DVDFab 11.0.4.1 + Passkey 9.3.5.5 + AnyDVD 8.3.8.0
DVDFab 11.0.4.1
https://www.dvdfab.cn/download.htm New: Added the support for some new Java protections. New: Added the support to detect if the loaded sources are 4K sources containing Dolby Vision & HDR10+ content, such as Alita: Battle Angel. New: Added the support to preserve the Dolby Vision & HDR10+ content when outputting BD100 size in the UHD Copy module. New: Added the support to remux SRT subtitles when choosing the conversion profiles for Apple devices in the Ripper modules. New: Added the support to extract to SRT subtitles when choosing the MP4. Dolby Vision conversion profile in the UHD Ripper module. Fix: A failure problem when removing Cinavia watermarks with the Full Disc mode in the Blu-ray Copy module. Passkey 9.3.5.5 http://www.dvdfab.cn/mlink/download.php?g=PASSKEY New: Added the support for some new Java protections. AnyDVD 8.3.8.0 https://www.redfox.bz/download/SetupAnyDVD.exe 8.3.8.0 2019 08 02 - New (Blu-ray): Support for new discs - New (DVD): Support for new discs - New (DVD): Show drive region if drive is empty - New (DVD): Enable AI scanner automatically if required with older discs - Some minor fixes and improvements |
DVDFab 11.0.4.0
New: Added the support for some new Java protections. New: Added the support to extract the subtitles of DVDs/Blu-rays/4K Ultra HD Blu-rays using the OCR (Optical Character Recognition) technology and then output them as standalone SRT subtitle files in the Ripper modules (Advanced Settings > Subtitle Mode). New: Added the support to extract the subtitles of DVDs/Blu-rays/4K Ultra HD Blu-rays using the OCR (Optical Character Recognition) technology and then remux them as SRT subtitles when choosing MP4 and MKV conversion profiles in the Ripper modules (Advanced Settings > Subtitle Mode). |
AnyDVD 8.3.7.2 Beta
http://sandbox.redfox.bz/SetupAnyDVD8372.exe
8.3.7.2 2019 07 23 - New (Blu-ray): Support for new discs - New (DVD): Support for new discs - New (DVD): Show drive region if drive is empty - New (DVD): Enable AI scanner automatically if required with older discs - Some minor fixes and improvements |
Passkey 9.3.5.3
New: Added the support for some new Java protections. New: Updated certain certificates to prevent possible network connection failures. |
DeUHD Ultra HD Blu-ray 2.0.0.0
2.0.0.0 07/15/2019
From V 2.0.0, DeUHD has been able to rip ALL UHD discs. If you failed to open your disc, just retry after 1 working day. DeUHD will decrypt it automatically for you! https://www.deuhd.ru/download.html |
DVDFab 11.0.3.9
New: Added the support for some new Java protections. Fix: A problem that the output file contains two audio tracks despite only one is selected if the Copy Audio option is ticked at the Advanced Settings panel when converting 4K Ultra HD Blu-rays containing Dolby Vision content with the Dolby Vision relevant profiles. Fix: A problem that DVDFab cannot correctly calculates the size of certain DVD ISO files. |
Passkey 9.3.5.1
AnyDVD 8.3.7.1 Beta
8.3.7.1 2019 07 08
- New (Blu-ray): Support for new discs - New (DVD): Support for new discs - New (DVD): Show drive region if drive is empty - New (DVD): Enable AI scanner automatically if required with older discs - Some minor fixes and improvements http://sandbox.redfox.bz/SetupAnyDVD8371.exe |
DVDFab 11.0.3.8 + Passkey 9.3.5.0
DVDFab 11.0.3.8
https://www.dvdfab.cn/download.htm New: Added the support for some new Java protections. New: Added the support to remove the Cinavia watermarks found on the Blu-ray 2D & 3D versions of Resident Evil: The Final Chapter (2016). New: Some minor improvements on GUI and UE. Passkey 9.3.5.0 http://www.dvdfab.cn/mlink/download.php?g=PASSKEY New: Added the support for some new Java protections. |
AnyDVD 8.3.7.0
8.3.7.0 2019 07 03 New (Blu-ray): Support for new discs New (Blu-ray): CloneBD 1.2.5.0 is now supported by AnyDVD's Cinavia fix. It allows to modify the audio data within CloneBD during the copy operation. CloneBD must be decoding the audio data (downsampling to AC3/DTS must be enabled in CloneBD!) The AnyDVD fox icon in the Windows notification area will turn purple, if samples are processed (similar to the PowerDVD and ArcSoft TMT Cinavia patches). New (Blu-ray): Support for incorrectly authored on-demand discs New (DVD): Support for new discs Some minor fixes and improvements |
AnyDVD 8.3.6.3 Beta
http://sandbox.redfox.bz/SetupAnyDVD8363.exe
8.3.6.3 2019 07 02 - New (Blu-ray): Support for new discs - New (Blu-ray): CloneBD 1.2.5.0 is now supported by AnyDVD's Cinavia fix. It allows to modify the audio data within CloneBD during the copy operation. CloneBD must be decoding the audio data (downsampling to AC3/DTS must be enabled in CloneBD!) The AnyDVD fox icon in the Windows notification area will turn purple, if samples are processed (similar to the PowerDVD and ArcSoft TMT Cinavia patches). - New (Blu-ray): Support for incorrectly authored on-demand discs - New (DVD): Support for new discs - Some minor fixes and improvements |
AnyDVD (HD) 8.3.6.2 beta
http://sandbox.redfox.bz/SetupAnyDVD8362.exe
8.3.6.2 2019 06 30 - New (Blu-ray): Support for new discs - New (Blu-ray): CloneBD 1.2.5.0 is now supported by AnyDVD's Cinavia fix. It allows to modify the audio data within CloneBD during the copy operation. CloneBD must be decoding the audio data (downsampling to AC3/DTS must be enabled in CloneBD!) The AnyDVD fox icon in the Windows notification area will turn purple, if samples are processed (similar to the PowerDVD and ArcSoft TMT Cinavia patches). - New (DVD): Support for new discs - Some minor fixes and improvements |
AnyDVD 8.3.6.1 Beta
http://sandbox.redfox.bz/SetupAnyDVD8361.exe
8.3.6.1 2019 06 27 - New (Blu-ray): Support for new discs - New (Blu-ray): CloneBD 1.2.5.0 bit is now supported by AnyDVD's Cinavia fix. It allows to modify the audio data within CloneBD during the copy operation. CloneBD must be decoding the audio data (downsampling to AC3 must be enabled in CloneBD!) The AnyDVD fox icon in the Windows notification area will turn purple, if samples are processed (similar to the PowerDVD and ArcSoft TMT Cinavia patches). - New (DVD): Support for new discs - Some minor fixes and improvements |
DVDFab 11.0.3.7
New: Added the support for some new Java protections. New: Added the H.265 codec support at the Advanced Settings panel when converting HDR content to SDR in the Ripper and Video Converter modules. Fix: Improved the YouTube to MP3 and Video Downloader utility tools to better analyze URLs. |
DVDFab 11.0.3.6
New: Added the support for some new Java protections. New: Added the support to choose different Dolby Versions at the Advanced Settings panel of Dolby Vision relevant conversion profiles. Fix: A problem that users who purchased only Hi-Fi Audio Converter cannot use the product. Fix: Improved the user experience for 8K relevant conversion profiles. |
| Wszystkie czasy w strefie CET. Aktualna godzina: 15:04. |
