Stary 14.09.2023, 23:08   #901
jadburner
Avatar użytkownika jadburner
Data rejestracji: 07.03.2017
Napisany przez lala64 Podgląd Wiadomości
Thank you very much
Crossflashing went well and I'm now able to play my UHD discs
Excellent! Congratulations!
jadburner jest offline
Stary 15.09.2023, 14:23   #902
Oinker
Data rejestracji: 08.11.2022
Oinker zaczyna zdobywać reputację <1 - 49 pkt>
On Pioneer's web site, firmware 1.03 for the BDR-212DBK was updated December 21, 2022. So it is only firmware versions 1.02 and earlier that can be crossflashed.
Ok, I just downgraded my other 212M from S12 1.03 to S12U 1.02, then updated to S12U 1.03. 1.03 seems to be still downgradable and crossflashable, 1.04 (and future firmwares) aren't anymore.
Ostatnio zmieniany przez Oinker : 15.09.2023 o godz. 14:42
Oinker jest offline
Stary 15.09.2023, 17:48   #903
jadburner
Napisany przez Oinker Podgląd Wiadomości
The "safe" firmware versions are drive-specific. On the BDR-212 it is 1.02 and earlier. On the other 212/S12 models, it's 1.03 and earlier. You can tell by looking at the firmware dates on this web page; any firmware dated December 2022 and later cannot be crossflashed or downgraded.
Stary 26.09.2023, 22:19   #904
groats
Data rejestracji: 26.09.2023
groats w tym momencie nie ma Reputacji dodatnich ani ujemnych <0  pkt>
Hello,
I'm looking for a way to crossflash my new Pioneer BDR-XS07TS to a UHD-friendly BDR-XS07TSUHD.
I stumbled across DVRTool, which my drive doesn't support, and am now looking for the newer BDRFlash.
I also have an old Pioneer BDR-208DBK drive in the basement, which I would like to make UHD-friendly, too.
Thanks in advance!
groats jest offline
Stary 27.09.2023, 04:23   #905
jadburner
Napisany przez groats Podgląd Wiadomości
Hello,
Thanks in advance!
Welcome to the forums, groats!
PM sent.
Stary 05.10.2023, 22:41   #906
Oinker
Pioneer released a bunch of new firmwares for 212 & 213 series drives V1.05, changes:
Added a new function "Damage Prevention mode for music CD"
Improved operational stability
Still NOT recommended to update due to downgrade & crossflash protections.
Oinker jest offline
Stary 06.10.2023, 00:07   #907
jadburner
Thank you, Oinker. You are correct. Pioneer is doing everything they can to trick owners into flashing and crippling their drives with newer firmware.
Stary 22.10.2023, 01:29   #908
JuliusC
Data rejestracji: 14.05.2023
JuliusC w tym momencie nie ma Reputacji dodatnich ani ujemnych <0  pkt>
Hello,
I just got a Pioneer BDR-209EBK... and I'd like to crossflash it so it can read UHD disks. From what I read, others have been able to do so. Any help would be greatly appreciated.
Drive details (from MakeMKV):
Drive Information
Manufacturer: PIONEER
Product: BD-RW BDR-209M
Revision: 1.30
Firmware date: 2014-12-05
Bus encryption flags: 13
Highest AACS version: 77
LibreDrive Information
Status: Enabled
Drive platform: RS8600
Firmware name: PIONEER BDR-209
Firmware type: Original (unpatched)
Firmware version: 1.30/ID60
Big thanks in advance!
JuliusC jest offline
Stary 22.10.2023, 05:58   #909
jadburner
Napisany przez JuliusC Podgląd Wiadomości
Hello,
Drive Information
Revision: 1.30
Status: Enabled
JuliusC - PM sent.
Stary 22.10.2023, 21:46   #910
JuliusC
It's working!
Big THANKS to all those involved in this tool, and to Jadburner for the help and support.
Stary 26.10.2023, 17:21   #911
dev
Data rejestracji: 26.10.2023
dev w tym momencie nie ma Reputacji dodatnich ani ujemnych <0  pkt>
Hi, I have this BDR-UD03ASC slim drive:
Drive Information
Product: BD-ROM BDCUD03AS
Revision: 1.00
Serial number: NHDL000680WL
Firmware date: 2014-04-01
Bus encryption flags: 1B
Status: Possible, not yet enabled
Drive platform: Pioneer RS8590
Firmware version: ID23
Is it possible to crossflash it to enable LibreDrive? Thanks in advance.
dev jest offline
Stary 27.10.2023, 00:38   #912
jadburner
Napisany przez dev Podgląd Wiadomości
Drive Information
Revision: 1.00
Welcome to the forums, dev. Unfortunately, your drive is a BDC-UD03 combo drive, not a BDR-UD03. BDRFlash only supports crossflashing to BDR drives. You will need to work with the MakeMKV developers to see if they can enable support for it.
Stary 27.10.2023, 00:59   #913
dev
Hello jadburner and thank you very much.
I'm not sure which type applies to this drive, because the sticker says BDR, but MakeMKV reads BDC.
dev jest offline
Stary 29.10.2023, 18:56   #914
jadburner
Thanks for the extra information you provided, dev. We'll work with you to see if we can get your drive crossflashed to a BDR drive. Check your PM.
Stary 09.11.2023, 05:09   #915
HotDrive
Data rejestracji: 09.11.2023
HotDrive w tym momencie nie ma Reputacji dodatnich ani ujemnych <0  pkt>
Hi guys, thanks for letting me join this awesome forum :-)
I am running a Pioneer BDR-209EBK (listed as BDR-209M) with firmware 1.20
Can you help me flashing it to something UHD compatible?
Many thanks in advance
HotDrive jest offline
dvrtool, pioneer
Pioneer BD Drive Utility czary2mary Programy do nagrywania, testowania, diagnostyki 16 05.02.2022 08:55
Linkownia\ firmware do CD\DVD\BluRay czary2mary Flashowanie/Firmware/Podkręcanie napędów optycznych 2 24.08.2019 18:09
[Komentarze] Flash Utility for LiteOn-made Drives i biblioteka biosów w wersji BIN -Sid-The-Rat=> Flashowanie/Firmware/Podkręcanie napędów optycznych 209 10.02.2006 15:01
Flash Utility for LiteOn-made Drives i biblioteka biosów w wersji BIN SoBal Flashowanie/Firmware/Podkręcanie napędów optycznych 0 28.09.2003 22:37
Wszystkie czasy w strefie CET. Aktualna godzina: 03:19.
