Stary 29.09.2026, 08:37   #16
cashkey1
Data rejestracji: 25.01.2025
cashkey1 w tym momencie nie ma Reputacji dodatnich ani ujemnych <0  pkt>
i downloaded your freemkv software. thanks.
but i noticed that to rip a uhd disc, the program doesnt have the keydb incorporated within your program. any chance you could include the keydb keys into your program to work straight out of the box?
something like what makemkv has done? it has automatic keydb's incorporated in it.
Ostatnio zmieniany przez joujoujou : 29.09.2026 o godz. 23:59
cashkey1 jest online   Odpowiedz cytując ten post
Stary 29.09.2026, 08:47   #17
mattjackson
Data rejestracji: 29.09.2026
mattjackson w tym momencie nie ma Reputacji dodatnich ani ujemnych <0  pkt>
i am choosing to not distribute keys. they are easily obtained anyways, keydbs website literally had a download zip button. that said there is an online key server you can register for and use, then no keydb needed. Info on discord. But no I wont be putting keys in the app itself.
also for reference makemkv doesnt use keydb it has its own key sources it bundles. not the public keys from keydb. The online key server freemkv works with is also not keydb but a larger collection.
mattjackson jest offline   Odpowiedz cytując ten post
Stary 29.09.2026, 10:42   #18
cashkey1
ah, okie. thanks. anyway do keep up the good work done.
Stary 29.09.2026, 18:28   #19
trev.bot flash
Moje przetestowane napędy na sofcie od Trevor-a = Good job
Pioneer XD05JP2 fw.3.11 do Pioneer XD06U UHD 1.11
Flashing Pioneer drives with firmware 12/2022+-2026-09-25_10-12-43.jpg
Flashing Pioneer drives with firmware 12/2022+-2026-09-25_11-32-23.jpg
Stary 29.09.2026, 18:30   #20
trev.bot flash
Pioneer BDR-212BK do Pioneer BDR-212U UHD 1.05
Flashing Pioneer drives with firmware 12/2022+-2026-09-29_16-23-37.jpg
Flashing Pioneer drives with firmware 12/2022+-2026-09-29_16-29-36.jpg
Stary 29.09.2026, 20:10   #21
mattjackson
We should be trying to backup oem drives before we crossflash imo. Otherwise we lose the original firmware that may not exist in the public domain. Is anybody saving their original firmware or just flashing?
Stary wczoraj, 10:49   #22
Stingray
Data rejestracji: 12.02.2024
Stingray zaczyna zdobywać reputację <1 - 49 pkt>
Could you tell me why many people choose the Pioneer BDR-212U firmware (or similar) instead of the S12JX? Personally, I install the MAX S11/S12 firmware versions to use the Pioneer utility for enabling Silent Mode foremost. To be honest, I almost never need UHD, since I mostly burn discs
Stingray jest offline   Odpowiedz cytując ten post
Stary wczoraj, 12:52   #23
Oinker
Data rejestracji: 08.11.2022
Oinker zaczyna zdobywać reputację <1 - 49 pkt>
Smile
Thanks!
I downgraded my S13U with firmware 1.05 to 1.02 using beta 62, then I crossflashed it to S13J-X 1.02 with BDRFlash 1.00 and updated to 1.03 using the official Pioneer updater:
Flashing Pioneer drives with firmware 12/2022+-s13u102.png   Flashing Pioneer drives with firmware 12/2022+-s13u-s13jx103.png
Oinker jest offline   Odpowiedz cytując ten post
Stary wczoraj, 12:55   #24
Oinker
Now I hope I could do the same with my 212M @ S12 1.04.
Stary wczoraj, 17:11   #25
mattjackson
"I downgraded my S13U with firmware 1.05 to 1.02 using beta 62, then I crossflashed it to S13J-X 1.02 with BDRFlash 1.00 and updated to 1.03 using the official Pioneer updater:"
Thats a great test workflow for me to look into! Downgrade + cross flash + upgrade, Amazing.
Stary wczoraj, 17:22   #26
mattjackson
Added a couple hundred more firmwares btw to the site
12/2022+, drives, firmware, flashing, pioneer
Wszystkie czasy w strefie CET. Aktualna godzina: 02:03.
