DVDFab Passkey 9.4.2.2
https://www.dvdfab.cn/mlink/download.php?g=PASSKEY
Passkey 9.4.2.2 Changelog New: Added the support for some new Java protections. |
DVDFab 12.0.5.2
https://www.dvdfab.cn/download.htm
DVDFab 12.0.5.2 Changelog New: Added support for some new Java protections. New: Some minor changes and improvements. Fix: A problem that DVDFab Mini cannot switch display languages. Fix: A problem that the posters are not updated when searching for certain movies. Fix: A freeze problem when enlarging videos with Enlarger AI in the DVD Ripper module. |
DVDFab 12.0.5.1
DVDFab 12.0.5.1 Changelog New: Some improvements on the H264 conversion engine. Fix: A problem that the output video has incorrect duration when splitting DVDs in the DVD Copy module. |
DVDFab 12.0.5.0
DVDFab 12.0.5.0 Changelog New: Added support for the new Windows 11 operating system. New: Added support for some new Java protections. Fix: An incorrect resolution problem when converting 4K Ultra HD Blu-rays to SDR 1080p MKV format in the UHD Ripper module. Fix: A failure problem when converting with the MP4.Passthrough profile in the Ripper and Video Converter modules. |
AnyDVD 8.5.7.1 Beta
https://sandbox.redfox.bz/SetupAnyDVD8571.exe
8.5.7.1 2021 10 07 - New (Blu-ray): Support for new discs - New (Blu-ray): Support for a new structural protection found on "made on demand" discs |
DVDFab Passkey 9.4.2.0 + DVDFab 12.0.4.9
https://www.dvdfab.cn/mlink/download.php?g=PASSKEY Passkey 9.4.2.0 Changelog New: Added the support for some new Java protections. DVDFab 12.0.4.9 https://www.dvdfab.cn/download.htm DVDFab 12.0.4.9 Changelog New: Added support for some new Java protections. Fix: A failure problem when converting GIF images with Enlarger AI in Video Converter. Fix: A problem that the frame rate of the created video is inconsistent with the conversion settings when converting certain .m2ts files in Video Converter. |
DVDFab 12.0.4.7
DVDFab 12.0.4.7 Changelog New: Added the Rife 3.0 and Rife 3.1 models in the Smoother AI. New: Added support for the MP4.4K.DolbyVision.H265.10Bit conversion profile in the UHD Ripper module to render subtitles. |
DVDFab 12.0.4.5 + AnyDVD 8.5.7.0
DVDFab 12.0.4.5
https://www.dvdfab.cn/download.htm DVDFab 12.0.4.5 Changelog New: Added support for some new Java protections. New: Added support for the new CAIN model in the Smoother AI module to work with the DVD Ripper and Video Converter modules. Fix: A black screen problem when playing the videos converted from certain HEVC encoded MP4 videos. AnyDVD 8.5.7.0 https://www.redfox.bz/download/SetupAnyDVD.exe 8.5.7.0 2021 08 19 - New (Blu-ray): Support for new discs - New (Blu-ray): Support for a new structural protection found on some Japanese discs - New (DVD): Support for new discs |
DVDFab 12.0.4.3 + AnyDVD 8.5.6.3 Beta
DVDFab 12.0.4.3
https://www.dvdfab.cn/download.htm DVDFab 12.0.4.3 Changelog New: Added the new AI model named CAIN for the Smoother AI in the Blu-ray Ripper module. Fix: A problem that certain Blu-rays made by the Blu-ray Creator cannot play back. Fix: A crash problem when selecting the BD50 output size in the Blu-ray Creator module if the OS language is Japanese. Fix: A display problem under high DPI settings in certain cases. AnyDVD 8.5.6.3 Beta https://sandbox.redfox.bz/SetupAnyDVD8563.exe 8.5.6.3 2021 08 18 - New (Blu-ray): Support for new discs - New (Blu-ray): Support for a new structural protection found on some Japanese discs - New (DVD): Support for new discs |
DVDFab 12.0.4.1 + DVDFab Passkey 9.4.1.9 + AnyDVD 8.5.6.2 Beta
DVDFab 12.0.4.1
https://www.dvdfab.cn/download.htm DVDFab 12.0.4.1 Changelog New: Added support for the Smooth AI module to work with the Video Converter module. Fix: A problem that the edited movie titles change back to the originals after pressing the Enter key on the keyboard. DVDFab Passkey 9.4.1.9 https://www.dvdfab.cn/mlink/download.php?g=PASSKEY Passkey 9.4.1.9 Changelog New: Added the support for some new Java protections. AnyDVD 8.5.6.2 Beta https://sandbox.redfox.bz/SetupAnyDVD8562.exe 8.5.6.2 2021 07 26 - New (Blu-ray): Support for new discs - New (Blu-ray): Support for a new structural protection found on some Japanese discs - New (DVD): Support for new discs |
DVDFab 12.0.4.0 + DVDFab Passkey 9.4.1.7
DVDFab 12.0.4.0
https://www.dvdfab.cn/download.htm DVDFab 12.0.4.0 Changelog Fix: A crash problem when loading sources with the Main Movie mode of the DVD Copy module in certain cases. DVDFab Passkey 9.4.1.7 https://www.dvdfab.cn/mlink/download.php?g=PASSKEY Passkey 9.4.1.7 Changelog New: Added the support for some new Java protections. |
AnyDVD 8.5.6.1 beta
https://sandbox.redfox.bz/SetupAnyDVD8561.exe
8.5.6.1 2021 07 06 - New (Blu-ray): Support for new discs - New (DVD): Support for new discs - New (DVD): Support for a new structural protection found on some Japanese discs |
DVDFab 12.0.3.6 + AnyDVD 8.5.6.0
DVDFab 12.0.3.6
https://www.dvdfab.cn/download.htm DVDFab 12.0.3.6 Changelog New: Added support for some new Java protections. New: Some GUI improvements. Fix: A failure problem when converting certain Blu-rays in the Blu-ray Ripper module. AnyDVD 8.5.6.0 https://www.redfox.bz/download/SetupAnyDVD.exe 8.5.6.0 2021 06 30 - New (Blu-ray): Support for new discs - New (DVD): Support for new discs - Fix (Blu-ray): Regression bug introduced in 8.4.9.3 beta, which caused Blulock fix to fail |
DVDFab 12.0.3.4
DVDFab 12.0.3.4 Changelog Fix: A problem that the EAC3 audio track of the output video contains only 6 channels despite there are 8 in the source when converting Blu-rays in the Blu-ray Ripper module. Fix: A problem that the titles are displayed in the Playlist order by default after opening Blu-rays in the Blu-ray relevant modules. Fix: A crash problem when converting certain BDAV discs in the Blu-ray Recorder Ripper module. Fix: Some minor changes and improvements. |
AnyDVD 8.5.5.1 Beta
https://sandbox.redfox.bz/SetupAnyDVD8551.exe
8.5.5.1 2021 06 12 - New (Blu-ray): Support for new discs - New (DVD): Support for new discs |
| Wszystkie czasy w strefie CET. Aktualna godzina: 12:52. |
