-   Zabezpieczenia CD/DVD/Blu-ray (https://forum.cdrinfo.pl/f11/)
-   -   [ARTYKUŁ]Jak wykonać kopię płyt BluRay (https://forum.cdrinfo.pl/f11/artykul-jak-wykonac-kopie-plyt-bluray-95913/)
czary2mary 17.02.2022 11:47
DVDFab 12.0.6.2
https://www.dvdfab.cn/download.htm
DVDFab 12.0.6.2 Changelog
Fix: A startup crash problem due to altered DVDFab host information in the system hosts file.
Fix: A startup crash problem on machines installed with AMD Radeon RX 480 video card.
Fix: A subtitle display problem after burning the videos downloaded from Netflix to BD25 discs in the Blu-ray Creator module.
czary2mary 10.02.2022 12:44
DVDFab 12.0.6.1
DVDFab 12.0.6.1
DVDFab 12.0.6.1 Changelog
Fix: A failure problem when copying certain Japanese DVDs in the Full Disc mode of the DVD Copy module.
Fix: A problem that Japanese subtitles contain messy codes after burning to BD discs.
czary2mary 29.01.2022 10:42
DVDFab Passkey 9.4.3.1
https://www.dvdfab.cn/mlink/download.php?g=PASSKEY
Passkey 9.4.3.1 Changelog
New: Added the support for some new Java protections.
czary2mary 26.01.2022 13:19
DVDFab 12.0.6.0 + AnyDVD 8.5.9.0
DVDFab 12.0.6.0
DVDFab 12.0.6.0 Changelog
Fix: A crash problem when trimming videos in the Video Converter module in certain cases.
Fix: A crash problem when adjusting the size of subtitles in the Video Converter module.
Fix: A failure problem when loading certain MP4 videos in the Blu-ray Creator module.
Fix: A problem that the background art of the menu template in the DVD Creator module cannot be created.
Fix: A crash problem when clicking on the Play with PlayerFab icon from the task queue to play the output files if the PlayerFab has been uninstalled.
Fix: Some minor changes and improvements.
Fix: A crash problem when loading sources in certain cases.
AnyDVD 8.5.9.0
https://www.redfox.bz/download/SetupAnyDVD.exe
8.5.9.0 2022 01 24
New (Blu-ray): Support for new discs
New (UHD): Added support for non-friendly drives with the help of MakeMKV "Libre Drive"
MakeMKV v1.16.5 must be installed for this to work.
czary2mary 21.01.2022 10:37
DVDFab 12.0.5.8 + DVDFab Passkey 9.4.3.0
DVDFab 12.0.5.8
DVDFab 12.0.5.8 Changelog
New: Added the H265 encoding support when converting videos with the TS conversion profile in the Video Converter module.
New: Some improvements on GUI display under higher DPI settings.
Fix: A problem that the live update window still pops up after uninstalling all the DVDFab related products.
Fix: A problem that the text introduction in the Streaming menu template of the Blu-ray Creator module can be manually removed.
Fix: A problem that the cloned ISO files of the 4K Blu-rays recorded by Panasonic DMR-4CW200 cannot play back.
Passkey 9.4.3.0 Changelog
New: Added support for some new Java protections.
czary2mary 13.01.2022 12:29
DVDFab Passkey 9.4.2.9
Passkey 9.4.2.9 Changelog
czary2mary 06.01.2022 07:15
DVDFab Passkey 9.4.2.8
Passkey 9.4.2.8 Changelog
czary2mary 30.12.2021 11:47
DVDFab 12.0.5.7 + DVDFab Passkey 9.4.2.7
DVDFab 12.0.5.7
DVDFab 12.0.5.7 Changelog
Fix: A failure problem when loading videos from the OneDrive directory.
Fix: A failure problem when saving the changes after resetting the directory of log files in the Settings panel.
Fix: A failure problem when opening the output directory after the conversion finishes in the Blu-ray Creator module.
Fix: A problem that the menu settings cannot be remembered in the Creator modules.
Passkey 9.4.2.7 Changelog
czary2mary 24.12.2021 09:04
DVDFab Passkey 9.4.2.6
Passkey 9.4.2.6 Changelog
czary2mary 17.12.2021 16:38
DVDFab 12.0.5.6 + AnyDVD 8.5.8.2 Beta
DVDFab 12.0.5.6
DVDFab 12.0.5.6 Changelog
AnyDVD 8.5.8.2 Beta
https://sandbox.redfox.bz/SetupAnyDVD8582.exe
8.5.8.2 2021 12 15
- New (Blu-ray): Support for new discs
- New (UHD): Added support for non-friendly drives with the help of MakeMKV "Libre Drive"
czary2mary 09.12.2021 12:42
DVDFab Passkey 9.4.2.5
Passkey 9.4.2.5 Changelog
czary2mary 05.12.2021 10:13
DVDFab 12.0.5.5
DVDFab 12.0.5.5 Changelog
Fix: A problem that the option to select Japanese audios and subtitles by default is missing when loading certain Blu-rays into the Blu-ray Ripper module if the OS language is Japanese.
Fix: A problem that Blu-rays larger than 40GB cannot be compressed onto DVDs in the Blu-ray to DVD Converter module.
czary2mary 01.12.2021 07:50
DVDFab Passkey 9.4.2.4
Passkey 9.4.2.4 Changelog
czary2mary 26.11.2021 10:20
DVDFab 12.0.5.4
DVDFab 12.0.5.4 Changelog
New: Added a new AI model DAIN to convert videos with Smoother AI.
Fix: A problem that DVDFab 365 subscribers get incorrect expiration date in certain cases.
czary2mary 23.11.2021 07:00
DVDFab 12.0.5.3 + DVDFab Passkey 9.4.2.3 + AnyDVD 8.5.8.0
DVDFab 12.0.5.3
DVDFab 12.0.5.3 Changelog
Fix: A problem that the Cinavia removal feature in the Blu-ray Ripper module does not work despite having purchased the Blu-ray Cinavia Removal.
Fix: A problem that the DVD Creator module cannot remember the menu mode user previously selected.
Passkey 9.4.2.0 Changelog
AnyDVD 8.5.8.0
8.5.8.0 2021 11 22
- New (Blu-ray): Support for a new structural protection found on "made on demand" discs
- New (DVD): Support for new discs
Wszystkie czasy w strefie CET. Aktualna godzina: 12:52.
