-   Zabezpieczenia CD/DVD/Blu-ray (https://forum.cdrinfo.pl/f11/)
-   -   [ARTYKUŁ]Jak wykonać kopię płyt BluRay (https://forum.cdrinfo.pl/f11/artykul-jak-wykonac-kopie-plyt-bluray-95913/)
czary2mary 29.11.2019 11:36
DVDFab 11 v11.0.6.2+ Passkey 9.3.6.6
DVDFab 11 v11.0.6.2
https://www.dvdfab.cn/download.htm
New: Added the support for some new Java protections.
New: Added the support to detect the new Blu-ray Java protections that are not supported yet.
New: Added the new Disc Messenger feature to notify you inside DVDFab about the newly supported 4K Ultra HD Blu-rays and Java protected Blu-rays.
New: Improved the poster display for Japanese adult movies.
New: Improved the Enlarger AI***8217;s hardware compatibility.
Fix: A crash problem when opening AACS 2.1 protected 4K Ultra HD Blu-ray discs.
Fix: A wrong aspect ratio problem when converting 4:3 DVDs to Blu-rays with Enlarger AI.
Passkey 9.3.6.6
http://www.dvdfab.cn/mlink/download.php?g=PASSKEY
czary2mary 28.11.2019 07:38
AnyDVD 8.4.1.0
https://www.redfox.bz/download/SetupAnyDVD.exe
8.4.1.0 2019 11 27
- New (Blu-ray): Support for new discs
- New (DVD): Support for new discs
- Fix (Blu-ray): AnyDVD could invalidate playlists in some situations
- Some minor fixes and improvements
czary2mary 26.11.2019 08:34
AnyDVD 8.4.0.3 Beta
http://sandbox.redfox.bz/SetupAnyDVD8403.exe
8.4.0.3 2019 11 25
czary2mary 22.11.2019 15:05
DVDFab 11 v11.0.6.1+ Passkey 9.3.6.5
DVDFab 11 v11.0.6.1
New: Introduced the brand-new Enlarger AI module, the world's 1st complete AI-powered, deep learning capable video upscaling solution to enlarge videos from 480p to 1080p. More Info: https://www.dvdfab.cn/enlarger-ai.htm or https://forum.dvdfab.cn/forum/softwa...faq#post374874
Passkey 9.3.6.5
Fix: A problem that the Passkey ad takes 100% of the CPU usage.
czary2mary 17.11.2019 06:28
DVDFab 11.0.6.0
Fix: A problem that the disc is ejected from optical drive during the loading process.
czary2mary 14.11.2019 14:22
DVDFab 11.0.5.9 + Passkey 9.3.6.4 + AnyDVD 8.4.0.2
DVDFab 11.0.5.9
New: Improved the user experience.
Fix: A crash problem when opening discs in certain cases.
Passkey 9.3.6.4
AnyDVD 8.4.0.2
http://sandbox.redfox.bz/SetupAnyDVD8402.exe
8.4.0.2 2019 11 13
czary2mary 12.11.2019 17:09
DVDFab 11.0.5.8 + Passkey 9.3.6.3
DVDFab 11.0.5.8
New: Renamed DVDFab Prime to DVDFab 365.
More Info:
https://www.dvdfab.cn/member.htm?a=dvdfab365
New: Introduced the Cloud Backup service (exclusive to DVDFab 365 subscribers) to back up custom profiles, configurations, etc. to cloud server.
Passkey 9.3.6.3
czary2mary 07.11.2019 18:38
AnyDVD 8.4.0.1 Beta
http://sandbox.redfox.bz/SetupAnyDVD8401.exe
8.4.0.1 2019 11 05
czary2mary 05.11.2019 01:18
DVDFab 11.0.5.7 + Passkey 9.3.6.2
DVDFab 11.0.5.7
Fix: A problem that the setting Exit program when all tasks are done does not work as it should.
Fix: A failure problem when directly outputting to the Movie Server with the Full Disc mode of the DVD Copy module.
Passkey 9.3.6.2
New: Improved the support for 4K UHD Blu-ray discs.
czary2mary 24.10.2019 14:57
DVDFab 11.0.5.6 + Passkey 9.3.6.1
DVDFab 11.0.5.6
Fix: A conversion problem with 2-pass encoding method in the Video Converter module.
Fix: A freeze problem if multiple tasks are added to the task queue of the Video Converter module.
Fix: A crash problem when expired users load sources to the Video Converter module in certain cases.
Passkey 9.3.6.1
Fix: A problem that no text is displayed on the authorization window in certain cases.
czary2mary 22.10.2019 07:53
AnyDVD 8.4.0.0
8.4.0.0 2019 10 21
- New (Blu-ray): Improved allocation of spare sectors. Allows remastering of unprotected discs, e.g. US "on demand" discs.
- Fix (DVD): Crash with some Japanese discs
czary2mary 20.10.2019 05:49
Passkey 9.3.5.9
New: Introduced the online authorization method to activate the software.
czary2mary 18.10.2019 01:14
DVDFab 11.0.5.5 + AnyDVD 8.3.9.6 Beta
DVDFab 11.0.5.5
New: Added the support to turn on/off the NFO file creation feature at Common Settings > Meta.
AnyDVD 8.3.9.6 Beta
http://sandbox.redfox.bz/SetupAnyDVD8396.exe
8.3.9.6 2019 10 17
czary2mary 15.10.2019 08:36
DeUHD Ultra HD Blu-ray 2.0.0.3
2.0.0.3 10/11/2019
Added support for new discs.
Made some improvement.
https://www.deuhd.ru/download.html
czary2mary 11.10.2019 06:48
DVDFab 11.0.5.4
New: Improved the burning speed quite a bit.
Wszystkie czasy w strefie CET. Aktualna godzina: 13:53.
