Passkey 9.2.1.2
DVDFab 10.0.4.8 + Passkey 9.2.1.1
DVDFab 10.0.4.8
New: Introduced the new product Screen Recorder & Editor for iOS under the Utilities tab. Note that this product is still at the Alpha stage, if you have advices and suggestions, please feel free to let us know. More Info: http://www.dvdfab.cn/screen-recorder-editor-for-ios.htm New: Added the ***8220;Copy Source***8221; option in right-click menu in the Main Movie mode of Copy module, Ripper and Converter modules. New: Added a ***8220;How to handle read error problems***8221; tip in the read error alert dialog. More Info: http://www.dvdfab.cn/faq/?type=dvd_copy#faq_6 New: Added the support to remove the Cinavia protections found on the Blu-ray versions of Fifty Shades Darker, La La Land, Coming Home, and the DVD versions of Patriots Day and John Wick: Chapter 2. New: Added the support for some new Java protections. Fix: Improved the support for handling read error problems of DVD and Blu-ray discs. Fix: Improved the support for detecting DVDFab Movie Server. Fix: Fixed the problem that DVDFab failed to transfer the output ISO files to the Movie Server in certain cases. Fix: Improved the support for DVD PathPlayer. Fix: Improved the support for BDInfo utility. Fix: Some minor changes and improvements. http://www.dvdfab.cn/download.htm Passkey 9.2.1.1 New: Added the support for some new Java protections. http://www.dvdfab.cn/mlink/download.php?g=PASSKEY |
AnyDVD 8.1.6.5 beta
8.1.6.5 2017 07 18
- New (Blu-ray): Support for new discs - Fix (Blu-ray): Crash with some discs - Fix (DVD): CSS brute force removal did not work with some drives - Some minor fixes and improvements http://sandbox.redfox.bz/SetupAnyDVD8165.exe |
AnyDVD 8.1.6.4 beta
8.1.6.4 2017 07 17
- New (Blu-ray): Support for new discs - Fix (Blu-ray): Crash with some discs - Fix (DVD): CSS brute force removal did not work with some drives - Some minor fixes and improvements http://sandbox.redfox.bz/SetupAnyDVD8164.exe |
DVDFab 10.0.4.7 Beta + Passkey 9.2.1.0
New: Introduced the new product Screen Recorder & Editor for iOS under the Utilities tab. Note that this product is still at the Alpha stage, if you have advices and suggestions, please feel free to let us know. More Info: http://www.dvdfab.cn/screen-recorder-editor-for-ios.htm New: Added the support for some new Java protections. New: Added the ***8220;Copy Source***8221; option in right-click menu in the Main Movie mode of Copy module, Ripper and Converter modules. New: Added a ***8220;How to handle read error problems***8221; tip in the read error alert dialog. More Info: http://www.dvdfab.cn/faq/?type=dvd_copy#faq_6 Fix: Improved the support for DVD PathPlayer. Fix: Improved the support for BDInfo utility. Fix: Some minor changes and improvements. http://www.dvdfab.cn/mlink/download.php?g=DVDFAB10_BETA Passkey 9.2.1.0 New: Improved the support for Blu-ray BluPath. http://www.dvdfab.cn/mlink/download.php?g=PASSKEY |
Passkey 9.2.0.9
New: Improved the support for DVD PathPlayer.
AnyDVD 8.1.6.1 Beta
8.1.6.1 2017 07 04
- New (Blu-ray): Support for new discs - Fix (Blu-ray): Crash with some discs - Some minor fixes and improvements http://sandbox.redfox.bz/SetupAnyDVD8161.exe |
AnyDVD 8.1.6.0
8.1.6.0 2017 07 03
- New (Blu-ray): Support for new discs - New (DVD): Support for new discs - Some minor fixes and improvements https://www.redfox.bz/download/SetupAnyDVD.exe |
DVDFab 10.0.4.6 + Passkey 9.2.0.8
DVDFab 10.0.4.6
New: Added the support for some new Java protections. New: Added the support for the new copy protection found on another US version of the DVD Saban's Power Rangers. Fix: Fixed the failure problem when using VSO and ImgBurn burnning engines in certain cases. http://www.dvdfab.cn/download.htm Passkey 9.2.0.8 New: Added the support for some new Java protections. http://www.dvdfab.cn/mlink/download.php?g=PASSKEY |
DVDFab 10.0.4.5 + Passkey 9.2.0.6
DVDFab 10.0.4.5
New: Added the support for some new Java protections. New: Added the support to remove Cinavia watermarks as found on the Blu-ray versions of Patriot's Day (Canada edition)) and John Wick: Chapter 2 (Canada edition). New: Added the support for the new copy protections found on the DVD versions of John Wick: Chapter 2 (Canada edition) and Saban's Power Rangers. New: Introduced the new tool BDFix available under the Utility tab. More Info: http://www.dvdfab.cn/bdfix.htm New: Added the support to save DVD & Blu-ray ISO files directly to DVDFab Movie Server. More Info: http://www.dvdfab.cn/movie-server.htm Fix: Fixed the problem that BDInfo scans incorrect bitrates in certain cases. Fix: Fixed the problem that the file size is too small when compressing Blu-ray sources to BD25 with AMD GPU in certain cases. Fix: Fixed the pixelization problem when ripping to AVI videos. Fix: Fixed the crash problem when removing Apple DRM encryptions in certain cases. Fix: Some minor fixes and improvements. http://www.dvdfab.cn/download.htm Passkey 9.2.0.6 New: Added the support for some new Java protections. http://www.dvdfab.cn/mlink/download.php?g=PASSKEY |
AnyDVD 8.1.5.2 Beta
8.1.5.2 2017 06 30
- New (Blu-ray): Support for new discs - New (DVD): Support for new discs - Some minor fixes and improvements When testing, please check for DVD regression problems. Thank you. http://sandbox.redfox.bz/SetupAnyDVD8152.exe |
AnyDVD 8.1.5.1 Beta
8.1.5.1 2017 06 29
- New (Blu-ray): Support for new discs - New (DVD): Support for new discs - Some minor fixes and improvements When testing, please check for DVD regression problems. Thank you. http://sandbox.redfox.bz/SetupAnyDVD8151.exe |
DVDFab 10.0.4.4 Beta
New: Improved the incremental update feature. Fix: Fixed the problem that BDInfo scans incorrect bitrate in certain cases. Fix: Fixed the pixelization problem when ripping to AVI videos. Fix: Some minor fixes and improvements. http://www.dvdfab.cn/mlink/download.php?g=DVDFAB10_BETA |
DVDFab 10.0.4.3 + Passkey 9.2.0.4 + AnyDVD 8.1.5.0
DVDFab 10.0.4.3
New: Added the support for some new Java protections. New: Added the support for the new copy protection as found on DVD John Wick: Chapter 2. New: Added the support to remove Cinavia watermarks as found on the Blu-ray versions of Patriot's Day, John Wick: Chapter 2, The Eagle Huntress and La La Land. Fix: Some minor fixes and improvements. http://www.dvdfab.cn/download.htm Passkey 9.2.0.4 New: Added the support for some new Java protections. New: Added the support for the new copy protection as found on DVD John Wick: Chapter 2. http://www.dvdfab.cn/mlink/download.php?g=PASSKEY AnyDVD 8.1.5.0 8.1.5.0 2017 06 20 - New (Blu-ray): Support for new discs - New (DVD): Support for new discs - Some minor fixes and improvements https://www.redfox.bz/download/SetupAnyDVD8150.exe |
AnyDVD 8.1.4.5 Beta
8.1.4.5 2017 06 20
- New (Blu-ray): Support for new discs - New (DVD): Support for new discs - New: OPD can be used, if Passkey is installed - Change (DVD): OPD is currently disabled - Caution (DVD): There might be regression problems. - Some minor fixes and improvements http://sandbox.redfox.bz/SetupAnyDVD8145.exe |
| Wszystkie czasy w strefie CET. Aktualna godzina: 15:02. |
