Ok thank you. So what's the method to do that?
209 series 1.54 should be from 2020, thus it should work. Just don't update to 1.55. And don't use 211 series 1.54!
Hi everybody, Have a BDR-209EBK, firmware version 1.54, can this be crossflashed to make it UHD friendly? Many thanks in advance.
Hi, sent a PM but new user so not sure it will be delivered. Have a BDR-209DBK, firmware version: 1.10/ID61, can this be crossflashed to make it UHD friendly? Many thanks in advance.
hi, i would also like to flash my bdr-209ebk 1.52 to be uhd friendly.
thanks if someone can help me |
Good day, I was wondering if you can help find the cross flash software for my bdr-209ebk to make it UHD friendly. Thanks
| Wszystkie czasy w strefie CET. Aktualna godzina: 06:18. |
