-   -   [PS3] Custom Firmware (https://forum.cdrinfo.pl/f106/ps3-custom-firmware-87638/)
szczuru 24.08.2015 13:16
Jest Rebug 4.75 :)
Berion 24.08.2015 14:02
Jest jakiś changelog? ;p
Diabolique 24.08.2015 14:19
a właśnie wlazłem tu, żeby dowiedzieć się coś na temat nowego CFW. ważne, że jest jakieś nowe :szczerb:
ethar 24.08.2015 15:25
Tylko "smaczki":
FEATURES FOR REBUG REX/D-REX EDITION
FEATURE – Dual LV2 Kernels CEX/DEX
(Swap your EID0/LV2 kernel using Rebug Toolbox in seconds)
FEATURE – ALL Retail functions available in CEX mode
(No need to install different firmware)
FEATURE – ALL Debug functions available in DEX mode
FEATURE – FULL ProDG Connectivity in DEX mode
(Full Support on both Normal mode and Cobra mode)
FEATURE – QA Token compatibility
FEATURE – OtherOS++ support enabled
(Use Rebug Toolbox to Boot OtherOS with different LV1 patches)
FEATURE – Package Manager
(Replacement for the standard ‘Install Package Files’ option)
INCLUDED – Rebug Toolbox 02.02.05
(Install included Rebug Toolbox or higher for full compatibility)
PATCHED – Appldr: LV2 memory hash check is disabled
(Memory protection on LV2 is disabled in higher level)
PATCHED – LV1: Disable System Integrity Check
(Safe to use with mismatched COREOS/SYSCON versions or if PS3 is not QA enabled)
PATCHED – LV1: Undocumented function 114
(Allow mapping of protected memory)
PATCHED – LV1: Skip all ACL Checks
(Needed to allow booting of OtherOS)
PATCHED – LV1: Peek and Poke support
(Unused LV1 call 182 and 183)
PATCHED – LV2: Peek and Poke support
(LV2 Syscall 6 and 7)
PATCHED – LV2: Peek and Poke support for LV1
(LV2 Syscall 8 and 9)
PATCHED – LV2: LV1 CALL System call
(LV2 Syscall 10)
PATCHED – Recovery: Prevent accidental OFW update while on Recovery mode
PATCHED – VSH: Allow Unsigned act.dat and *.rif files
PATCHED – VSH: Disable Unlinking/Deleting of act.dat
PATCHED – VSH: Disable NEW PSP DRM Check on Unsigned PSP packages added on OFW 4.75
PATCHED – VSH: Disable Epilepsy Warning for Faster Boot-Up Speed
FUN FEATURE – Fake Save Data Owner
(Use Game Saves from ANY Owner)
FUN FEATURE – In Game Screenshot
(Allows taking screenshots in Game)
FUN FEATURE – Enhanced Remote Play
(This unlocks the limitation of working apps/games for remote play)
FUN FEATURE – Lock/Unlock Trophies (Offline only)
FEATURE – Cinavia protection fully disabled
(Supports optical media/bd iso, AACS must be decrypted)
FEATURE – Cobra 7.1
(Disabled by default, Toolbox required to enable)
FEATURE – 1.42.04 MOD REBUG EDITION
(Full Webman intergration supports both CEX/DEX 4.75)
ethar 24.08.2015 15:28
Właśnie ktoś może potwierdzić jedną rzecz, siedze na Habib 4.70 i mam 2 problemy - nie frustrujące ale jednak:
1) Odpalanie PS2ISO nie wykrywa pada bezprzewodowego (trzeba grać na kablu, bezsensu dla mnie bo pad od PS2 jest już ściorchany - przyciski nie wchodzą jak powinny, a od PS3 mam bardzo krótki kabel który w sumie służy tylko do ładowania).
2) Po wyjściu do Systemu PS3 - po graniu w grę z PS2, nonstop automatycznie mi ją odpala w kółko. Jedyny sposób to rozłączenie konsoli od prądu.
Czy ktoś miał podobne problemy na Habibie? Czy ten Rebug ma podobnie?
Trilu 24.08.2015 16:11
Na 4.70 były takie cyrki ,gry z ps2 na Rebugu ładuje się PS2 ISO / Classic Launcher'em ,wtedy działa bezprzewodowo pad .
Berion 24.08.2015 16:44
@ethar
Ale chodzi o zmiany od ostatniej wersji, nie o ficzery. ;p
ethar 24.08.2015 18:23
@Berion
Obawiam się, że nie wiele się zmieniło od 4.70 poza tym że jest postawiony na 4.75... I tak z połowy funkcji pewnie nie skorzystam do końca życia mojej konsoli. Na dniach sobie zaktualizuje :)
Berion 24.08.2015 18:46
To tak jak ja. ;) Ale przynajmniej można być już spokojnym z tym numerkiem o wszystkie gry i patche.
ethar 24.08.2015 18:55
Dokładnie szczególnie, że już zaraz Phantom Pain - chociaż zastanawiam się bardziej nad zakupem wersji na PC - mam kompa który to uciągnie, możliwość experymentalnego sterowania myszką (albo pada zawsze mogę podłączyć), lepsza grafika i tańszy.
(Dzisiaj sprawdzałem ceny i mniej więcej PC - 179 PS3 -199 PS4 -229)
W dodatku mody - ktoś walnął fajnego moda do GZ w postaci FPP - ale raczej ciekawostka. Chociaż mam nadzieję że kiedyś ktoś się znajdzie kto będzie chciał przenieść np MGS1 albo MG i MG2 na silnik V. Co nie jest takie nierealne jak ostatnio wyczytałem że ktoś przenosi Morrowinda na silnik Skyrima :P
BTW Czy w oficjalnym changelogu OFW 4.75 jest "Poprawa stabilności systemu" ?:D
Berion 24.08.2015 21:14
Na PC. ;]
ethar 24.08.2015 22:38
Napisany przez Berion (Post 1334449)
Na PC. ;]
To miała być ironia ? Bo szczerze nie wiem, znam takich którzy mówią "Hideo się sprzedał jedyny prawdziwy MGS może być tylko na playstation - to jedyna słuszna wersja." Argumenty typu że pierwsze MG były na nesa, a pierwszy MGS także na PC jakoś jakby ich nie słyszeli :P
Ogólnie bym polował na jakiś pakiet MGS: GZ + PP, albo nawet kolekcjonerke (chociaż z tego co widziałem takowej na PC nie ma - tylko XBO oraz PS4).
misiozol 25.08.2015 10:09
Jak cenisz naklejke na konsoli i pudelko w kolory MGS to bierz konsole , inaczej tylko wersje z PC nie ma sensu brac juz konsoli (sam nie wieze ze to napisalem) PC mozna zmapowac pod kontroler na ps3 i to bezprzewodowo ;)
ethar 25.08.2015 11:12
Właśnie ta konsola z MGS'em średnio mnie się podoba szczerze mówiąc - już bardziej podchodzi mi ta z limitowanej Edycji Uncharted na PS4. Póki co budżet mały, poczekam aż wejdą jakieś pierwsze slimy PS4 a gry używane potanieją. To mój przepis na przyszłość mojego konsolowego grania :P
Trilu 07.09.2015 18:56
Wyszedł Rebug 4.75.3 ,dodany spoofer 4.76 w Rebug Toolbox .
MGS wygląda dobrze na ps3 ,ogólnie gra bardzo dobra i warta wydanego grosza .Wciąga jak Uncharted ,a to dobry omen :D
Wszystkie czasy w strefie CET. Aktualna godzina: 09:16.
