AnyDVD 8.2.1.9 beta
8.2.1.9 2018 01 30
- New: PowerDVD 14 UHD OEM is now supported by AnyDVD's unique Cinavia fix - New (UHD Blu-ray): Added decryption with "UHD friendly" drives (experimental). - New (UHD Blu-ray): Prevent "UHD friendly" drives to "lock" after some minutes of inactivity. - New (Blu-ray): Support for new discs - New (DVD): Support for new discs - Change: Removed drive serial number from status window and logfile - Some minor fixes and improvements http://sandbox.redfox.bz/SetupAnyDVD8219.exe |
AnyDVD 8.2.1.8 beta
8.2.1.8 2018 01 30
- New: PowerDVD 14 UHD OEM is now supported by AnyDVD's unique Cinavia fix - New (UHD Blu-ray): Prevent "UHD friendly" drives to "lock" after some minutes of inactivity. - New (Blu-ray): Support for new discs - New (DVD): Support for new discs - Change: Removed drive serial number from status window and logfile - Some minor fixes and improvements http://sandbox.redfox.bz/SetupAnyDVD8218.exe |
DeUHD Ultra HD Blu-ray 1.0.1.8
1.0.1.8 01/29/2018
Support some new discs, check the details from http://deuhd.ru/4k_uhd_info.html Added support for different versions of some titles already on the list. https://www.deuhd.ru/download.html |
DVDFab 10.0.7.9 + AnyDVD 8.2.1.7 beta
DVDFab 10.0.7.9
New: Added the support for AACS v64. New: Added the support for some new Java protections. http://www.dvdfab.cn/download.htm AnyDVD 8.2.1.7 beta 8.2.1.7 2018 01 23 - New: PowerDVD 14 UHD OEM is now supported by AnyDVD's unique Cinavia fix - New (UHD Blu-ray): Fetch AACS keys from external file for use with "UHD-friendly" drives. The key file location can be changed in AnyDVD settings - New (UHD Blu-ray): Prevent "UHD friendly" drives to "lock" after some minutes of inactivity. - New (Blu-ray): Support for new discs - New (DVD): Support for new discs - Change: Removed drive serial number from status window and logfile - Some minor fixes and improvements [url]http://sandbox.redfox.bz/SetupAnyDVD8217.exe[/url |
DeUHD Ultra HD Blu-ray 1.0.1.7
1.0.1.7 01/22/2018
DeUHD Ultra HD Blu-ray 1.0.1.6
1.0.1.6 01/15/2018
Support some new discs, check the details from http://deuhd.ru/4k_uhd_info.html Added support for different versions of some titles already on the list. Support to create the protected ISO file (The file can only read from a virtual drive when DeUHD is running!). Support to decrypt the protected ISO which created by DeUHD or third party programs. https://www.deuhd.ru/download.html |
DVDFab x64 10.0.7.7
New: Added the support to remove Cinavia watermarks of the infected DVDs and Blu-rays with the Full Disc mode. New: Added the support to remove the Cinavia watermark from the DVD version of the Rock Dog. New: Added the support to clone the 4K Ultra HD Blu-rays with the leaked keys. Fix: The occasional crash problem when removing Cinavia watermarks under the Main Movie mode. Fix: The problem that the subtitles are inaccurately positioned after being rendered in the UHD Ripper module. Fix: The audio channel decreasing problem when converting with m2ts.passthrough profile if the sources are filled with DTS-HD or DTS: X audios. Fix: The authorization failure problem in some rare cases. Fix: Some minor changes and improvements. http://www.dvdfab.cn/mlink/download.php?g=DVDFAB10_x64 |
Passkey 9.2.2.5
http://www.dvdfab.cn/mlink/download.php?g=PASSKEY |
AnyDVD 8.2.1.5 Beta
8.2.1.5 2018 01 11
New: PowerDVD 14 UHD OEM is now supported by AnyDVD***8217;s unique Cinavia fix New (UHD Blu-ray): Fetch AACS keys from external file for use with ***8220;UHD-friendly***8221; drives. The key file location can be changed in AnyDVD settings New (UHD Blu-ray): Prevent ***8220;UHD friendly***8221; drives to ***8220;lock***8221; after some minutes of inactivity. New (Blu-ray): Support for new discs New (DVD): Support for new discs Some minor fixes and improvements http://sandbox.redfox.bz/SetupAnyDVD8215.exe |
DeUHD Ultra HD Blu-ray 1.0.1.5
1.0.1.5 01/09/2018
Support some new discs, check the details from http://deuhd.ru/4k_uhd_info.html Added support for different versions of some titles already on the list. Solved an installation problem. Added Italian language.(Thanks for the contributors.) https://www.deuhd.ru/download.html |
DVDFab 10.0.7.7
New: Added the support to remove Cinavia watermarks of the infected DVDs with the Full Disc mode.
Fix: Some minor changes and improvements. https://www.dvdfab.cn/download.htm |
Passkey 9.2.2.4
Fix: A failure problem when ripping DVD/Blu-ray discs to ISO in certain cases.
DeUHD Ultra HD Blu-ray 1.0.1.4
1.0.1.4 01/01/2018
Support some new discs, check the details from http://deuhd.ru/4k_uhd_info.html Added support for different versions of some titles already on the list. Set the last rip output path as the default. Raised two discs limitation to six discs/day for Lifetime users. https://www.deuhd.ru/download.html |
LG BH16NS55 zrzuca takie płyty w dowolnym programie bez zająknięcia, nie trzeba żadnych kombinacji. Pisałem o FairMount, bo pojawił się w tym wątku i byłem ciekaw czy komukolwiek ten program pomógł z jakimkolwiek zabezpieczeniem :) Dzięki za pomoc! |
| Wszystkie czasy w strefie CET. Aktualna godzina: 15:02. |
