-   Zabezpieczenia CD/DVD/Blu-ray (https://forum.cdrinfo.pl/f11/)
-   -   [ARTYKUŁ]Jak wykonać kopię płyt BluRay (https://forum.cdrinfo.pl/f11/artykul-jak-wykonac-kopie-plyt-bluray-95913/)
czary2mary 18.06.2017 19:54
Passkey 9.2.0.3
New: Added the support for some new Java protections.
Fix: A crash problem when doing the BDFix in certain caes.
http://www.dvdfab.cn/mlink/download.php?g=PASSKEY
czary2mary 16.06.2017 09:29
DVDFab 10.0.4.2
New: Added the support to remove Cinavia watermarks as found on the Blu-ray versions of At Any Price, Elvis and Nixon, Love and Mercy, Don***8217;t Kill It and the DVD versions of Sing, Middle School: The Worst Years of My Life.
New: Added the Scheduled Task feature to the Task Queue Manager.
New: Added the 10bit support to several MKV and MP4 profiles in the Ripper and Converter modules.
Fix: Some minor fixes and improvements.
http://www.dvdfab.cn/download.htm
czary2mary 14.06.2017 08:01
Passkey 9.2.0.2
Passkey 9.2.0.2
jarek665 12.06.2017 09:19
bardzo to jest przydatne
czary2mary 08.06.2017 20:58
DVDFab 10.0.4.1 Beta + AnyDVD 8.1.4.3 Beta
New: Added the support to remove Cinavia watermarks as found on the Blu-ray versions of Love and Mercy, Don***8217;t Kill It and the DVD version of Sing, Middle School: The Worst Years of My Life.
http://www.dvdfab.cn/mlink/download.php?g=DVDFAB10_BETA
AnyDVD 8.1.4.3 Beta
8.1.4.3 2017 06 08
- New (Blu-ray): Support for new discs
- New (DVD): Support for new discs
- Some minor fixes and improvements
http://sandbox.redfox.bz/SetupAnyDVD8143.exe
czary2mary 07.06.2017 18:54
Passkey 9.2.0.1
czary2mary 30.05.2017 17:02
AnyDVD 8.1.4.0
8.1.4.0 2017 05 29
- Fix: Bug introduced in 8.1.3.0, optical drives disappear after fresh installation on a 32 bit machine
https://www.redfox.bz/download/SetupAnyDVD.exe
czary2mary 29.05.2017 16:04
DVDFab 10.0.4.0 + Passkey 9.2.0.0 + AnyDVD 8.1.3.0
DVDFab 10.0.4.0
Fix: Improved the support for Cloud Decryption service for Blu-rays.
Fix: A crash problem when opening Apple DRM videos in certain cases.
Passkey 9.2.0.0
Note: Beginning with Passkey v9.2.0.0, Cloud Decryption Database will be disabled if AnyDVD is installed on your PC.
New: Introduced the new feature called Fix Blu-ray(BDFix), BDFix can fix the ripped Blu-ray playback problem if the protections like Region Code, Screen Pass are not removed correctly.
More Info: http://www.dvdfab.cn/manual/passkey/blu-ray-fix
AnyDVD 8.1.3.0
8.1.3.0 2017 05 22
Fix (Blu-ray): The feature, which helps non-licensed Blu-ray players (Kodi, VLC, Media Players, ...) to pick the correct playlist for the main feature, did not work with some discs
Included a security update of ElbyCDIO.sys.
A malicious program could gain administrative rights using ElbyCDIO.sys on Windows XP and the 32-bit versions of Windows Vista and Windows 7.
http://sandbox.redfox.bz/SetupAnyDVD8130.exe
czary2mary 19.05.2017 09:17
AnyDVD 8.1.2.3 beta
8.1.2.3 2017 05 17
- Fix (Blu-ray): The feature, which helps non-licensed Blu-ray players
- Included a security update of ElbyCDIO.sys
http://sandbox.redfox.bz/SetupAnyDVD8123.exe
czary2mary 18.05.2017 10:20
AnyDVD 8.1.2.2 beta
8.1.2.2 2017 05 17
http://sandbox.redfox.bz/SetupAnyDVD8122.exe
czary2mary 17.05.2017 05:50
DVDFab 10.0.3.9 + AnyDVD 8.1.2.1 beta
DVDFab 10.0.3.9
New: Added the support to open the unprotected 4K UHD Blu-ray sources. Users can scan for detailed Blu-ray info, but cannot copy/convert for now.
New: Introduced the free product BDInfo which is available under the Utilities tab. It can show the detailed info about the source including Cinavia, Atmos, DTS:X, HDR, etc. More Info: http://www.dvdfab.cn/bdinfo.htm
AnyDVD 8.1.2.1 beta
8.1.2.1 2017 05 16
http://sandbox.redfox.bz/SetupAnyDVD8121.exe
czary2mary 14.05.2017 07:03
DVDFab 10.0.3.8 Beta
New: Added the support to open the unprotected 4K UHD Blu-ray sources. User can scan for BDInfo, but cannot copy/convert for now.
New: Introduced the free product BDInfo which is available under the Utilities tab. It can show detail info about the source including Cinavia, Atmos, DTS:X, HDR, etc. More Info:
czary2mary 06.05.2017 05:36
AnyDVD 8.1.2.0 + DVDFab 10.0.3.7 Beta + Passkey 9.1.1.6
AnyDVD 8.1.2.0
8.1.2.0 2017 05 05
- Change (Blu-ray): Removed obsolete AACS version information from status window
- Fix (Blu-ray): BD-live wasn't always removed
- Fix (DVD): Regression problem
New: Added the support for some new BD Java protections.
New: Added the AMD APP support to the encoding methods while handling H.264 and H.265 sources.
More info: http://www.dvdfab.cn/amd-app.htm
New: Added the conversion profiles for Samsung Galaxy S8, S8 Plus and Tab S3 in the Ripper and Converter modules.
Fix: Fixed a crash problem when read error occurs while opening certain Blu-ray discs.
Fix: Fixed a crash problem when opening Blu-ray discs in certain cases.
Passkey 9.1.1.6
czary2mary 04.05.2017 17:30
Any DVD HD 8.1.1.4 Beta
8.1.1.4 2017 05 04
http://sandbox.redfox.bz/SetupAnyDVD8114.exe
czary2mary 03.05.2017 18:57
Any DVD HD 8.1.1.3 Beta
8.1.1.3 2017 05 03
http://sandbox.redfox.bz/SetupAnyDVD8113.exe
Wszystkie czasy w strefie CET. Aktualna godzina: 15:02.
