Stary 29.09.2026, 09:47   #16
mattjackson
Data rejestracji: 29.09.2026
mattjackson zaczyna zdobywać reputację <1 - 49 pkt>
i am choosing to not distribute keys. they are easily obtained anyways, keydbs website literally had a download zip button. that said there is an online key server you can register for and use, then no keydb needed. Info on discord. But no I wont be putting keys in the app itself.
also for reference makemkv doesnt use keydb it has its own key sources it bundles. not the public keys from keydb. The online key server freemkv works with is also not keydb but a larger collection.
Ostatnio zmieniany przez joujoujou : 30.09.2026 o godz. 00:59
mattjackson jest offline   Odpowiedz cytując ten post
Stary 29.09.2026, 11:42   #17
cashkey1
Data rejestracji: 25.01.2025
cashkey1 w tym momencie nie ma Reputacji dodatnich ani ujemnych <0  pkt>
ah, okie. thanks. anyway do keep up the good work done.
cashkey1 jest offline   Odpowiedz cytując ten post
Stary 29.09.2026, 19:28   #18
trev.bot flash
Moje przetestowane napędy na sofcie od Trevor-a = Good job
Pioneer XD05JP2 fw.3.11 do Pioneer XD06U UHD 1.11
Flashing Pioneer drives with firmware 12/2022+-2026-09-25_10-12-43.jpg
Flashing Pioneer drives with firmware 12/2022+-2026-09-25_11-32-23.jpg
Stary 29.09.2026, 19:30   #19
trev.bot flash
Pioneer BDR-212BK do Pioneer BDR-212U UHD 1.05
Flashing Pioneer drives with firmware 12/2022+-2026-09-29_16-23-37.jpg
Flashing Pioneer drives with firmware 12/2022+-2026-09-29_16-29-36.jpg
Stary 29.09.2026, 21:10   #20
mattjackson
We should be trying to backup oem drives before we crossflash imo. Otherwise we lose the original firmware that may not exist in the public domain. Is anybody saving their original firmware or just flashing?
Stary 30.09.2026, 11:49   #21
Stingray
Data rejestracji: 12.02.2024
Stingray zaczyna zdobywać reputację <1 - 49 pkt>
Could you tell me why many people choose the Pioneer BDR-212U firmware (or similar) instead of the S12JX? Personally, I install the MAX S11/S12 firmware versions to use the Pioneer utility for enabling Silent Mode foremost. To be honest, I almost never need UHD, since I mostly burn discs
Stingray jest offline   Odpowiedz cytując ten post
Stary 30.09.2026, 13:52   #22
Oinker
Data rejestracji: 08.11.2022
Oinker zaczyna zdobywać reputację <1 - 49 pkt>
Smile
Thanks!
I downgraded my S13U with firmware 1.05 to 1.02 using beta 62, then I crossflashed it to S13J-X 1.02 with BDRFlash 1.00 and updated to 1.03 using the official Pioneer updater:
Flashing Pioneer drives with firmware 12/2022+-s13u102.png   Flashing Pioneer drives with firmware 12/2022+-s13u-s13jx103.png
Oinker jest offline   Odpowiedz cytując ten post
Stary 30.09.2026, 13:55   #23
Oinker
Now I hope I could do the same with my 212M @ S12 1.04.
Stary 30.09.2026, 18:11   #24
mattjackson
"I downgraded my S13U with firmware 1.05 to 1.02 using beta 62, then I crossflashed it to S13J-X 1.02 with BDRFlash 1.00 and updated to 1.03 using the official Pioneer updater:"
Thats a great test workflow for me to look into! Downgrade + cross flash + upgrade, Amazing.
Stary 30.09.2026, 18:22   #25
mattjackson
Added a couple hundred more firmwares btw to the site
Stary 02.10.2026, 03:25   #26
cashkey1
hi mattjackson, do you happen to have the pioneer BDR-UD02 stock firmware by chance?
Stary 03.10.2026, 05:01   #27
mattjackson
Not yet, i think im about 200 short from "everything" and I am definitely down to the hard to get ones. I just got a UD03 1.03.
All will be up on the website soon including a new search which should show you what cross flashes are compatible. So if your on X it will say you can got to Y or Z and you just download what you want to be on and flash it. No multistep games of downgrade > cross flash > upgrade....in theory
Stary 03.10.2026, 06:43   #28
cashkey1
Cool!!! but sad that its very hard to get that elusive BDR-UD02 firmware...i bricked it when i flashed it first to ud03, then eventually to ud04. and i didnt know how to back up the original ud02 firmware first.
Stary 03.10.2026, 06:50   #29
mattjackson
My flasher can backup to an OEM style format (kernel + normal), meaning if you backed up I can upload it for others to download and flash as is.
Give me a few days and the updated flasher with the backup working will be up there.
Stary 03.10.2026, 07:26   #30
cashkey1
nice buddy. just hoping that i can bring my ud02 back to life again..
12/2022+, drives, firmware, flashing, pioneer
Wszystkie czasy w strefie CET. Aktualna godzina: 01:04.
