,
Wszystkie czasy w strefie CET. Aktualna godzina: 06:32.
