-   Zabezpieczenia CD/DVD/Blu-ray (https://forum.cdrinfo.pl/f11/)
-   -   [ARTYKUŁ]Jak wykonać kopię płyt BluRay (https://forum.cdrinfo.pl/f11/artykul-jak-wykonac-kopie-plyt-bluray-95913/)
czary2mary 27.12.2016 20:26
AnyDVD 8.0.9.0
8.0.9.0 2016 12 26
New (Blu-ray): Support for new discs
New (DVD): Support for new discs
Change (Blu-ray): Reverted change from 8.0.4.0, "Failing MFR is no longer fatal on unprotected discs",
as it could create unplayable discs
Change (Blu-ray): If keeping original menus fails, the standard speedmenu is used
Fix (Blu-ray): Hang with black screen during playback with some discs
Some minor fixes and improvements
https://www.redfox.bz/download/SetupAnyDVD.exe
czary2mary 25.12.2016 13:33
AnyDVD 8.0.8.1 Beta
- Merry Christmas
- New (Blu-ray): Support for new discs
- Change (Blu-ray): Reverted change from 8.0.4.0, "Failing MFR is no longer fatal on unprotected discs",
- Change (Blu-ray): If keeping original menus fails, the standard speedmenu is used
- Fix (Blu-ray): Hang with black screen during playback with some discs
- Some minor fixes and improvements
http://sandbox.redfox.bz/SetupAnyDVD8081.exe
czary2mary 16.12.2016 13:01
DVDFab 10.0.1.6
New: Added the support to remove the Cinavia watermark found on Demolition.
Fix: A crash problem when opening DVD discs in certain cases.
Fix: A problem that the second task does not start when using two DVD drives in the Copy module.
Fix: A problem that the remove HD audio option does not work correctly when converting Blu-ray sources to MKV videos in certain cases.
Fix: Some minor changes and improvements.
http://www.dvdfab.cn/mlink/download.php?g=DVDFAB10
czary2mary 13.12.2016 07:44
AnyDVD 8.0.8.0
2016 12 12
- New: Notification icon "Help..." uses an online manual
- Fix (Blu-ray): Regression, remastering could make some discs unplayable
- Fix (DVD): Could not decrypt CSS with some discs and certain drives
DVDFab 10.0.1.5
Fix: A crash problem when converting DVD sources to the saved profile in certain cases.
czary2mary 10.12.2016 08:32
DVDFab 10.0.1.4
DVDFab 10.0.1.4
New: Added the support for the new copy protection found on miwa - ***32080;-***12422;***12356;- limited edition DVD.
New: Added the support to remove the Cinavia watermarks found on Invisible Woman, The Past and Wadjda.
Fix: A crash problem when detecting menu playlist in Blu-ray Copy module, Customize mode.
Fix: A problem that no video file was exported when converting DVDs to MP4/MKV videos with Cloud Decryption Service enabled in certain cases.
Fix: A problem that no video file was exported when converting Blu-ray sources to MKV videos in certain cases.
Fix: A crash problem when saving personal profiles in Video Converter module.
Fix: A problem that no subtitles showed up in the final videos when converting with external subtitles in Video Converter module.
Fix: A problem that the output size switched to DVD-5 when creating DVDs with DVD-9 output size in certain cases.
Fix: A problem that the Start button was disabled when reloading the crashed tasks in the Creator module.
czary2mary 02.12.2016 18:46
DVDFab 10.0.1.3
New: Improved the Cloud Decryption Service for DVDs.
New: Improved the BluPath feature for Blu-rays.
Fix: Improved the UI support for 4K display and high DPI (125%).
Fix: A problem that DVDFab failed to remove Blu-ray region code in certain cases.
Fix: Improved the support for custom menu settings in Blu-ray to DVD Converter, DVD to Blu-ray Converter, DVD Creator and Blu-ray Creator modules.
Fix: A problem that the conversion task can neither be cancelled nor finished if the user account expiry alert pops up.
AnyDVD 8.0.7.2
2016 12 01
http://sandbox.redfox.bz/SetupAnyDVD8072.exe
czary2mary 26.11.2016 09:59
AnyDVDHD 8.0.7.0
8.0.7.0 2016 11 25
czary2mary 23.11.2016 22:01
DVDFab 10.0.1.1
New: Added the support to remove the Cinavia watermarks found on Monk Comes Down the Mountain, Nebraska and Midnight in Paris.
Fix: A crash problem when copying DVD/Blu-ray discs in certain cases.
Fix: Improved the support for Task Queue Manager.
Fix: A problem that the source subtitle is deleted when deleting the external subtitle.
Fix: A problem that the merge feature does not work in Ripper and Video Converter modules.
Fix: A problem that the output Volume Label cannot be renamed in Blu-ray to DVD Converter module.
Fix: A problem that the ***8220;Fit to disc***8221; option does not work in Creator module.
czary2mary 22.11.2016 08:12
DVDFab 10.0.1.0
DVDFab 10.0.1.0 - już oficjalna wersja finalna DVDFab 10
New: Completely redesigned user interface.
New: Added the support to change UI skins.
New: Added the blazing fast cloud decryption service for DVDs.
New: Added the all-new conversion engine in Ripper and Converter modules for 64-bit systems.
New: Added the support to set the online movie poster of the loaded DVD/Blu-ray as UI background.
New: Introduced the all-new task manager for easier task management.
New: Introduced the all-new DVDFab Mini that allows users to get tasks done with the least steps possible.
New: Introduced the archived task feature to save the tasks should the program crash or quit unexpectedly.
New: Introduced the all-new DVDFab Remote app that allows users to check real-time task status of DVDFab on smart phones.
New: Improved the MKV conversion process for better playback compatibility.
New: Completely redesigned operational logics for a better user experience.
Fix: Tons of other minor changes and improvements.
czary2mary 20.11.2016 15:55
AnyDVD 8.0.6.1 2016 11 19
- New (DVD): Support for new discs
http://sandbox.redfox.bz/SetupAnyDVD8061.exe
DVDFab 10.0.0.7 Beta
New: Added the ***8220;Switch to Mini***8221; option.
Fix: A crash problem when deleting tasks in certain cases.
Fix: A problem that the task cannot be restarted after cancellation in certain cases.
Fix: A problem that the output file name does not restore to movie name if users rename and then delete it in Ripper and Video Converter.
Fix: A problem that all the source title names become the same in certain cases if users load multiple sources in Ripper and Video Converter.
Fix: A problem that the profile cannot be changed in Video Converter.
Fix: A crash problem when converting video files to DVDs in certain cases.
czary2mary 18.11.2016 07:19
DVDFab 10.0.0.6 Beta
Wersja DVDFab 10 uzyskało status Beta
czary2mary 15.11.2016 15:54
Ilość załączników: 2
Promocja na DVDFab Platinum \ dożywotnia licencja..
Załącznik 83535
Załącznik 83536
czary2mary 14.11.2016 07:19
DVDFab 10.0.0.4 Alpha
http://www.dvdfab.cn/mlink/download....DVDFAB10_Alpha
New: Added the support to set the movie poster as DVDFab UI background when opening DVD/Blu-ray sources.
New: Improved the support for Copy, Ripper, Converter and Creator modules.
Fix: Fixed some minor bugs and small issues.
czary2mary 09.11.2016 18:35
AnyDVD HD 8.0.6.0
8.0.6.0 2016 11 06
- Testing (Blu-ray 4k): Show supported AACS version of drive
- Some fixes and improvements
czary2mary 09.11.2016 07:20
DVDFab 9.3.2.1
Changes in 9.3.2.1:
New: Added the support for some new Java protections.
New: Added the support for some new copy protections as found on certain Japanese adult DVDs.
New: Improved the support for the DVD Cloud Decryption Service.
New: Added the support to remove the Cinavia watermarks found on Now You See Me 2, The Purge Election Year, Still Alice, Her (2013), Kill Your Darlings, Blue Jasmine, Popstar: Never Stop Never Stopping and Inside Llewyn Davis.
Fix: A crash problem when opening DVD sources in certain cases.
http://dvdfab.cn/dvd-fab-new.htm
http://dvdfab.cn/mlink/download.php?g=DVDFAB9
Wszystkie czasy w strefie CET. Aktualna godzina: 13:53.
