Just successfully crossflashed my "rev. 1" BDR-S08XLT to BDR-211UBK and ripping a UHD BD for the first time. Thank you jadburner for your generous help! Also shout out to blackened2687 (and all the people who helped) for the great work.
I actually did it through a Windows KVM on Linux by the means of "SCSI passthrough" (virtio-scsi + scsi-generic), so although your mileage could vary (as it involves quite a few "components" that might occasionally break in one sense or another, such as the respective drivers in the Linux kernel, qemu and the virtio-scsi Windows driver), at the very least it could work. (Now I'm wondering if it would even work through wine...given that it apparently works well for ImgBurn I suppose there's at least some support for SPTI...?) Btw because my S08 is already a half-dead drive (red laser down; tray is hard to eject), I'm thinking of sourcing another Pioneer drive from the local second-hand market, but I'm having the following doubt:
Hello, I have a Pioneer BDR-209BDK that I'd like to crossflash to BDR-211 to be able read UHD discs with it. Is it possible ? Thanks in advance!
Drive Information OS device name: F: Manufacturer: PIONEER Product: BD-RW BDR-209D Revision: 1.30 Serial number: Firmware date: 2014-12-05 Bus encryption flags: 13 Highest AACS version: 77 LibreDrive Information Status: Enabled Drive platform: RS8600 Firmware name: PIONEER BDR-209 Firmware type: Original (unpatched) Firmware version: 1.30/ID61 DVD all regions: Yes BD raw data read: Yes BD raw metadata read: Yes Unrestricted read speed: Yes No disc inserted |
I just did so. Thanks Jad, much appreciated
Hello all! First off, thankful for this community and apologies for typing in English. I was lucky enough to come across 3 kinds of pioneer drives within the last couple months and much like others, have been having a hard time finding instructions or the appropriate firmware to flash the pioneer drives to rip 4k uhd in make mkv or if any of these 3 are already ready to go. I am thankful of any help people may be able to provide. I didn't have any issues flashing other LG drives. These are the 3 types of pioneer drives I have. Thanks!
1. Pioneer- 212 DBK Drive Information Manufacturer: PIONEER Product: BD-RW BDR-212D Revision: 1.02 Serial number: DGDL056186WL Firmware date: 2022-03-16 Bus encryption flags: 13 LibreDrive Information Status: Enabled Drive platform: RS8F00 Firmware name: PIONEER BDR-212T Firmware type: Original (unpatched) Firmware version: 1.02/ID61 DVD all regions: Yes BD raw data read: Yes BD raw metadata read: Yes Unrestricted read speed: Yes 2. Pioneer 209-DBK Drive Information Manufacturer: PIONEER Product: BD-RW BDR-209D Revision: 1.51 Serial number: SGDL054224WL Firmware date: 2018-05-08 Bus encryption flags: 13 LibreDrive Information Status: Enabled Drive platform: RS8601 Firmware name: PIONEER BDR-209 Firmware type: Original (unpatched) Firmware version: 1.51/ID61 DVD all regions: Yes BD raw data read: Yes BD raw metadata read: Yes Unrestricted read speed: Yes Drive Information Manufacturer: PIONEER Product: BD-RW BDR-212V Revision: 1.02 Serial number: DGDL027832WL Firmware date: 2022-05-31 Bus encryption flags: 13 LibreDrive Information Status: Possible, not yet enabled Drive platform: Pioneer RS8F00 Firmware version: ID06 |
Its truly amazing and simply wonderful: After a hassle-free update, this quite old drive now reads 4K UHDs and DVD-RAMs as well. Many thanks to everyone who made this possible!
Have a great weekend! |
Hello! Here is a BDR-208DBK. It was made 07/2013 and is quite older than a BDR-211. There is no BDXL label on it's tray panel. I am wondering if this drive may be capable for UHDs also? I assume someone has unfortunately already done a firmware update in the past:
------------------------------------- Drive information OS device name: Manufacturer: PIONEER Product: BD-RW BDR-208D Revision: 1.50 Serial number: Firmware date: 2015-09-24 Bus encryption flags: 13 Highest AACS version: 68 LibreDrive Information Status: Enabled Drive platform: RS8301 Firmware name: PIONEER BDR-208 Firmware type: Original (unpatched) Firmware version: 1.50/ID61 DVD all regions: Yes BD raw data read: Yes BD raw metadata read: Yes Unrestricted read speed: Yes No disc inserted ------------------------------------- Thank you very much for your support in advance! |
Hi guys, first of all, sorry for posting in english. I've got the following drive:
Kod:
Drive InformationThanks in advance for any help! |
im now looking for people with 12/22+ FW for some tests |
Hello @billycar11
I sent you a private message 2 days ago. Perhaps you didn't got it ? |
Had and extra code and just wanted to give it away but everyone told you don't talk to me so whatever |
| Wszystkie czasy w strefie CET. Aktualna godzina: 04:58. |
