-   Flashowanie/Firmware/Podkręcanie napędów optycznych (https://forum.cdrinfo.pl/f29/)
-   -   Crossflash BDR-209EBK to BDR211EBK (https://forum.cdrinfo.pl/f29/crossflash-bdr-209ebk-bdr211ebk-98829/)
tahitibub 14.03.2026 00:41
Hello @Coopervid,
Don't worry, I didn't pay @billycar11 (and that's a good thing, because I'm pretty broke right now!). I did, however, pay for my MakeMKV license.
In fact, jabdburner provided me with the flashing software, the appropriate firmware file, and the instructions (it's pretty straightforward).
Everything went as planned, the only thing I couldn't do was back up the old firmware
Now I can play 4K UHD movies on my Pioneer player. A mega big thank you to @jadburner and you!
NB: I do have one question, though ... Is there an RPC-1 version of the BDR-211UBK firmware?
Coopervid 13.03.2026 00:57
Napisany przez jadburner (Post 1477156)
Check your PM.
Don't pay Billy. jabdburner will take care of this and he has done already.
jadburner 12.03.2026 19:01
Napisany przez tahitibub (Post 1477150)
Hello,
First of all, thank you for welcoming me to this forum.
I'm French, and unfortunately I do not speak Polish. I will therefore write this message in English, and I hope that this is okay for you.
I have a Pioneer BDR-209MBK drive that I would like to unlock so that it can play 4K UHD videos.
If I understand correctly, it seems possible to flash it with the firmware from a BDR-211, but I have not been able to find detailed instructions and the necessary files to do it. In addition, I would like to backup the current firmware before flashing the new one.
Could someone send me a detailed tutorial with the necessary files?
Thank you.
Below MKV drive info:
Drive Information
Manufacturer: ASUS
Product: BW-16D1H-U
Revision: E104
Serial number: XXXXXXXXXXXX
Firmware date: 2017-06-14
Bus encryption flags: 1B
LibreDrive Information
Status: Enabled
Drive platform: RS8600
Firmware name: PIONEER BDR-209
Firmware type: Original (unpatched)
Firmware version: E104/ID71
DVD all regions: Yes
BD raw data read: Yes
BD raw metadata read: Yes
Unrestricted read speed: Yes
No disc inserted
Check your PM.
billycar11 12.03.2026 16:59
Hello,
Thank you.
Drive Information
Manufacturer: ASUS
Product: BW-16D1H-U
Revision: E104
Status: Enabled
No disc inserted
PMed you
tahitibub 12.03.2026 13:21
Hello,
Thank you.
Drive Information
Manufacturer: ASUS
Product: BW-16D1H-U
Revision: E104
Status: Enabled
No disc inserted
jadburner 20.02.2026 03:34
Napisany przez gary83 (Post 1476939)
Hi,
I came across this post and joined the forum, DVRTool v1.0 - firmware flashing utility for Pioneer DVR/BDR drives . I hope you are still taking requests, the drive info is below.
I tried to pm but does not appear to have worked.
Drive Information
OS device name: /dev/sr0
Current profile: BD-ROM
Manufacturer: PIONEER
Product: BD-RW BDR-UD03
Revision: 1.14
Serial number:
Firmware date: 2020-06-15
Highest AACS version: 68
Status: Enabled
Drive platform: RS8511
Firmware name: PIONEER BDR-US03
Firmware version: 1.14
Is it possible to also get the tool to dump the firmware?
Thank you for your time.
Check your PM.
gary83 20.02.2026 01:56
Hi,
Drive Information
Revision: 1.14
Serial number:
Status: Enabled
jadburner 14.02.2026 20:32
Napisany przez myscha (Post 1476856)
Hello, is it possible to cross-flash the following drive?
Yes. Check your PM.
myscha 14.02.2026 19:08
Laufwerksinformation
OS-Gerätename: E:
Produzent: PIONEER
Produkt: BD-RW BDR-209M
Revision: 1.30
Serienummer: -
Firmware-Datum: 2014-12-05
Markierungen der Bus-Verschlüsselung: 13
Highest AACS version: 53
Status: Enabled
Firmware version: 1.30/ID60
Keine Disk eingelegt
arbelos 01.02.2026 20:13
Napisany przez jadburner (Post 1476630)
Check your PM.
Crossflash was successful, thanks again jadburner!
jadburner 28.01.2026 02:05
Napisany przez arbelos (Post 1476625)
Just received a Pioneer BDR-209D. Hoping it is possible to cross-flash the drive I think to 211?. I have added my drives info below.
Thank you for the help.
Check your PM.
arbelos 28.01.2026 00:33
Drive Information
OS device name: D:
Product: BD-RW BDR-209D
Revision: 1.30
Serial number: -
Firmware date: 2014-12-05
Bus encryption flags: 13
Status: Enabled
Firmware version: 1.30/ID61
No disc inserted
jadburner 10.01.2026 08:13
Napisany przez Beaker (Post 1476417)
Hello! Here is a BDR-209EBK which should be capable to read UHD discs also. What shall we do?
Drive information
OS device name:
Product: BD-RW BDR-209M
Revision: 1.30
Serial number:
Status: Enabled
No disc inserted
Thank you very much for your support in advance!
Check PM.
Beaker 09.01.2026 23:12
Drive information
OS device name:
Revision: 1.30
Serial number:
Status: Enabled
No disc inserted
jadburner 03.01.2026 04:50
Napisany przez Nakamura (Post 1476319)
Hello THANK YOU SO MUCH for your help!!! Can I also restore the original state? If so, could you please also send me the V8.11 (Buffalo) or the BDR-209M files? Thanks again Regards
Check PM.
Wszystkie czasy w strefie CET. Aktualna godzina: 04:57.
