Stary 22.07.2023, 15:23   #1
PlextorMan
Data rejestracji: 21.07.2023
PlextorMan w tym momencie nie ma Reputacji dodatnich ani ujemnych <0  pkt>
Problem with CrossFlash Lite-On IHBS212 to Plextor PX-LB950SA
Hello,
I recently bought a new Lite-on IHBS212 (retail) on eBay and I found the following problem:
The Drive burns on the media: "Verbatim BD-RE 2x" at only 1x speed.
Burning is slow and poor quality.
See Image below:
Therefore, I decided to update the firmware in my drive from: https://www.firmwarehq.com/download_..._HL05.EXE.html
to the version: "HL05" (Lite-on IHBS212 2) and the problem was not solved.
Then I tried to CrossFlash at: "Plexor PX-LB950SA" using a binary file: "Plextor_px-LB950SA_GEN1_1.06.bin". Because my version of the drive is:
"Lite-on IHBS212.BD Writer Board Rev: 01 Manufactured Date: March 2011." And I stopped at the program: "Flash program V2.3.46".
See Picture below:
After flashing, the drive remains still as Liteon IHBS212.
I restored the firmware back using "EEPROM UTILITY SE 6.2.0".
I do not know if I have the right version of this program for Lite-on IHBS212 Rev1.
UPDATE (change of Link): I followed the instructions here: Crossflash BluRay LiteOn iHBS+OEM+klony
My question is:
How can I complete this CrossFlash to solve this problem?
*** Thank you very much.***
Ostatnio zmieniany przez PlextorMan : 22.07.2023 o godz. 16:47
PlextorMan jest offline   Odpowiedz cytując ten post
Stary 22.07.2023, 15:54   #2
Oinker
Data rejestracji: 08.11.2022
Oinker w tym momencie nie ma Reputacji dodatnich ani ujemnych <0  pkt>
You need to drag'n'drop the firmware .bin file on the FUFlasher.exe in Windows Explorer. It'll auto-start the FUFlasher then, and should show the Update version 1.06. Ensure you're on the correct drive before flashing! Regarding the slow write speed, do you have verification during write active? That'll slow down the write speed to 50% of what you've chosen (i.e. 1x in this case of 2x writing).
Oinker jest offline   Odpowiedz cytując ten post
Stary 22.07.2023, 16:44   #3
PlextorMan
Napisany przez Oinker Podgląd Wiadomości
Drag'n'drop for this program (fu_flasher.exe) does not work, the program does not allow the firmware to be dragged into the window.
And the burning is equally slow even in the program "Nero Burning Rom".
Stary 22.07.2023, 17:21   #4
Oinker
Not into the program window, the exe in Explorer, i.e. in the pic above you click on the bin file hold it and just drag it on the exe file above the bin. In Nero you have to open Recorder menu -> Drive selection -> Options button -> Disable defect management.
Stary 22.07.2023, 20:01   #5
PlextorMan
OK, The Flashing Was Successful. Thanx!
The speed of burning in Nero is already OK, but in Opti Drive Control it cannot be set.
Is there any possibility to turn this off on this drive?
And one more question:
How can I restore the original (backed) Lite-On firmware for multiple tests?
I attempted to restore with: "EEPROM UTILITY with 6.2.0" (Restore Eeprom Button) and it failed.
Thank you.
Stary 22.07.2023, 21:01   #6
Oinker
The EEPROM is only for the laser calibration data, it's specific for each drive and shouldn't be changed. In order to go back to the original firmware you need a bin file og it, and use it with the FUFlasher like you did with the Plextor firmware.
Stary 22.07.2023, 21:52   #7
PlextorMan
Unfortunately, it is not possible.
If I drag the file: "ATAPI_iHBS212_2_HL05.bin" on the Exe file (FU_Flasher.exe).
The program starts and exits immediately. Backup BIN file IHBS212 It has only 8 kb size. Plextor Firmware has 2 MB.
I don't know where the problem could be.
But the program: "EEPROM Utility SE 6.2.0" always creates only 8KB file.
Stary 22.07.2023, 23:07   #8
Oinker
Yes, the EEPROM Utility just saves the laser calibration data, thus the 8 kB file, it can not be used for firmware flashing. Only to restore the laser calibration data. You must use a firmware bin file, which is 2 MB.
Stary 22.07.2023, 23:23   #9
PlextorMan
OK, Thanx.
crossflash, ihbs212, lite-on, plextor, problem, px-lb950sa
Wszystkie czasy w strefie CET. Aktualna godzina: 20:23.
