-   Zabezpieczenia CD/DVD/Blu-ray (https://forum.cdrinfo.pl/f11/)
-   -   [ARTYKUŁ]Jak wykonać kopię płyt BluRay (https://forum.cdrinfo.pl/f11/artykul-jak-wykonac-kopie-plyt-bluray-95913/)
czary2mary 19.06.2019 06:14
DeUHD Ultra HD Blu-ray 1.0.4.0
1.0.4.0 06/18/2019
Support some new discs, check the details from http://deuhd.ru/4k_uhd_info.html
Added support for different versions of some titles already on the list.
Fixed some crash problems.
https://www.deuhd.ru/download.html
czary2mary 15.06.2019 02:30
DVDFab 11.0.3.5
https://www.dvdfab.cn/download.htm
New: Added the support for some new Java protections.
New: Added the support for the LG BU40N UHD drive with firmware version 1.01 and 1.02.
New: Added the support to download 8K videos in the Video Downloader utility tool.
New: Added the support to detect 8K decoder and encoder at Common Settings > A/V Codec > Hardware Info.
New: Added the support to convert DVDs, Blu-rays, 4K Ultra HD Blu-rays and other videos to 8K MP4, MKV or M2TS videos.
New: Added the support to convert 8K videos with NVIDIA CUDA hardware acceleration (Pascal series video cards or above required).
New: Improved the user experience when choosing Movie Server as the output destination from the output selection list.
Fix: A problem that the bit rate setting cannot be changed at the Advanced Settings panel when MP4.Dolby Vision conversion profile is selected.
Fix: A crash problem upon program startup in certain cases.
Fix: A no sound problem when converting 4K MKV videos for iPad in the Video Converter module.
czary2mary 05.06.2019 20:06
AnyDVD 8.3.6.0
https://www.redfox.bz/download/SetupAnyDVD.exe
8.3.6.0 2019 06 04
- New (Blu-ray): Support for new discs
- New (Blu-ray): Stability improvements
- New (DVD): Support for new discs
- Some minor fixes and improvements
czary2mary 03.06.2019 01:00
DVDFab 11.0.3.4
New: Added the support to output 224kbps AC3 audios in the Ripper and Video Converter modules.
Fix: A problem that NVDIA GPU hardware acceleration cannot be turned on with 2-pass encoding method in the Ripper and Video Converter modules.
czary2mary 30.05.2019 19:53
DVDFab 11.0.3.3
New: Added the support to compress the output video to a smaller size when converting with the MP4.Dolby Vision profile in the UHD Ripper module.
New: Added the Copy Audio option to MP4.Dolby Vision profile at the Advanced Settings panel of the UHD Ripper module.
Fix: A problem that the audio/subtitles preselection settings at the Common Settings > Streams do not work for the Video Converter module.
Fix: A crash problem when loading certain BDMV folder sources.
Fix: An output oversize problem when converting certain DVDs for iPads.
Fix: A video stuttering problem caused by using hardware acceleration with NVIDIA***8217;s GeForce RTX-20 series video cards, such as RTX 2080.
czary2mary 26.05.2019 00:17
AnyDVD 8.3.5.3 Beta
http://sandbox.redfox.bz/SetupAnyDVD8353.exe
8.3.5.3 2019 05 24
czary2mary 25.05.2019 00:33
Passkey 9.3.4.8
http://www.dvdfab.cn/mlink/download.php?g=PASSKEY
Fix: A problem opening DVDs caused by network connection failure.
czary2mary 23.05.2019 02:45
DVDFab 11.0.3.2
Fix: A problem that the IQS hardware acceleration does not work on machines installed with Intel UHD Graphics 605.
Fix: A freeze problem when converting certain UHD sources to MKV videos in the UHD Ripper module.
Fix: A problem that the required free space in output directory is doubled if Web Optimized option is selected at the Advanced Settings panel when converting with MP4 relevant profiles in the Ripper modules.
Fix: A crash problem when merging multiple titles in the Ripper module.
Fix: Improved the Video Downloader utility.
Fix: Improved the conversion regarding 4K Dolby Vision videos.
Fix: Improved the GUI and UE for loading discs.
Fix: Some minor changes and improvements.
czary2mary 18.05.2019 04:35
Passkey 9.3.4.3
New: Added the support for the BS4K & CS4K (4K BDAV) contents recorded by Sharp devices.
czary2mary 17.05.2019 05:46
DVDFab 11.0.3.1
New: Added the support for NVIDIA***8217;s latest Turing video cards including GeForce 16 series/GeForce 20 series and more.
New: Added the support to show the source size under the Clone mode of the Copy modules.
New: Added the new MP4.Dolby Vision conversion profile in the UHD Ripper module to preserve the Dolby Vision contents for playback on Dolby Vision compatible TVs.
New: Added the support to output AAC 7.1/OGG 7.1/PCM 7.1/DTS 7.1/WMA10 7.1/E-AC-3 5.1 audios in the Ripper and Video Converter modules.
Fix: A problem that the file title cannot be renamed at the main interface of the Ripper modules.
Fix: Some minor GUI improvements.
czary2mary 14.05.2019 14:39
DVDFab 11.0.3.0 Beta
DVDFab 32-bit :
http://www.dvdfab.cn/mlink/download.php?g=DVDFAB11_BETA
DVDFab 64-bit :
http://www.dvdfab.cn/mlink/download....FAB11_x64_BETA
Fix: A problem that the converted MP4 videos by Blu-ray Ripper module fail to play back in certain cases.
czary2mary 13.05.2019 13:03
AnyDVD 8.3.5.2 Beta
http://sandbox.redfox.bz/SetupAnyDVD8352.exe
8.3.5.2 2019 05 10
czary2mary 10.05.2019 11:05
DVDFab 11.0.2.9 + Passkey 9.3.4.6
DVDFab 11.0.2.9
New: Introduced the Free version of the Video Converter module.
New: Added the DTS audio conversion profile in the Ripper and Converter modules.
New: Added the Passthrough and Conversion Processing Mode options at the Advanced Settings panel of the DVD to Blu-ray Converter module.
Fix: A problem that the titles of certain recorded Blu-rays are not displayed properly after being loaded into the main interface.
Fix: An output oversize problem when copying certain BDAV sources to BD25 size.
Fix: A crash problem when opening certain BDAV sources.
Fix: A problem that the Subtitle is reverted back to English from None after changing the output destination path in the Video Converter module.
Fix: A freeze problem when clicking the Edit button in the Video Converter module.
Fix: A problem that an ISO file is still reported by Windows as occupied by DVDFab despite being deleted as the source from the Ripper modules.
Fix: Some minor GUI and UE improvements.
Passkey 9.3.4.6
New: Added support to reset the Blu-ray region code settings for PowerDVD 19.
czary2mary 03.05.2019 03:04
Passkey 9.3.4.5
czary2mary 30.04.2019 06:12
AnyDVD 8.3.5.1 Beta + DVDFab 11.0.2.8 + Passkey 9.3.4.4
AnyDVD 8.3.5.1 Beta
http://sandbox.redfox.bz/SetupAnyDVD8351.exe
8.3.5.1 2019 04 29
- New (Blu-ray): Workaround for playback problems with JRiver Media Center
DVDFab 11.0.2.8
New: Added the support to a new copy protection found on the DVD version of The Dictator.
New: Added the support for the BS4K & CS4K (4K BDAV) contents recorded by Sharp devices in the Clone mode of the UHD Copy module.
Fix: An estimation error problem on the output file size if the Same as Source option is selected at the Advanced Settings panel of the Creator module.
Passkey 9.3.4.4
Wszystkie czasy w strefie CET. Aktualna godzina: 15:04.
