I too have a BDR209-ebk looking to get 4k capability. What is the method to do this?
Hi at all.
I have a 209M and want Crossflash it to UHD Support. Can you help me please? Cytat:
Thank you very much, the crossflashing worked and my drive can now read UHD disks.
Hello everybody. I want to crossflash my BDR-209EBK to a BDR-211 to get UHD support, my drive info:
Great, it worked very well, thanks a lot.
I just stubmled over this thread and I hope I can find some help with crossflashing my BDR209D to a BDR211EBK.
Kod:
Laufwerksinformation |
PM sent.
Thanks. |
Hi. Can someone help me to flash my drive? Thanks in advance.
Welcome to the forums, CDOldie. Please check your PM.
BDR-209 to a BDR 211
Hello to all Users and Helpers in this Forum! :)
I’m glad to find professionals. I’m new in flashing Rom-Drives. My question: I have a Pioneer BDR-209EBK Drives from 2016. Laufwerksinformation Produzent: PIONEER Produkt: BD-RW BDR-209M Revision: 1.34 Firmware-Datum: 2016-04-25 Markierungen der Bus-Verschlüsselung: 13 Highest AACS version: 81 LibreDrive Information Status: Enabled Drive platform: RS8600 Firmware name: PIONEER BDR-209 Firmware type: Original (unpatched) Firmware version: 1.34/ID60 DVD all regions: Yes BD raw data read: Yes BD raw metadata read: Yes Unrestricted read speed: Yes I would like to crossflash it to the BDR-211 Drive for UHD Support. What Firmware should I download from the Forums Downloadpage? Is it the Pioneer is it the BDR-211EBK / UBK or the S11J-X Firmware? Extracting the exe with 7 zip? Cossflashing with BDRFlash Tool? …But I cannot find the Tool anywhere. I hope you can understand me, my english is not so good, and sorry …my Polish is even worse, if non-existent. Thank you for your support in advance. Best wishes CDOldie |
Thanks Jadburner |
| Wszystkie czasy w strefie CET. Aktualna godzina: 06:18. |
