DVDFab 10.0.3.6
New: Added the support to remove Cinavia watermark on the Blu-ray version of The Edge of Seventeen, A Kind of Murder, Arrival (2016), Searching for Sugar Man and Hell or High Water (another version).
New: Added the support to remove Cinavia watermark on the DVD version of Deepwater Horizon. New: Changed the output format of videos by DRM Removal for Apple from M4V to MP4. Fix: Improved the software stability. http://www.dvdfab.cn/mlink/download.php?g=DVDFAB_CNT |
DVDFab 10.0.3.5
Fix: A crash problem when encountering the read error during opening DVD/Blu-ray disc in certain cases.
DVDFab 10.0.3.4 + Passkey 9.1.1.5
DVDFab 10.0.3.4
New: Added the support for some new Blu-ray JAVA protections. New: Added the support to remove Cinavia watermarks on the Blu-ray versions of Hacksaw Ridge, Julieta, Love Is Strange, A Street Cat Named Bob, Sing and the DVD version of Now You See Me 2. New: Added the support for iTunes 12.6 in DRM Removal. New: Added the support to remove the DRM encryptions of Audiobooks and music videos. New: Improved the support for DRM Removal. Fix: Improved the support for the Preview feature. Fix: Improved the support for the conversion engine. Fix: A problem that the video bitrate cannot be set manually in Advanced Settings if AVI XVID profile is selected. Fix: Some minor changes and improvements. http://www.dvdfab.cn/mlink/download.php?g=DVDFAB_CNT Passkey 9.1.1.5 New: Added the support for some new Java protections. New: Added the support to reset the Blu-ray region code of PowerDVD 17. http://www.dvdfab.cn/mlink/download.php?g=PASSKEY |
Any DVD HD 8.1.1.2 Beta
8.1.1.2 2017 04 14
- New (Blu-ray): Support for new discs - New (DVD): Support for new discs - Fix (DVD): Regression problem http://sandbox.redfox.bz/SetupAnyDVD8112.exe |
DVDFab 10.0.3.3 beta
New: Added the support to remove Cinavia watermarks on the Blu-ray versions of Hacksaw Ridge, Julieta, Sing, Love Is Strange, A Street Cat Named Bob, Sing and the DVD version of Now You See Me 2. New: Added the support for iTunes 12.6 in DRM Removal. New: Added the support to remove the DRM encryptions of Audiobooks and music videos. New: Improved the support for DRM Removal. Fix: Improved the support for the Preview feature. Fix: Improved the support for the conversion engine. Fix: A problem that the video bitrate cannot be set manually in Advanced Settings if AVI XVID profile is selected. Fix: Some minor changes and improvements. http://www.dvdfab.cn/mlink/download.php?g=DVDFAB10_BETA |
Any DVD HD 8.1.1.1 Beta
8.1.1.1 2017 04 07
- New (Blu-ray): Support for new discs - New (DVD): Support for new discs http://sandbox.redfox.bz/SetupAnyDVD8111.exe |
Any DVD HD 8.1.1.0
8.1.1.0 2017 04 03
- New (Blu-ray): Support for new discs - New (DVD): Support for new discs - New: PowerDVD 17 is now supported by AnyDVD's unique Cinavia fix - New (Blu-ray): Preserve playlist information in disc.inf of mounted images - Some minor fixes and improvements https://www.redfox.bz/download/SetupAnyDVD.exe |
DVDFab 10.0.3.2
Fix: A problem that the movies cannot be displayed in DRM Removal in certain cases.
Fix: A noise problem when playing the converted DRM-free M4A files in certain cases. Fix: A noise problem when converting DVD sources to MP4 format with mp2 audio tracks in certain cases. http://www.dvdfab.cn/mlink/download.php?g=DVDFAB_CNT |
DVDFab 10.0.3.1
New: Introduced the DVDFab DRM Removal to remove DRM encryptions from relevant Apple contents.
More Info: http://www.dvdfab.cn/drm-removal.htm New: Added the support to remove the Cinavia as found on the Blu-ray Robot & Frank, The To Do List, Ouija: Origin of Evil and Elle. New: Added the support to remove the Cinavia as found on the DVD Mechanic: Resurrection. New: Added a startup guide to introduce Copy (Full Disc, Main Movie) and Ripper modules for first-time users. New: Improved the support for the Blu-ray BluPath. Fix: A failure problem when copying Blu-ray 3D sources to SBS 3D format in Full Disc and Main Movie modes in certain cases. Fix: A failure problem when converting DVD/Blu-ray sources with AVI XVID profile. Fix: A crash problem when starting DVDFab in certain cases. Fix: Some minor changes and improvements. http://www.dvdfab.cn/mlink/download.php?g=DVDFAB_CNT |
DVDFab 10.0.3.0 Beta
For DRM Removal, there is a known problem when displaying the music playlist, some of songs might not be displayed, which will be fixed soon in the next version, together with other minor issues.
New: Introduced the DVDFab DRM Removal to remove DRM encryptions from relevant Apple contents. More Info: http://www.dvdfab.cn/drm-removal.htm New: Improved the support for the Blu-ray BluPath. Fix: A failure problem when converting DVD/Blu-ray sources with AVI XVID profile. Fix: A crash problem when starting DVDFab in certain cases. Fix: Some minor changes and improvements. http://www.dvdfab.cn/mlink/download.php?g=DVDFAB10_BETA |
Any DVD HD 8.1.0.1 Beta
8.1.0.1 2017 03 23
- New (Blu-ray): Support for new discs - New (DVD): Support for new discs - New: PowerDVD 17 is now supported by AnyDVD's unique Cinavia fix - Some minor fixes and improvements http://sandbox.redfox.bz/SetupAnyDVD8101.exe |
Passkey 9.1.1.3 + DVDFab for Linux
Passkey 9.1.1.3
New: Improved the support for Blu-ray BluPath. http://www.dvdfab.cn/mlink/download.php?g=PASSKEY DVDFab for Linux Pierwsza wersja Alpha dla Linux How to Install on Linux: - Open Terminal - Run chomd +x DVDFab_linux.run - Run ./ DVDFab_linux.run Tested OS: the Alpha version has been tested on the Ubuntu system only as of now, but you can also test it on other versions of Linux. What to Try: Copy a Blu-ray in Full Disc and Main Movie modes Copy a DVD in Full Disc and Main Movie modes Convert videos in the Converter module Produce a DVD or Blu-ray with the Creator module Convert a Blu-ray to DVD Known Issues: The preview feature might not work properly as of now; The video edit feature might not work properly as of now; The Customize, Split, Merge, DVD to Blu-ray features might not work properly as of now; It might cause the software to freeze when compressing Blu-rays to BD25 size in certain cases. http://www.dvdfab.cn/mlink/download.php?g=DVDFAB_LINUX |
DVDFab 10.0.2.9 + Passkey 9.1.1.2
DVDFab 10.0.2.9
New: Added the support to remove the Cinavia watermark found on the Blair Witch (Blu-ray version) and the Nerve (DVD version). Fix: A problem that the preview engine failed to initialize in certain cases. Fix: Improved the support for previewing the DVD sources. Fix: Some minor changes and improvements. http://www.dvdfab.cn/mlink/download.php?g=DVDFAB_CNT Passkey 9.1.1.2 New: Improved the support for Blu-ray BluPath. http://www.dvdfab.cn/mlink/download.php?g=PASSKEY |
DVDFab 10.0.2.8
New: Add the support to remove the Cinavia watermarks from Blu-ray movies including Before Midnight, The Kings of Summer and Lambert & Stamp.
Fix: A problem that DVDFab does not display correctly after updating from the old version in certain cases. Fix: A problem that DVD sources could not be previewed in certain cases. http://www.dvdfab.cn/mlink/download.php?g=DVDFAB_CNT |
Passkey 9.1.1.1
New: Improved the support for creating protected ISO with Blu-ray discs.
| Wszystkie czasy w strefie CET. Aktualna godzina: 15:02. |
