-   Zabezpieczenia CD/DVD/Blu-ray (https://forum.cdrinfo.pl/f11/)
-   -   [ARTYKUŁ]Jak wykonać kopię płyt BluRay (https://forum.cdrinfo.pl/f11/artykul-jak-wykonac-kopie-plyt-bluray-95913/)
czary2mary 10.11.2017 20:21
AnyDVD 8.1.9.5 Beta
8.1.9.5 2017 11 09
- New (Blu-ray): Support for new discs
- New (DVD): Support for new discs
- New (DVD): More aggressive removal of bogus titles, please check for regression problems.
- New: Delayed driver disable, so Windows will receive a disc insertion event on AnyDVD exit
- Change: Avoid reading TOC of non-CD media
- Change (Blu-Ray): Avoid reading physical layout
- Fix: Setting drive speed still didn't work with some drives.
http://sandbox.redfox.bz/SetupAnyDVD8195.exe
czary2mary 09.11.2017 09:37
AnyDVD 8.1.9.4 Beta
8.1.9.4 2017 11 07
http://sandbox.redfox.bz/SetupAnyDVD8194.exe
czary2mary 08.11.2017 06:06
AnyDVD 8.1.9.3 Beta
8.1.9.3 2017 11 06
http://sandbox.redfox.bz/SetupAnyDVD8193.exe
czary2mary 07.11.2017 11:22
DeUHD Ultra HD Blu-ray v1.006
1.0.0.6 11/06/2017
Support some new discs, check the details from http://deuhd.ru/4k_uhd_info.html11
Solved some crash problems.
Updated 15 discs on Nov. 06.
https://www.deuhd.ru/download/DeUHD1006.exe
czary2mary 04.11.2017 08:36
DVDFab 10.0.6.5
New: Added the support to remove the Cinavia watermarks found on the Blu-ray version of Bleed for This and Free Fire.
Fix: Some conversion crash problems in certain cases.
Fix: Some minor changes and improvements.
http://www.dvdfab.cn/download.htm
czary2mary 02.11.2017 08:57
DVDFab x64 10.0.6.5
Na razie ukazała się nowa tylko x64 bit wersja .
Producent zapowiedział ukazanie się wersji x32bit w późniejszym terminie .
New: Added the Full Disc backup mode support to the UHD Copy module.
Fix: Fixed the problem that the subtitle of the video converted by UHD Ripper is improperly positioned.
Fix: Fixed the problem that the Fabprocess.exe exits unexpectedly in the middle of the conversion.
http://www.dvdfab.cn/mlink/download.php?g=DVDFAB10_x64
czary2mary 31.10.2017 06:53
DeUHD Ultra HD Blu-ray v1.005
1.0.0.5 10/30/2017
Support some new discs, check the details from http://deuhd.ru/4k_uhd_info.html4
Speed up the rip speed.
Solved the problem that cannot register with some email format.
To install the new version 1.0.0.5, you need to uninstall the old version and restart your computer first.
https://www.deuhd.ru/download/DeUHD1005.exe
czary2mary 26.10.2017 10:05
DVDFab 10.0.6.4
New: Added the support to some new Java protections.
New: Added the support to remove the Cinavia watermarks found on the Blu-ray version of The Mummy, and the DVD versions of the Gods of Egypt and the Power Rangers.
New: Added the support to enable CUDA or Intel Quick Sync hardware acceleration while converting to 4K relevant profiles.
Fix: Improved the profile selection process in the Ripper and Converter modules.
Fix: Fixed the problem that DRM Removal module cannot access the iTunes music library in certain cases.
Fix: Added the support to preserve the resolution as 480i in the Blu-ray Copy module if the original source is 480i.
Fix: Fixed the problem that the color range is not recognized while selecting certain profiles in the Blu-ray Ripper module .
czary2mary 24.10.2017 12:14
DeUHD Ultra HD Blu-ray v1.004
1.0.0.4 10/23/2017
Support to check for update.
https://www.deuhd.ru/download/DeUHD1004.exe
czary2mary 22.10.2017 09:05
SoThinkMedia
Fengtao Software -DVDFab wykupił firmę i wszystkie prawa do programów Sothink Media – BluRay Copy.
Zakończone jednocześnie zostało wsparcie i rozwój tych programów które oczywiście będą dalej działały ale jednocześnie nie ukażą się nowe wersje ani aktualizacje .
Firma Fengtao Software oferuje dotychczasowym użytkownikom programów Sothink Media – BluRay Copy 50% zniżki na licencje programów DVDFab .
Strona firmowa Sothink Media – BluRay Copy jest już przekierowywana (Fengtao Software )
http://www.sothinkmedia.com/.htm
czary2mary 21.10.2017 06:34
DVDFab 10.0.6.3 Beta + DVDFab Passkey 9.2.1.7
New: Added the support to enable CUDA or Intel Quick Sync hardware acceleration while converting to HEVC 8bit/10bit profiles.
http://www.dvdfab.cn/mlink/download.php?g=DVDFAB10_BETA
New: Added the support for some new Java protections.
http://www.dvdfab.cn/mlink/download.php?g=PASSKEY
czary2mary 18.10.2017 07:08
AnyDVD 8.1.9.2 Beta
8.1.9.2 2017 10 16
http://sandbox.redfox.bz/SetupAnyDVD8192.exe
czary2mary 17.10.2017 08:23
DeUHD Ultra HD Blu-ray v.1003
1.0.0.3 10/16/2017
Solved the problem that cannot rip to ISO sometimes.
http://deuhd.ru/download/DeUHD1003.exe
czary2mary 09.10.2017 20:07
DeUHD Ultra HD Blu-ray v.1002
Aktualizacja:
http://deuhd.ru/download/DeUHD1002.exe
The changelog is in:
Support to try 3 discs in trial version.
Support some new discs, check the details from http://deuhd.ru/4k_uhd_info.html (dodano 10 nowych tytułów)
Decrypt all the m2ts files 8~10 minutes in the trial version, means that you can watch the movie with the navigation menu.
Improved the rip speed in trial version.
czary2mary 05.10.2017 19:43
AnyDVD 8.1.9.1 Beta
8.1.9.1 2017 10 04
- Change: Dropped support for Windows 2000 because of compiler update
http://sandbox.redfox.bz/SetupAnyDVD8191.exe
Wszystkie czasy w strefie CET. Aktualna godzina: 13:53.
