Link works perfect , forum engine will not host big files like 16mb :D hence is linked outside . how to use zippy, did you try BIG button DOWNLOAD NOW with arrow pointing down ?
I too have a LG BU40N REV 1.03 2019 Model. Mine is enclosed in a Vantec USB 3.0 SATA Enclosure. I used to make backups all the time but that was years ago and this is frustrating. This flasher tool seems to only be able to be downloaded on "ZIPPYFILE" which I can't figure out how to download the file. All downloads lead me to crap that I don't want to install on my computer. I'm just trying to downgrade my firmware from 1.03 to 1.00. I hope you can help a newb. Used to actually be a computer technician but it was almost 20 years ago. Thank you.
Is there a tool that can backup the original firmware on this drive. I believe that some where on this forum that a tool does exist. Please advise. |
https://www.cdrinfo.pl/bios/17327060657 https://www.cdrinfo.pl/bios/18029213725 version 1.V1-02 has only a lock for the update method unlocked by factory installer .. I do not know the firmware version 1.D.x but VinPower has a lot of models of special duplicators ..VinPower, Rimage, Primera, and recently purchased the Acard brand .. |
VinPower LG WH16NS58 \VinPower firmware: 1.V1 1.V1-02 1.V2 1.V5 |
1.V5 - this is a special firmware from VinPower |
Found some answer here - https://forum.cdrinfo.pl/f107/vinpow...ml#post1404621
Ideally we should take the 1.V5 and add the ability to read the encrypted data as it is in 1.0 version |
I mean, is any sense of, for example, of crossflasing BH16NS55 to WH16NS58 version 1.V5 or 1.00 version will be enough?
What are the differences between 1.00 and 1.V5 of WH16NS58 ? |
DosFlash V2.0 patched to support BH16NS40/BH16NS55 drives |
Hello,
I can see that the there is a 1.V5 version firmware for WH16NS58 DUP on their site - https://www.vinpowerdigital.com/main...downloads.aspx If you download it, it looks like an ordinary LG firmware with some header. I've cut the header and uploaded it to https://www109.zippyshare.com/v/eJ4nnxdZ/file.html Do you think it's worth trying? Or the newer version has the ripping restrictions and there is no sense of using it? |
Are blocked and BluRay drives and AACS 2 decryption programs. |
Good czary2mary.
I've been talking Deuhd. They have told me they are going to work with this model Buffalo BRUHD-PU3-BK - Ultra HD Blu-Ray USB3. Many friendly units are being blocked by firmware and by windows. Even surely the new disc will bring a new security system new protection v2.1 regards |
Buffalo BRUHD-PU3-BK - Ultra HD Blu-Ray USB3 -Slim (klon \OEM modelu Pioneer)
Pioneer BDR-XD07J-UHD - Ultra HD Blu-Ray USB3 -Slim Żaden Pioneer nie umożliwia na dzień dzisiejszy tworzenia kopii mediów UHD \4K BluRay . Również wszystkie nowe LG USB \ Asus USB zostały po-blokowane poprzez zainstalowanie firmware który uniemożliwia dostęp programom kopiującym \zgrywającym UHD do materiałów \nośników UHD. Musisz szukać modeli napędów przyjaznych dla UHD ASUS USB \ LG USB ze starszym oprogramowaniem . |
| Wszystkie czasy w strefie CET. Aktualna godzina: 18:27. |
